MAX253 变压器驱动器,用于隔离型RS-485接口
新品快讯
29人已加入
MAX253 概述
The MAX253 is a monolithic oscillator/power-driver, specifically designed to provide isolated power for an isolated RS-485 or RS-232 data interface. It drives a center-tapped transformer primary from a 5V or 3.3V DC power supply. The secondary can be wound to provide any isolated voltage needed at power levels up to 1W.
The MAX253 consists of a CMOS oscillator driving a pair of N-channel power switches. The oscillator runs at double the output frequency, driving a toggle flip-flop to ensure 50% duty cycle to each of the switches. Internal delays are arranged to ensure break-before-make action between the two switches.
The SD pin puts the entire device into a low-power shutdown state, disabling both the power switches and oscillator.
MAX253 pdf datasheet
MAX253 关键特性
  • Power-Supply Transformer Driver for Isolated RS-485/RS-232 Data-Interface Applications
  • Single +5V or +3.3V Supply
  • Low-Current Shutdown Mode: 0.4µA
  • Pin-Selectable Frequency: 350kHz or 200kHz
  • 8-Pin DIP, SO, and µMAX Packages
    MAX253 应用/使用
     桥接地电位差
     高噪声抑制通信接口
     隔离型和/或高压电源
     隔离型RS-485/RS-232电源
     医疗装置
     过程控制
     变压器驱动器
    MAX253应用电路
  • 打开APP阅读更多精彩内容
    • 相关推荐
    • 热点推荐
