MAX4493, MAX4494, MAX4495 满摆幅运
新品快讯
29人已加入
MAX4493, MAX4494, MAX4495 运算放大器、单/双/四通道、双电源供电、SC70封装
MAX4493, MAX4494, MAX4495 概述
The MAX4493/MAX4494/MAX4495 single/dual/quad general-purpose operational amplifiers are designed for use in systems powered with dual supplies from ±2.25V to ±5.5V. These op amps provide a unity-gain bandwidth of 5MHz with only 770µA of quiescent current per amplifier. The wide input common-mode range extends from 200mV beyond the negative rail to within 1.5V of the positive supply rail while the output swings within 10mV (RL = 100kΩ) of either rail.
These amplifiers have excellent (110dB) open-loop gain with very low THD+N of 0.002% (f = 1kHz). The single MAX4493 is available in a tiny 5-pin SC70 package and the dual MAX4494 is available in the space-saving 8-pin SOT23. The quad MAX4495 is available in both 14-pin TSSOP and 14-pin SO packages. All products are rated at the automotive temperature range of -40°C to +125°C.
MAX4493, MAX4494, MAX4495 关键特性
  • 770µA Supply Current per Amplifier
  • Operates from Dual ±2.25V to ±5.5V Supplies
  • 5MHz Gain-Bandwidth Product
  • Rail-to-Rail Output Swing
  • Input Voltage Range Extends 200mV Below the Negative Rail
  • 110dB Open-Loop Gain (RL = 100kΩ)
  • Low THD+N of 0.002% (f = 1kHz)
  • No Phase Reversal for Overdriven Inputs
  • Unity-Gain Stable
  • Available in Space-Saving Packages
    • 5-Pin SC70 (MAX4493)
    • 8-Pin SOT23 (MAX4494)
    • 14-Pin TSSOP (MAX4495)
MAX4493, MAX4494, MAX4495 应用/使用
 电池供电应用
 DAC输出放大器
 工业控制系统
 信号调理
 电压基准发生器
MAX4493, MAX4494, MAX4495 pdf datasheet
MAX4493, MAX4494, MAX4495应用电路
  • 相关推荐
  • 热点推荐
