PIC单片机的BCD码加法程序
嵌入式设计应用
134人已加入
PIC单片机的BCD码加法程序
;*******************  Unsigned BCD Addition   ***************
;       This routine performs a 2 Digit Unsigned BCD Addition
; It is assumed that the two BCD numbers to be added are in
; locations Num_1 & Num_2. The result is the sum of Num_1+Num_2
; and is stored in location Num_2 and the overflow carry is returned
; in location Num_1
;   Performance :
;               Program Memory  :       25
;               Clock Cycles    :       17   ( worst case )
Num_1   equ     8       ; Overflow flow carry overwrites Num_1
result  equ     8
Num_2   equ     9       ; Num_2 + Num_1 overwrites Num_2
O_flow  equ     9
 include         "picreg.h"
BCDAdd  movf    Num_1,W
 clrf    Num_1           ;clear num_1
 addwf   Num_2,1         ; do binary addition
 btfsc   STATUS,C        ;< 256 then skip
 goto    inc_n1n2        ;else inc all
 movlw   66              ;add 66
 addwf   Num_2,1         ;/
 btfss   STATUS,DC       ;half carry?
 goto    sub_06          ;no then subtract
 btfss   STATUS,C        ;full carry?
 goto    sub_60          ;yes then subtract
inc_n1  incf    Num_1,1         ;inc it
 retlw   0               ;clr w
sub_06  btfss   STATUS,C        ;full carry
 goto    sub_66          ;yes subtract 66
 movlw   6               ;else subtract 6
 goto    sub_com         ;do common
sub_66  movlw   66
sub_com subwf   Num_2,1
 retlw   0
sub_60  movlw   60
 goto    sub_com
inc_n1n2
 movlw   66
 addwf   Num_2,1
 goto    inc_n1
;               Test Program
main    movlw   99
 movwf   Num_1      ; Set Num_1 = 99 ( max BCD digit )
 movlw   99
 movwf   Num_2      ; Set Num_2 = 99
 call    BCDAdd     ; After addition, Num_2 = 98
;                          ;  and Num_1 = 01 ( 99+99 = 198 -> max number )
self    goto    self
 org     1FF
 goto    main
 END
  • 相关推荐
  • 热点推荐
  • BCD
