消防泵标准大全
工艺综述
27人已加入
消防泵标准大全
标准编号
标准中文名称
标准英文名称
GB6245-1998
消防泵性能要求和试验方法
Performance requirements and test methods for fire pumps
JB/T10378-2002
固定式消防泵
NF S63-125-2-2002
消防泵.带起动注油器的消防离心泵.第2部分:总则和安全要求的检定
(Fire-fighting pumps - Fire-fighting centrifugal pumps with primer - Part 2 : verification of general and safety requirements.)
NF S63-125-1-2002
消防泵.带起动注油器的消防离心泵.第1部分:分类.总则和安全要求
(Fire-fighting pumps - Fire-fighting centrifugal pumps with primer - Part 1 : classification - General and safety requirements.)
ANSI/NFPA 20-2003
离心消防泵的安装
(Installation of Centrifugal Fire Pumps )
ANSI/UL 218-2002
消防泵控制器的安全标准
(Standard for Safety for Fire Pump Controllers )
ANSI/UL 218A-1994
柴油发动机带动的离心消防泵的蓄电池接触器
(Battery Contactors for Use in Diesel Engines Driving Centrifugal Fire Pumps)
BS DD IEC TS 62091-2003
低压开关设备和控制设备.固定式消防泵驱动器用控制器
(Low-voltage switchgear and controlgear - Controllers for drivers of stationary fire pumps)
BS EN 1028-2-2002
消防泵.带primer消防离心泵.一般验证和安全要求
(Fire-fighting pumps - Fire-fighting centrifugal pumps with primer - Verification of general and safety requirements)
BS EN 1947-2002
消防软水管.消防泵和车用半刚性输送软水管和水管配件
(Fire-fighting hoses - Semi-rigid delivery hoses and hose assemblies for pumps and vehicles)
BS EN 1028-1-2002
消防泵.起动注油消防离心泵.分类.总则和安全要求
(Fire-fighting pumps - Fire-fighting centrifugal pumps with primer - Classification - General and safety requirements)
prEN 14466-2002
消防泵 便携泵 试验、性能要求和安全
Fire fighting pumps - Portable pumps - Safety and performance requirements, tests
EN 1028-1-2002
消防泵 带起动器的消防离心泵第1部分:分类 一般和安全要求
Fire-fighting pumps - Fire-fighting centrifugal pumps with primer - Part 1: Classification; General and safety requirements
EN 1028-2-2002
消防泵 带起动器的消防离心泵第2部分:一般和安全要求的验证
Fire-fighting pumps - Fire-fighting centrifugal pumps with primer - Part 2: Verification of general and safety requirements
DIN 14421-2001
消防泵用压力计(测压计)
(Pressure gauges (manometer) for fire pumps)
DIN 14420-2002
消防泵.消防离心泵.在消防车中安装后的边缘吸力和边缘压力集合试验
(Fire-fighting pumps - Fire-fighting centrifugal pumps - Requirements for the suction-sided and pressure-sided assembly, test after installation in the fire-fighting vehicle)
DIN EN 1028-2-2002
(Fire-fighting pumps - Fire-fighting centrifugal pumps with primer - Part 2: Verification of general and safety requirements; German version EN 1028-2:2002)
DIN EN 1028-1-2002
消防泵.带起动注油器的消防离心泵.第1部分:分类、总则和安全要求
(Fire-fighting pumps - Fire-fighting centrifugal pumps with primer - Part 1: Classification; General and safety requirements; German version EN 1028-1:2002)
UL 1478-1995
消防泵减压阀
(Fire pumps relief valves )
UL 1004A-2001
消防泵电动机
(Fire pump motors )
IEC/TS 62091-2003
低压开关设备和控制设备.固定式消防泵的驱动器用控制器
  • 相关推荐
  • 热点推荐
