新品快讯
DS1862A XFP激光器控制和数字诊断IC
DS1862A 概述
The DS1862A is a closed-loop laser-driver control IC with built-in digital diagnostics designed for XFP MSA. The laser control function incorporates automatic power control (APC) and allows extinction ratio control though a temperature-indexed lookup table (LUT). The DS1862A monitors up to seven analog inputs, including temperature and monitor diode (MD) current, which are used to regulate the laser bias current and extinction ratio. Warning and alarm thresholds can be programmed to generate an interrupt if monitored signals exceed tolerance. Calibration is also provided internally using independent gain and offset scaling registers for each of the monitored analog signals. Settings such as programmed calibration data are stored in password-protected EEPROM memory. Programming is accomplished through an I²C-compatible interface, which can also be used to access diagnostic functionality.
DS1862A 关键特性
DS1862A 应用/使用
| 光传输中的数字诊断 | |
| 激光器控制与监视 | |
| Laser Control and Monitoring 10Gbps Optical Transceiver Modules (XFP) |
