MAX15039 6A、2MHz、降压型调节器,内置开关
新品快讯
29人已加入
MAX15039 概述
The MAX15039 high-efficiency switching regulator delivers up to 6A load current at output voltages from 0.6V to 90% of VIN. The IC operates from 2.9V to 5.5V, making it ideal for on-board point-of-load and postregulation applications. Total output error is less than ±1% over load, line, and temperature ranges.
The MAX15039 features fixed-frequency PWM mode operation with a switching frequency range of 500kHz to 2MHz set by an external resistor. The MAX15039 provides the option of operating in a pulse-skip mode to improve light-load efficiency. High-frequency operation allows for an all-ceramic capacitor design. The high operating frequency also allows for small-size external components.
The low-resistance on-chip nMOS switches ensure high efficiency at heavy loads while minimizing critical inductances, making the layout a much simpler task with respect to discrete solutions. Following a simple layout and footprint ensures first-pass success in new designs.
The MAX15039 comes with a high bandwidth (28MHz) voltage-error amplifier. The voltage-mode control architecture and the voltage-error amplifier permit a type III compensation scheme to be utilized to achieve maximum loop bandwidth, up to 20% of the switching frequency. High loop bandwidth provides fast transient response, resulting in less required output capacitance and allowing for all-ceramic-capacitor designs.
The MAX15039 provides two three-state logic inputs to select one of nine preset output voltages. The preset output voltages allow customers to achieve ±1% output-voltage accuracy without using expensive 0.1% resistors. In addition, the output voltage can be set to any customer value by either using two external resistors at the feedback with a 0.6V internal reference or applying an external reference voltage to the REFIN input. The MAX15039 offers programmable soft-start time using one capacitor to reduce input inrush current.
MAX15039 关键特性
  • Internal 26mΩ RDS(ON) High-Side and 20mΩ RDS(ON) Low-Side MOSFETs
  • Continuous 6A Output Current Over Temperature
  • ±1% Output Accuracy Over Load, Line, and Temperature
  • Operates from 2.9V to 5.5V VIN Supply
  • Adjustable Output from 0.6V to (0.9 x VIN)
  • Soft-Start Reduces Inrush Supply Current
  • 500kHz to 2MHz Adjustable Switching Frequency
  • Compatible with Ceramic, Polymer, and Electrolytic Output Capacitors
  • Nine Preset and Adjustable Output Voltages
    • 0.6V, 0.7V, 0.8V, 1.0V, 1.2V, 1.5V, 1.8V, 2.0V, 2.5V, and Adjustable
  • Monotonic Startup for Safe-Start Into Prebiased Outputs
  • Selectable Forced PWM or Skip Mode for Light Load Efficiency
  • Overcurrent and Overtemperature Protection
  • Output Current Sink/Source Capable with Cycle-by-Cycle Protection
  • Open-Drain, Power-Good Output
  • Lead-Free, 4mm x 4mm, 24-Pin Thin QFN Package
  • MAX15039 pdf datasheet
    MAX15039 应用/使用
    ASIC/CPU/DSP核与I/O供电
     基站电源
     DDR电源
     POL
     RAID控制电源
     服务器电源
     电信与网络电源
    MAX15039应用电路
    • 相关推荐
    • 热点推荐
    • M
