MAX828, MAX829 开关电容电压反相器
电源设计应用
455人已加入
MAX828, MAX829 pdf datasheet
MAX828,MAX829 概述
The MAX828/MAX829 combine low quiescent current and high efficiency. Oscillator control circuitry and four power MOSFET switches are included on-chip. Applications include generating a -5V supply from a +5V logic supply to power analog circuitry. Both parts come in a 5-pin SOT23-5 package and can deliver 25mA with a voltage drop of 500mV.
For a similar device with logic-controlled shutdown, refer to the MAX1719/MAX1720/MAX1721. For applications requiring more power, the MAX860 delivers up to 50mA with a voltage drop of 600mV, in a space-saving µMAX® package.
MAX828,MAX829 关键特性
  • 5-Pin SOT23-5 Package
  • 95% Voltage Conversion Efficiency
  • Inverts Input Supply Voltage
  • 60µA Quiescent Current (MAX828)
  • +1.5V to +5.5V Input Voltage Range
  • Requires Only Two Capacitors
  • 25mA Output Current
  • MAX828,MAX829应用/使用
    电池供电应用
  • 蜂窝电话
  • 手持终端、PDA
  • 医疗仪器
  • 小型LCD板
    MAX828,MAX829应用电路
    反相器
    典型工作电路
