16 16点阵显示程序(含电路图)
电子常识
2686人已加入
16 16点阵显示程序
以下是程序.
#include "config.h"
#define                DOTLED_LINE_PORT        PORTB
#define                DOTLED_LINE_DDR                DDRB
#define                DOTLED_LINE_PIN                PINB
#define                DOTLED_LINE_SCKT        PB1
#define                DOTLED_LINE_SCKH        PB5
#define                DOTLED_LINE_SDA                PB3
#define                DOTLED_ROW_PORT                PORTC
#define                DOTLED_ROW_DDR                DDRC
#define                DOTLED_ROW_PIN                PINC
#define                DOTLED_ROW_A0                PC0
#define                DOTLED_ROW_A1                PC1
#define                DOTLED_ROW_A2                PC2
#define                DOTLED_ROW_A3                PC3
#define                DOTLED_ROW_E                PC4
uint8 font[] = {
/*--  调入了一幅图像:这是您新建的图像  --*/
/*--  宽度x高度=16x16  --*/
0x00,0x00,0x00,0x00,0x08,0x38,0x18,0x44,0x08,0x44,0x08,0x04,0x08,0x08,0x08,0x10,
0x08,0x20,0x08,0x40,0x08,0x40,0x08,0x40,0x3E,0x7C,0x00,0x00,0x00,0x00,0x00,0x00
static void TransmitByte(uint8 byte);
static void SelectRow(uint8 row);
static void FlipLatchLine(void);
        uint8 i;
        for(i = 0 ; i < 8 ; i ++)
                if(byte & (1 << i))
                        DOTLED_LINE_PORT |= _BV(DOTLED_LINE_SDA);
                else
                        DOTLED_LINE_PORT &= ~_BV(DOTLED_LINE_SDA);
                //__delay_cycles(100);
                DOTLED_LINE_PORT |= _BV(DOTLED_LINE_SCKH);
                DOTLED_LINE_PORT &= ~_BV(DOTLED_LINE_SCKH);
          //row -= 1;
        row |= DOTLED_ROW_PIN & 0xe0;
        DOTLED_ROW_PORT = row;
        DOTLED_LINE_PORT |= _BV(DOTLED_LINE_SCKT);
        DOTLED_LINE_PORT &= ~_BV(DOTLED_LINE_SCKT);
void InitDotLedPort(void)
        DOTLED_LINE_PORT &= ~(_BV(DOTLED_LINE_SCKT) | _BV(DOTLED_LINE_SCKH));
        DOTLED_LINE_DDR |= _BV(DOTLED_LINE_SCKT) | _BV(DOTLED_LINE_SCKH) | _BV(DOTLED_LINE_SDA);
        DOTLED_ROW_PORT |= 0x1f;
        DOTLED_ROW_PORT &= 0xf0;
        DOTLED_ROW_DDR |= 0x1f;
void EnableRow(boolean IsEnable)
        if(IsEnable)
                DOTLED_ROW_PORT &= ~_BV(DOTLED_ROW_E);
        else
                DOTLED_ROW_PORT |= _BV(DOTLED_ROW_E);
void PrintDotLed(uint8 * buffer)
        uint8 i , tmp;
        for(i = 0 ; i < 16 ; i ++)
                tmp = *buffer ++;
                TransmitByte(~tmp);
                tmp = *buffer ++;
                TransmitByte(~tmp);
                SelectRow(i);
                FlipLatchLine();
void main(void)
        InitDotLedPort();
        EnableRow(TRUE);
        while(1)
                PrintDotLed(font);
                __delay_cycles(5000);
config.h文件
#ifndef        _CONFIG_H
#define        _CONFIG_H
//#define                GCCAVR
#define                CPU_CYCLES        7372800L
#ifndef                GCCAVR
#define                _BV(bit)        (1 << (bit))
#endif
#define                MSB                0x80
#define                LSB                0x01
#define                FALSE                0
#define                TRUE                1
typedef                unsigned char        uint8;
typedef                unsigned int        uint16;
typedef                unsigned long        uint32;
typedef                unsigned char        boolean;
#include
#include
#include "dotled.h"
#endif
16 16点阵显示电路
点阵
  • 相关推荐
  • 热点推荐
  • 点阵
