MAX14527, MAX14528 高精度、可调节过压保护
新品快讯
30人已加入
MAX14527, MAX14528 高精度、可调节过压保护器
MAX14527, MAX14528 概述
The MAX14527/MAX14528 overvoltage protection devices feature a low 100mΩ (typ) RON internal FET and protect low-voltage systems against voltage faults up to +28V. When the input voltage exceeds the overvoltage threshold, the internal FET is turned off to prevent damage to the protected components.
The overvoltage protection threshold can be adjusted with optional external resistors to any voltage between 4V and 8V. With the OVLO input set below the external OVLO select voltage, the MAX14527/MAX14528 automatically choose the internal ±2.5% accurate trip thresholds. The internal overvoltage thresholds (OVLO) are preset to 5.75V typical (MAX14527) or 6.76V typical (MAX14528). The MAX14527/MAX14528 are also protected against overcurrent events with an internal thermal shutdown.
The MAX14527/MAX14528 are offered in a small, 8-pin TDFN-EP package and operate over the -40°C to +85°C extended temperature range.
MAX14527/MAX14528 pdf datasheet
MAX14527, MAX14528 关键特性
  • Input Voltage Protection Up to +28V
  • Preset Internal ±2.5% Accurate OVLO Thresholds
    • 5.75V (MAX14527)
    • 6.76V (MAX14528)
  • Adjustable Overvoltage Protection Trip Level
  • Integrated 100mΩ (typ) n-Channel MOSFET Switch
  • Soft-Start to Minimize In-Rush Current
  • Automatic Overvoltage Protection Trip-Level Selection
  • Internal 15ms Startup Delay
  • Thermal Shutdown Protection
  • 8-Pin TDFN (2mm x 2mm) Package
  • -40°C to +85°C Operating Temperature Range
  • MAX14527, MAX14528 应用/使用
    蜂窝电话
     媒体播放器
     PDA与掌上电脑设备
    MAX14527, MAX14528 应用电路
    MAX14528
