MAX6629, MAX6630, MAX6631, MAX
新品快讯
30人已加入
MAX6629, MAX6630, MAX6631, MAX6632 12位 + 符号位数字温度传感器,串行接口
MAX6629, MAX6630, MAX6631, MAX6632概述
The MAX6629-MAX6632 are local digital temperature sensors with an SPI™-compatible serial interface. The temperature is converted to a 12-bit + sign word with a resolution of 0.0625°C/LSB. An extended temperature range provides useful readings up to +150°C.
These sensors are 3-wire serial interface SPI compatible, allowing the MAX6629-MAX6632 to be readily connected to a variety of microcontrollers (µCs). The MAX6629-MAX6632 are read-only devices, simplifying their use in systems where only temperature data is required.
All four digital temperature sensors require very little supply current, making them ideal for portable systems. The MAX6631/MAX6632 perform a temperature-to-digital conversion once every 8s and require minimal average supply current, 32µA (typ). The MAX6629/ MAX6630 perform a conversion once every 0.5s and require only 200µA (typ) supply current. Any of these temperature sensors can perform conversions more often—up to approximately four conversions per second by reading the conversion results more often.
MAX6629, MAX6630, MAX6631, MAX6632 pdf datasheet
MAX6629, MAX6630, MAX6631, MAX6632关键特性
  • Low Power Consumption
    • 32µA typ (MAX6631/MAX6632)
    • 200µA typ (MAX6629/MAX6630)
  • 12-Bit + Sign Resolution with 0.0625°C/LSB
  • Accuracy
    • ±1°C (max) from 0°C to +70°C
    • ±2.3°C (max) from -20°C to +100°C
    • ±3.2°C (max) from -40°C to +125°C
    • ±6.5°C (max) at +150°C
  • +150°C Extended Temperature Range
  • SPI-Compatible Serial Interface
  • +3.0V to +5.5V Supply Range
  • 6-Pin SOT23 Package
    MAX6629, MAX6630, MAX6631, MAX6632应用/使用
     汽车
     蜂窝设备
     硬盘驱动器
     HVAC
     工业控制系统
    MAX6629, MAX6630, MAX6631, MAX6632应用电路
    MAX6316
    典型应用电路
  • 打开APP阅读更多精彩内容
    • 相关推荐
    • 热点推荐
    • MAX6316
