MAX3542 Complete Single-Conver
新品快讯
30人已加入
MAX3542 Complete Single-Conversion Television Tuner
Description
The MAX3542 complete single-conversion television tuner is designed for use in analog/digital terrestrial applications and digital set-top boxes. This television tuner draws only 760mW of power from a +3.3V supply voltage.
The MAX3542 is designed to convert PAL or DVB-T signals in the 47MHz to 862MHz band to an intermediate frequency (IF) of 36MHz.
The MAX3542 includes a variable-gain low-noise amplifier (LNA), multiband tracking filters, a harmonic-rejection mixer, a low-noise IF amplifier, an IF power detector, and a variable-gain IF amplifier. The MAX3542 also includes fully monolithic VCOs and tank circuits, as well as a complete frequency synthesizer. This highly integrated design allows for low-power tuner-on-board applications without the cost and power dissipation issues of dual-conversion tuner solutions.
The MAX3542 is specified for operation in the 0°C to +70°C temperature range and is available in a lead-free 48-pin flip-chip (fcLGA) package.
Key Features
  • Low Power Consumption: 760mW (typ) from a +3.3V Supply Voltage
  • Integrated Tracking Filters
  • Low Noise Figure: 4.9dB (typ)
  • Small 7mm x 7mm fcLGA Lead-Free Package
  • IF Overload Detector Controls RF Variable-Gain Amplifier
  • 2-Wire, I²C-Compatible Serial Control Interface
  • Applications/Uses
    Analog/Digital Terrestrial Receivers
     Digital Set-Top Boxes
     Televisions
    • 相关推荐
    • 热点推荐
    • t
