MAX6576, MAX6577 SSOT23封装的单总线数
新品快讯
30人已加入
MAX6576, MAX6577 SSOT23封装的单总线数字温度传感器
MAX6576, MAX6577概述
The MAX6576/MAX6577 are low-cost, low-current temperature sensors with a single-wire output. The MAX6576 converts the ambient temperature into a square wave with a period proportional to absolute temperature (°K). The MAX6577 converts the ambient temperature into a square wave with a frequency proportional to absolute temperature. The MAX6576 offers accuracy of ±3°C at +25°C, ±4.5°C at +85°C, and ±5°C at +125°C. The MAX6577 offers accuracy of ±3°C at +25°C, ±3.5°C at +85°C, and ±4.5°C at +125°C.
Both devices feature a single-wire output that minimizes the number of pins necessary to interface with a microprocessor. The period/frequency range of the output square wave can be selected by hard-wiring the two time-select pins (TS0, TS1) to either VDD or GND. The MAX6576/MAX6577 are available in space-saving 6-pin SOT23 packages.
MAX6576, MAX6577 pdf datasheet
MAX6576, MAX6577关键特性
  • Simple Single-Wire Output
  • Two Output Types Available
    • Temperature to Period (µs) (MAX6576)
    • Temperature to Frequency (Hz) (MAX6577)
  • ±0.8°C Accuracy at +25°C (±3°C max)
  • No External Components
  • Operates from +2.7V to +5.5V Supply Voltage
  • Low 140µA Typical Supply Current
  • Standard Operating Temperature Range: -40°C to +125°C
  • Small 6-Pin SOT23 Package
    MAX6576, MAX6577应用/使用
     汽车电子
     电池组
     蜂窝电话
     精确的µP与µC监视
     硬盘驱动/磁带驱动器
     医疗装置
     网络与电信设备
     便携式电池供电设备
    MAX6576, MAX6577应用电路
    MAX6316
    典型工作电路
  • 打开APP阅读更多精彩内容
    • 相关推荐
    • 热点推荐
    • MAX6316
