MAX17108 10-Channel High-Volta
新品快讯
30人已加入
MAX17108 10-Channel High-Voltage Scan Driver and VCOM Amplifier for TFT LCD Panels
Description
The MAX17108 includes a 10-channel high-voltage level-shifting scan driver and a VCOM amplifier. The device is optimized for thin-film transistor (TFT) liquid-crystal display (LCD) applications.
The high-voltage level-shifting scan driver can swing from +38V to -12V and can swiftly drive capacitive loads. There are two positive supply inputs, which provide flexibility for system design.
The operational amplifier features rail-to-rail output, high short-circuit output current, fast slew rate, and wide bandwidth.
The MAX17108 is available in a 28-pin, 5mm x 5mm, lead-free thin QFN package with a maximum thickness of 0.8mm for thin LCD panels.
Key Features
  • High-Current, High-Speed Operational Amplifier
    • ±200mA Output Short-Circuit Current
    • 100V/µs Slew Rate
    • 20MHz -3dB Bandwidth
    • Rail-to-Rail Outputs
  • High-Voltage Level-Shifting Scan Drivers
    • Logic-Level Inputs
    • +38V to -12V Outputs
  • Thermal-Overload Protection
  • 28-Pin, 5mm x 5mm Thin QFN Package
  • Applications/Uses
    LCD Monitors
    LCD TVs
    • 相关推荐
    • 热点推荐
    • MAX1848
