MAX2172 Direct-Conversion to L
新品快讯
29人已加入
MAX2172 Direct-Conversion to Low-IF Tuner for Digital Audio Broadcast
The MAX2172 direct-conversion to low-IF tuner is designed for digital audio broadcast (DAB) and terrestrial digital multimedia broadcast (T-DMB) applications, covering an input frequency range of 168MHz to 240MHz (VHF-III), 1452MHz to 1492MHz (L-band), and also 87MHz to 108MHz (FM). The MAX2172 achieves a high level of component integration, allowing lowpower, tuner-on-board designs. The direct-conversion to low-IF architecture eliminates the need for an IF-SAW filter while providing a balanced 2.048MHz center frequency baseband output to the demodulator.
The MAX2172 provides a buffered reference clock at the crystal frequency.
A sigma-delta fractional-N synthesizer is incorporated to optimize both close-in and wideband phase noise performances for OFDM applications where sensitivity to both 1kHz phase noise and wideband phase noise related to strong adjacents can be a problem.
The MAX2172 is available in a 40-pin thin QFN package (6mm x 6mm) with an exposed pad. Electrical performance is guaranteed over the extended -40°C to +85°C temperature range.
  • +2.7V to +3.5V Supply Voltage Range
  • Low-IF Output Eliminates IF-Saw Filter
  • Integrated FM/VHF-III Bandpass Filter
  • Integrated Low-IF Bandpass Filter
  • Sigma-Delta Fractional-N Synthesizer
  • +45dBc ACPR (N±1)
  • 2.9dB Typical Noise Figure for VHF-III (Includes On-Chip Tracking Filter)
  • 3.1dB Typical Noise Figure for L-Band
  • VHF-III Sensitivity of -101dBm
  • L-Band Sensitivity of -101dBm
  • Baseband Overload Detector Controls RF AGC
  • Fast Channel Scan RSSI 5-Bit Output
  • FM (S+N)/N = 26dB at -111dBm
  • Small 6mm x 6mm Thin QFN Package
    Applications/Uses
    Fixed and Mobile Digital Audio Broadcast (DAB, DAB+) with FM
    Terrestrial Digital Multimedia Broadcast (T-DMB) with FM
    Functional Diagram
  • 打开APP阅读更多精彩内容
    • 相关推荐
    • 热点推荐
