PIC单片机的IIC接口程序
嵌入式设计应用
134人已加入
PIC单片机的IIC接口程序
InitI2CBusMaster
TxmtStartBit
   bsf    Bus_Busy                       ; on a start condition bus is busy
   bsf    STATUS, RP0                    ; Select page 1
   bsf    _SDA                           ; set SDA high
   bsf    _SCL                           ; clock is high
   call   Delay40uSec                    ; This is necessary for setup time
   bcf    _SDA                           ; This gives a falling edge on SDA while clock is high
   call   Delay47uSec                    ; Necessary for START HOLD time
   return
TxmtStopBit
   bcf    _SCL                           ; clock is low
   bcf    _SDA                           ; set SDA low
   bsf    _SCL                           ; clock is pulled up
   call   Delay40uSec                    ; Setup time for STOP condition
   bsf    _SDA                           ; rising edge on SDA while CLOCK is high
   call   Delay47uSec                    ; makes sure a START isn't sent immediately after a STOP
   bcf    Bus_Busy                       ; The bus isn't busy anymore
   return
AbortI2C
   call   TxmtStopBit                    ; Send a stop bit
   bsf    Abort                          ; set the abort bit
   return
TxmtSlaveAddr
   movf   SlaveAddr, w                   ; Move slave address to W
   bcf    ACK_Error                      ; reset Acknowledge error bit
   movwf  I2CData                        ; move W to I2C Data
   bcf    I2CData, LSB                   ; Set for write
   btfsc  Slave_RW                       ; If skip then write operation
   bsf    I2CData, LSB                   ; Clear for read
   call   SendData                       ; send the address
   btfss  Txmt_Success                   ; skip if successful
   goto   AddrSendFail                   ; Oops, we failed
   retlw  TRUE                           ; return true
AddrSendFail
   btfss  ACK_Error                      ; was there an error acknowledging
   retlw  FALSE                          ; No, so return 0
   call   TxmtStopBit                    ; Address not acknowleged, so send STOP bit
   retlw  FALSE                          ; Unsuccessful, so return 0
SendData
 ; We might should make a copy of the data here, the example does but I don't see why!!!
   bsf    Txmt_Progress                  ; We are in the middle of transmitting
   bcf    Txmt_Success                   ; reset success bit
   movlw  0x08
   movwf  I2CBitCount                    ; Set I2C Bit Count to 8
TxmtNextBit:
   bcf    _SCL                           ; Set clock Low
   rlf    I2CData, F                     ; MSB First, Note that I2CData is Destroyed
   bcf    _SDA                           ; Set clock based on what the MSB is
   btfsc  STATUS,C                       ; Was the MSB a 1
   bsf    _SDA                           ; Nope set it high
   call   Delay47uSec                    ; guarantee min LOW TIME tLOW & Setup time
   bsf    _SCL                           ; set clock high
   call   Delay40uSec                    ; guarantee min HIGH TIME tHIGH
   decfsz I2CBitCount, F                 ; are we done yet
   goto   TxmtNextBit                    ; nope, send the next bit
; Check For Acknowledge
   bcf    _SCL                           ; reset clock
   bsf    _SDA                           ; Release SDA line for Slave to pull down
   bsf    _SCL                           ; clock for slave to ACK
   bcf    STATUS, RP0                    ; Select PAGE 0 to test SDA pin
   btfsc  SdaPin                         ; SDA should be pulled low by slave if OK
   goto   TxmtErrorAck                   ; Uh oh, slave isn't behaving (or isn't there)
   bsf    STATUS, RP0                    ; Select PAGE 1
   bcf    Txmt_Progress                  ; reset progress bit in Bus Status
   bsf    Txmt_Success                   ; Transmission successful
   bcf    ACK_Error                      ; ACK OK
   return
TxmtErrorAck
   bsf    STATUS,RP0                     ; select page 1
   bsf    _SDA                           ; tristate SDA
   bsf    _SCL                           ; tristate SCL
   bcf    Txmt_Success                   ; Transmission NOT successful
   bsf    ACK_Error                      ; No ACK From Slave
   return
GetData
   bsf    Rcv_Progress                   ; set Bus status for txmt progress
   bcf    Rcv_Success                    ; reset status bit
   movlw  0x08
   movwf  I2CBitCount
RcvNextBit
   bsf    STATUS, RP0                    ; page 1 for TRIS manipulation
   bcf    _SCL                           ; lower clock
   bcf    _SDA                           ; lower data line
   call   Delay47uSec                    ; guarantee min LOW TIME tLOW & setup time
   bsf    _SCL                           ; clock high, data sent by slave
   bcf    STATUS, RP0                    ; select page 0 to read Ports
   bcf    STATUS, C                      ; 0 out Status
   btfsc  SdaPin                         ; Check state of pin
   bsf    STATUS, C                      ; Pin was high, set status
   rlf    I2CData, F                     ; left Shift data (MSB first)
   decfsz I2CBitCount, F                 ; Are we done yet
   goto   RcvNextBit                     ; Nope, go get the next one
; Generate ACK bit if not last byte to be read,
; if last byte Gennerate NACK ; do not send ACK on last byte, main routine will send a STOP bit
   bsf    STATUS, RP0                    ; Page 1 for TRIS manipulation
   bcf    _SCL                           ; pull SCL low
   bcf    _SDA                           ; ACK by pulling SDA low
   btfsc  Last_Byte_Rcv                  ; Is it the last byte to receive
   bsf    _SDA                           ; If so, send NACK by setting SDA high
   bsf    _SCL                           ; Raise Clock back up
RcvEnd:
   bcf    Rcv_Progress                   ; reset bit in Bus Status
   bsf    Rcv_Success                    ; transmission successful
   return
Delay47uSec:
   movlw ((_47uS_Delay-5)/3 + 1)         ; move delay into W
DlyK
   movwf DelayCount                      ; move what is in W to DelayCount
   decfsz   DelayCount, F                ; Decrement DelayCount
   goto  $-1                             ; Loop until 0
   return                                ; return
Delay40uSec:
   movlw ((_40uS_Delay-8)/3 + 1)         ; move delay into W
   goto  DlyK                            ; goto DlyK loop
