- The MAX17019 is a high-input-voltage, quad-output controller for automotive applications.
- This device saves space and cost by integrating four output-voltage regulators in a small, 6mm x 6mm, 48-pin TQFN package.
- The step-down regulators use a peak-current-mode, fixed-frequency control scheme to ease implementation without sacrificing transient response.
- Capable of operating up to 38V, the MAX17019 is ideal for automotive battery-powered devices.
- MAX17019 pdf,MAX17019 datasheet
Quad-Output Controller with High-Input Voltage for Automotive Applications
SUNNYVALE, CA—January 5, 2009—Maxim Integrated Products (NASDAQ: MXIM) introduces the
MAX17019, a high-input-voltage, quad-output controller for automotive applications. This device saves space and cost by integrating four independent voltage outputs in a small, 36mm² TQFN package. The device includes a main-stage step-down controller, a 3A
P-P step-down regulator, a 5A
P-P step-down regulator, and a 2A source/sink linear regulator. Capable of operating up to 38V, the MAX17019 is ideal for automotive battery-powered devices.
The step-down converters use a peak-current-mode, fixed-frequency control scheme to provide an easy-to-implement architecture that does not sacrifice transient response. This architecture also supports peak-current-limit protection and pulse-skipping operation to maintain high efficiency under light-load conditions.
The MAX17019 is available in a space-saving, 6mm x 6mm, 48-pin TQFN package, and is fully specified over the -40°C to +125°C automotive temperature range. Prices start at $5.50 (1000-up, FOB USA).
