MAX4473 低成本、低电压、PA功率控制放大器,用于GS
新品快讯
29人已加入
MAX4473 低成本、低电压、PA功率控制放大器,用于GSM应用
MAX4473 概述
The MAX4473 PA power control IC is intended for closed-loop bias control of GSM power amplifiers. The device facilitates accurate control of the current delivered to the power amplifier (PA) through a control voltage. The error amplifier senses the voltage drop across an external current-sense resistor placed between the supply and the PA. The output of the error amplifier adjusts the PA gain until the current is proportional to the power control voltage applied to the MAX4473. This unique topology is useful in time-division-multiple-access (TDMA) systems, such as GSM, where accurate transmit burst shaping and power control is required. User-selectable current sensing and gain setting resistors maximize flexibility.
The MAX4473 operates from a single 2.7V to 6.5V supply and typically draws 1.2mA of supply current. The error amplifier has a common-mode range that extends from 1V to VCC. The power control input and error amplifier outputs swing rail-to-rail. A low-power shutdown mode reduces supply current to less than 1µA and activates an on-board active pull-down at the error amplifier output. Fast enable/disable times of 0.9µs reduce average power consumption without compromising dynamic performance. The MAX4473 is available in a space-saving 8-pin µMAX® package.
MAX4473 pdf datasheet (PA Power Control)
MAX4473 关键特性
  • Optimized for GSM Timing Requirements
  • 2.7V to 6.5V Single-Supply Operation
  • 1.2mA Supply Current
  • <1µA Supply Current in Shutdown Mode
  • Guaranteed 1.5µs Enable/Disable Times
  • Active Output Pull-Down in Shutdown Mode
  • Rail-to-Rail Error Amplifier Output
  • Rail-to-Rail Power Control Input
  • Output Drive Capability–500Ω and 300pF Loads
  • 1V to VCC Current Sense Input Common-Mode Voltage Range
  • No Phase-Reversal for Common-Mode Voltage from 0 to VCC
  • External Current Sensing and Gain Setting Resistors Maximize Flexibility
  • Available in a Space-Saving 8-Pin µMAX Package
    MAX4473 应用/使用
     无绳电话
     GSM蜂窝电话
     高频伺服环路
     精密电流控制
    典型工作电路
  • 打开APP阅读更多精彩内容
    • 相关推荐
    • 热点推荐
