AME5258应用电路
IC应用电路图
512人已加入
The AME5258 is a high efficiency monolithic synchronous buck regulator using a constant frequency, current mode architecture. The device is available in an adjustable version and fixed output voltages of 1.2V, 1.8V, 2.5V and 3.3V. Supply current with no load is 300μA and drops to <1μA in shutdown. The 2.5V to 5.5V input voltage range makes the AME5258 ideally suited for single Li-Ion battery- powered applications. 100% duty cycle provides low dropout operation, extending battery life in portable systems. PWM pulse skipping mode operation provides very low output ripple voltage for noise sensitive applications. At very light load, the AME5258 will automatically skip pulses in pulse skip mode operation to maintain output regulation.
AME
Figure 1: High Efficiency Step-Down Conventer
Figure 2: 1.8V at 600mA Step-Down Requlator
AME5258 pdf datasheet
AME5258管脚图引脚图
AME
  • 相关推荐
  • 热点推荐
  • AME
