PIC:读写24LCxx系列的EEPROM的实例C语言程序
控制/MCU
1920人已加入
//*            Using I2C Master Mode for access Slave (EEPRM)
//* Written by:  Richard Yang
//*              Sr. Corporate Application Engineer
//*              Microchip Technology Inc.
//* Date:        Oct. 3nd '2002
//* Revision: 1.00
//* Language tools : MPLAB-C18 v2.09.13
//*      MPLINK v3.10
//*      MPLAB-IDE v6.00.17 & ICD2
/* Include Header files  */
#i nclude
#i nclude    // Load I2C Header file from defult direct
#i nclude
#i nclude "P18LCD.h"   // Load P18LCD Header file form current working direct
/* Declare the Function Prototype */
void Initialize_I2C_Master(void);
void EE_Page_Write(unsigned char,unsigned char,unsigned char,unsigned char *);
void EE_SEQU_Read(unsigned char,unsigned char,unsigned char,unsigned char *);
void EEPROM_Write(unsigned char,unsigned char,unsigned char);
void EEPROM_ACK(unsigned char);
unsigned char EEPROM_Read(unsigned char,unsigned char);
void I2C_Done(void);
void Initialize_Timer2(void);
void isr_high_direct(void);
void isr_high(void);
#pragma romdata My_romdata=0x1000
const rom far unsigned char LCD_MSG1[]="SW2: Byte Write ";
const rom far unsigned char LCD_MSG2[]="SW6: Random Read";
const rom far unsigned char LCD_MSG3[]="Byte Write Mode ";
const rom far unsigned char LCD_MSG4[]="Random Read Mode";
const rom far unsigned char LCD_MSG5[]="Sended:         ";
const rom far unsigned char LCD_MSG6[]="Send:           ";
const rom unsigned char I2C_Write_Buffer[]="Microchip Technology";
#pragma romdata
/* Define following array in data memory */
unsigned char I2C_Read_Buffer [32];
/* define following variable in data memory at Access Bank */
#pragma udata access My_RAM
near unsigned char Debounce;
near unsigned char Send_Addr;
near unsigned char Send_Data;
near unsigned char Send_Length;
near unsigned char Read_Data;
near unsigned char P_SW2;
near unsigned char P_SW6;
#pragma udata
#define Page_Length 8
#define SW2  PORTAbits.RA4
#define SW6  PORTEbits.RE1
#define Bounce_Time 6
#define EE_CMD 0xA0
/*       Main  Program        */
void main(void)
 ADCON1=0b00000110;  // Disable A/D Function
 TRISAbits.TRISA4=1;  // Set SW2 for input
 TRISEbits.TRISE1=1;  // Set SW6 for Input
 Initialize_Timer2( );
 Initialize_I2C_Master( );
 OpenLCD( );
 if (SW2 & SW6)Debounce=0;
 else Debounce = Bounce_Time;
 while(1)
  LCD_Set_Cursor(0,0);    // Put LCD Cursor on (0,0)
  putrsLCD(LCD_MSG1);
  LCD_Set_Cursor(1,0);    // Put LCD Cursor on (1,0)
  putrsLCD(LCD_MSG2);
  P_SW2=P_SW6=0;
  Send_Addr=0;
  while(1)
   if (P_SW2)
    P_SW2=0;
    putrsLCD(LCD_MSG3);
    LCD_Set_Cursor(1,0);    // Put LCD Cursor on (0,0)
    putrsLCD(LCD_MSG5);
    do
     while (!P_SW2);
     P_SW2=0;
     LCD_Set_Cursor(1,8);
     Send_Data=I2C_Write_Buffer[Send_Addr];
     EEPROM_Write(EE_CMD,Send_Addr,Send_Data);
     puthexLCD(EE_CMD);
     putcLCD(' ');
     puthexLCD(Send_Addr);
     putcLCD(' ');
     puthexLCD(Send_Data);
     EEPROM_ACK(EE_CMD);
     Send_Addr++;
    } while (I2C_Write_Buffer[Send_Addr]!=0x00);
   break;
   if (P_SW6)
    P_SW6=0;
    putrsLCD(LCD_MSG4);
    putrsLCD(LCD_MSG6);
    while(1)
     if (P_SW6)
     P_SW6=0;
     LCD_Set_Cursor(1,5);
     Read_Data = EEPROM_Read(EE_CMD,Send_Addr);
     puthexLCD(EE_CMD);
     putcLCD(' ');
     putcLCD(' ');
     puthexLCD(EE_CMD);
     putcLCD(' ');
     puthexLCD(Read_Data);
     Send_Addr++;
     if (P_SW2) break;
    if (P_SW2) break;
   if (P_SW2)
    P_SW2=0;
     break;
//*       #pragma Interrupt Declarations         *
//* Function: isr_high_direct                    *
//*   - Direct execution to the actual           *
//*     high-priority interrupt code.            *
#pragma code isrhighcode = 0x0008
     _asm      //begin in-line assembly
     goto isr_high   //go to isr_high function
     _endasm     //end in-line assembly
#pragma code
//* Function: isr_high(void)                     *
//*   High priority interrupt for Timer2         *
#pragma interrupt isr_high
void isr_high(void)
 PIR1bits.TMR2IF=0;     // Clear Timer2 interrupt Flag
 if (Debounce==0)
  if (!SW2)
  { P_SW2=1; Debounce =Bounce_Time; }
  if (!SW6)
  { P_SW6=1; Debounce =Bounce_Time; }
 else if (SW2 & SW6)Debounce--;
   else Debounce =Bounce_Time;
#pragma code
//*         Write a Byte to EEPROM
//*   - ctrl : Control Byte of EEPROM
//*   - addr : Location of EEPROM
//*   - data : Data Byte of EEPROM
  RCONbits.IPEN=1;   // Enable Interrupt Priority bit
  IPR1bits.TMR2IP=1;   // Set Timer2 for High Priority
  INTCONbits.GIEH=1;   // Enable High Priority Interrupt
  OpenTimer2 (TIMER_INT_ON  // Turn On the Timer2 with Interrupt
       & T2_PS_1_4   // (4Mhz/4) [4*10*(99+1)] = 4mS */
       & T2_POST_1_10);
  PR2 = 99;
//*         Write a Byte to EEPROM              *
//*   - ctrl : Control Byte of EEPROM   *
//*   - addr : Location of EEPROM   *
//*   - data : Data Byte of EEPROM    *
void EEPROM_Write(unsigned char ctrl,unsigned char addr,unsigned char data)
 IdleI2C();                // ensure module is idle
   StartI2C();      // Start condition
 I2C_Done();      // Wait Start condition completed and clear SSPIF flag
 WriteI2C(ctrl);     // Write Control+Write to EEPROM & Check BF flag
 while(SSPCON2bits.ACKSTAT);  // wait until received the Acknowledge from EEPROM
 I2C_Done();      // Clear SSPIF flag
 WriteI2C(addr);     // Write Address to EEPROM
 I2C_Done();
 WriteI2C(data);     // Write Data to EEPROM
 I2C_Done();
 StopI2C();      // Stop condition
 I2C_Done();      // Wait the Stop condition completed
//*         Pae Write to EEPROM
//*   - length : Write counter
//*   - *dptr : RAM point --> EEPROM
void EE_Page_Write(unsigned char ctrl,unsigned char addr,unsigned char length,unsigned char *dptr)
 I2C_Done();
 while (length!=0)    // Check write completed ?
  WriteI2C(*dptr);   // Write data to EEPROM
  I2C_Done();
  dptr++;      // Point to next byte
  length--;
//*         EEPROM Acknowledge Polling          *
//*   --  The routine will polling the ACK  *
//*       response from EEPROM       *
//*   --  ACK=0 return        *
//*   --  ACK=1 send Restart & loop check  *
void EEPROM_ACK(unsigned char ctrl)
 unsigned char i;
 WriteI2C(ctrl);     // Write Control to EEPROM (WRITE)
 while (SSPCON2bits.ACKSTAT)  // test for Acknowledge from EEPROM
  for (i=0;i<100;i++);  // Delay for next Repet-Start
       RestartI2C();               // initiate Repet-Start condition
  I2C_Done();          // Wait Repet-Start condition completed
 StopI2C();                      // send STOP condition
 I2C_Done();      // wait until stop condition is over
//*    Random Read a Byte from EEPROM           *
//*   - ctrl : Control Byte of EEPROM (Write) *
//*     (Ctrl +1 ) : Read Command    *
//*   - addr : Address Byte of EEPROM   *
//*   - Return : Read Data from EEPROM   *
unsigned char EEPROM_Read(unsigned char ctrl,unsigned char addr)
 unsigned char f;
    while(SSPCON2bits.ACKSTAT);    // test for ACK condition, if received
    RestartI2C();                // initiate Restart condition
 I2C_Done();
 WriteI2C(ctrl+1);    // Write Control to EEPROM
 f=ReadI2C();     // Enable I2C Receiver & wait BF=1 until received data
 NotAckI2C();     // Genarate Non_Acknowledge to EEPROM
 I2C_Done();
 return(f);      // Return Data from EEPROM
//*         Sequential Read from EEPROM
//*   - length : Read counter
//*   - *dptr : Store EEPROM data to RAM
void EE_SEQU_Read(unsigned char ctrl,unsigned char addr,unsigned char length,unsigned char *dptr)
 I2C_Done();
 while(SSPCON2bits.ACKSTAT);    // Test for ACK condition, if received
 while (length!=0)
  *dptr=ReadI2C();   // Enable I2C Receiver & Store EEPROM data to Point buffer
  I2C_Done();
  dptr++;
  length--;
  if (length==0) NotAckI2C();
  else AckI2C();    // Continue read next data, send a acknowledge to EEPROM
  I2C_Done();
//*   Check I2C action that is completed        *
void I2C_Done(void)
 while (!PIR1bits.SSPIF);  // Completed the action when the SSPIF is Hi.
 PIR1bits.SSPIF=0;      // Clear SSPIF
//* Initial I2C Master Mode with 7 bits Address  *
//* Clock Speed : 100KHz @4MHz      *
 OpenI2C(MASTER,SLEW_ON);
 SSPADD= 9;
  • 相关推荐
  • 热点推荐
  • EEPROM
