MAX870, MAX871 开关电容电压反相器
电源设计应用
455人已加入
MAX870, MAX871 pdf datasheet
MAX870, MAX871 概述
The ultra-small MAX870/MAX871 monolithic, CMOS charge-pump inverters accept input voltages ranging from +1.4V to +5.5V. The MAX870 operates at 125kHz, and the MAX871 operates at 500kHz. Their high efficiency (90%) and low operating current (0.7mA for the MAX870) make these devices ideal for both battery-powered and board-level voltage-conversion applications.
Oscillator control circuitry and four power MOSFET switches are included on-chip. A typical MAX870/ MAX871 application is generating a -5V supply from a +5V logic supply to power analog circuitry. Both parts come in a 5-pin SOT23-5 package and can deliver 25mA with a voltage drop of 500mV.
For a similar device with logic-controlled shutdown, refer to the MAX1720/MAX1721. For applications requiring more power, the MAX860 delivers up to 50mA with a voltage drop of 600mV, in a space-saving µMAX package.
MAX870, MAX871 关键特性
  • 5-Pin SOT23-5 Package
  • 99% Voltage Conversion Efficiency
  • Invert Input Supply Voltage
  • 0.7mA Quiescent Current (MAX870)
  • +1.4V to +5.5V Input Voltage
  • Require Only Two Capacitors
  • 25mA Output Current
  • Shutdown Control
  • MAX870, MAX871 应用/使用
    电池供电设备
  • 蜂窝电话
  • 手持终端、PDA
  • 从5V逻辑电源产生本地-5V电源
  • 医疗仪器
  • 小型LCD板
    MAX870, MAX871应用电路
    典型工作电路
    • 相关推荐
    • 热点推荐
