MAX9610 高精度电流检测放大器、1µA、µDFN/SC70封装、用于锂离子电池
MAX9610 概述
The MAX9610 high-side current-sense amplifier offers precision accuracy specifications of VOS less than 500µV (max) and gain error less than 0.5% (max). This device features an ultra-low 1µA quiescent supply current. The MAX9610 fits in a tiny, 1mm x 1.5mm µDFN package or a 5-pin SC70 package, making this part ideal for applications in notebook computers, cell phones, cameras, PDAs, and all lithium ion battery-operated portable devices where accuracy, low quiescent current, and small size are critical.
The MAX9610 features an input voltage range (common mode) from 1.6V to 5.5V. This input range is excellent for monitoring the current of a single-cell, lithium-ion battery (Li+), which at full charge is 4.2V, typically 3.6V in normal use, and less than 2.9V when ready to be recharged. These current-sense amplifiers have a voltage output and are offered in three gain versions: 25V/V (MAX9610T), 50V/V (MAX9610F), and 100V/V (MAX9610H).
The three gain versions offer flexibility in the choice of the external current-sense resistor. The very low 500µV (max) input offset voltage allows small 25mV to 50mV full-scale VSENSE voltage for very low voltage drop at full-load current measurement.
The MAX9610 is offered in tiny 6-pin µDFN, (1mm x 1.5mm x 0.8mm footprint) and 5-pin SC70 packages, specified for operation over the -40°C to +85°C temperature range.
For a very similar 1.6V to 28V input voltage device in a 4-bump UCSP™ package (1mm x 1mm x 0.6mm), refer to the MAX9938 data sheet.
MAX9610 关键特性
Ultra-Low Supply Current of 1µA (max)
Low 500µV (max) Input Offset Voltage
Low < 0.5% (max) Gain Error
Input Common Mode: +1.6V to +5.5V
Voltage Output
Three Gain Versions Available
- 25V/V (MAX9610T)
- 50V/V (MAX9610F)
- 100V/V (MAX9610H)
Tiny µDFN (1mm x 1.5mm x 0.8mm) and SC70 Packages
MAX9610 应用
3.3V和5V电源管理系统
照相机
蜂窝电话
PDA
便携式Li+电池供电系统
USB端口
MAX9610应用电路 |
