体验最新的 IDE
大家在使用集成开发工具IDE时,总觉得有些地方自己不习惯。最近IAR和Keil这俩工具都有一定程度的更新。下面由我来给大家讲讲都更新了些什么内容。
MDK-ARM
参看我之前分享的文章【Keil(MDK-ARM)介绍、下载、安装与注册】,可以到官网或网盘下载最新的软件安装包。
ARM
早在一个多月前,MDK-ARM V5.24就有预览版本推出。就在这6月30日推出了正式版本。如果你对新版本IDE有好奇心,不妨下载安装试试。
MDK-ARM官方更新说明地址(长按地址 -> 选择复制 -> 打开):
http://www.keil.com/update/relnotes/MDK524.htm
大概更新内容如下:
1.编译器[ARM Compiler]
The ARM Compiler 6.7.
The ARM Compiler 5.06u5.
2.软件包[Software Packs included]
ARM - CMSIS 5.0.1 (和MDK-V5.23一样)
Keil - MDK Middleware 7.4.1
-Updated the FileSystem Component to version 6.9.8.
-Updated the USB Component to version 6.11.0.
-Updated the Network Component to version 7.5.0.
Keil - ARM Compiler Extensions 1.3.1
-Updated SCVD examples to build without warnings for use with ARMCLANG compiler.
-Updated SCVD Event Recorder documentation.
3.uVision更新至V5.24.1.0
·Updated: Feature map of the MDK Editions are reflected by the product i.e.
·Added: Source Browse information is now available in project targets using ARM Compiler 6
·Improved: Source Browser window redesign for better usability for project targets using the ARM Compiler 6.
·Improved: Dynamic Syntax Checker for project targets using the ARM Compiler 6
·Added: ARM Compiler 6 warning level MISRA Compatible suppressing compiler warnings contradicting MISRA rules. Warning level Moderate Warnings got renamed to AC5-like Warnings.
·Improved: PC-Lint setup
·Extended: the ARM-Compiler version selection in Options for Target dialog adds the option to select the latest installed version of ARM Compiler 5 and ARM Compiler 6
·Improved: the MDK-ARM installer creates a backup of the TOOLS.ini file in case an existing installation folder is used
4.操作系统要求[Supported Operating Systems]
官网地址:
http://www2.keil.com/system-requirements
支持Windows Vista、Windows 7、Windows 8和Windows 10
不再支持Windows XP系统了.
EWSTM8
参看我之前分享的文章【IAR for STM8介绍、下载、安装与注册】,可以到官网或网盘下载最新的软件安装包。
ARM
EWSTM8官方更新说明地址(长按地址 -> 选择复制 -> 打开):
https://www.iar.com/iar-embedded-workbench/#!?currentTab=release-notes
ARM
升级内容如上截图,大致为:
1.更新IDE
全新的IDE界面,增强窗口管理和对接,可定制的工具栏。
2.C-STAT扩展功能
静态分析工具C-STAT延到了约150新的检查,包括90项新的MISRA-C。同时,有新的选项来启用或禁用的阶段分析和排除文件的分析。
3.增加对新设备的支持
增加新设备:STM8S001J3,ASTWBC5V,STWBC,STWBC-EP,STWBC-MC STWBC-WA。
4.更新用户文档
IDE项目管理和建设指导和C-SPY调试指南已经更新,以反映产品的变化。
在我前面分享的文章【IAR大升级,你们都使用了吗?】就有说,EWSTM8会有较大的升级改变(不妨点击链接进去看下界面的大改变)。
EWARM
参看我之前分享的文章【IAR for ARM介绍、下载、安装与注册】,可以到官网或网盘下载最新的软件安装包。
ARM
关于EWARM的文章,我汇总在底部菜单 -> 经典文章里面,感兴趣的朋友可以去查看。
