MAX5963 双通道、7.5V至76V、热插拔控制器和二极
新品快讯
29人已加入
MAX5963 双通道、7.5V至76V、热插拔控制器和二极管“或”逻辑控制器
概述
The MAX5963 dual hot-swap and diode ORing controller provides complete protection for dual-supply high availability systems. The device operates from 7.5V to 76V and provides hot-swap and low voltage-drop diode ORing functionality for two 7.5V to 76V outputs.
The MAX5963 allows for the safe insertion and removal of system line cards and FireWire® peripherals into a live backplane by providing inrush current control and active current limiting. The device controls external n-channel power MOSFETs to perform low-voltage-drop ORing, inrush current control, and current limiting functions. The current-limit function actively limits the current drawn by the load, protecting the load from a short-circuit condition. The MAX5963 also features a circuit-breaker function that disconnects the power to the load if the load current exceeds the circuit-breaker limit for a programmable circuit-breaker timeout.
The MAX5963 features an autoretry/latchoff input. In autoretry mode, the MAX5963 automatically restarts the turned-off channel after a programmable delay. In latchoff mode, the MAX5963 latches the channel off.
The MAX5963 consumes less than 10µA from the PWR supply in system power-off mode.
The MAX5963 is available in a 40-pin TQFN package (6mm x 6mm) and operates over the 0°C to +85°C upper commercial temperature range.
关键特性
  • Hot Swaps Two 7.5V to 76V Supplies
  • Integrates Low-Voltage-Drop ORing Controller
  • ±5% Accuracy Bilevel Active Current Limit/Circuit Breaker
  • Programmable Current-Limit/Circuit-Breaker Timeout
  • 10µA Power-Off Mode Current
  • Protects Up to Two FireWire Ports
  • System Power-On/Off ORing
  • Latchoff or Autoretry Power Management
  • Independent ON/OFF Control Allows Undervoltage Lockout Programming
  • Fast Load Disconnect through FOSO Input (FireWire Port)
  • 应用/使用
     基站线卡
     刀片式服务器
     FireWire台式机/笔记本电脑端口
     FireWire集线器
     网络交换机/路由器
    MAX5963 pdf datasheet
    • 相关推荐
    • 热点推荐
