Infineon FS45MR12W1M1-B11 7.5kW马达驱动方案
infineon公司的评估板Eval-M5-E1B1245N-SiC是7.5 kWCoolSiC™ MOSFET马达驱动器,包括有三相SiC功率模块,和装备了M5 32引脚接口连接器如XMC DriveCard 4400的控制板,具有CoolSiC™ MOSFET马达驱动的特性.评估板Eval-M5-E1B1245N-SiC包括有六块电源模块
FS45MR12W1M1_B11和EiceDRIVER™ 1200 V绝缘栅驱动器1EDI20H12AH.模块额定耐压指标为1200V,开态电阻为 45 mOhm.输入电压为340~480 VAC,集成了NTC温度传感器,最大马达输出功率7.5kW,板上集成了EMI滤波器,在电源和信号部分间绝缘,隔离的Δ∑-ADC电流检测,热敏电阻输出,过流和短路硬件保护,超温硬件保护,保护时所有六个开关开断.主要用在马达控制和驱动,太阳能系统解决方案和不间断电源(UPS).本文介绍了评估板Eval-M5-E1B1245N-SiC主要特性和优势,框图和主要指标,电路图,材料清单和PCB装配图.
Eval-M5-E1B1245N-SiC CoolSiC™ MOSFET motor drives evaluation board for 7.5 kW
       This complete evaluation board including a 3-phase SiC power module for motor drive applications. In combination with control boards equipped with the M5 32-pin interface connector such as the XMC DriveCard 4400, it features and demonstrates our CoolSiC™ MOSFETs in motor drives.
       The evaluation board was developed to support customers during their first steps designing applications with the sixpack power module FS45MR12W1M1_B11 and EiceDRIVER™ 1200 V isolated gate driver 1EDI20H12AH. The module has a rated blocking voltage of 1200 V at a typical on-state resistance of 45 mOhm. It is optimized for motor drive applications with a very high-frequency switching operation.
评估板Eval-M5-E1B1245N-SiC主要特性:
EasyPACK™ 1B 1200 V / 45 mΩ sixpack module with CoolSiC™ MOSFET
       Lead-free terminal plating; RoHS compliant
       Low inductive design
       Integrated NTC temperature sensor
       The evaluation board characteristics are:
       Input voltage 340~480 VAC
       Maximum 7.5 kW motor power output
       On-board EMI filter
       Basic insulation between power and signal part
       Isolated current sensing with Δ∑-ADC
       Isolated sensing of dc-link voltage by Δ∑-ADC
       Thermistor output
       Overload and short-circuit hardware protection
       Overtemperature hardware protection
       All six switches turn off during protection
       Rugged gate driver technology with stability against transient and negative voltage
       Auxiliary power supply with 5 V
       Measurement test points compatible with standard oscilloscope probes
       PCB is 259 mm x 204 mm and has four layers of 35 μm copper each
       评估板Eval-M5-E1B1245N-SiC主要优势:
MADK is optimized to GPD / Servo drives with very high fsw
Including the Easy 1B with CoolSiC™ MOSFET in sixpack configuration
Equipped with all assembly groups for sensorless field oriented control (FOC)
Overtemperature and overcurrent protection as well as short circuit protection
Diagrams
图1.评估板Eval-M5-E1B1245N-SiC框图
评估板Eval-M5-E1B1245N-SiC主要指标:
驱动
This application note provides an overview of the evaluation board Eval-M5-E1B1245N-SiC including its main features, key data, pin assignments and mechanical dimensions.
 Eval-M5-E1B1245N-SiC is a complete evaluation board including a 3-phase SiC power module for motor drive applications. In combination with control boards equipped with the M5 32-pin interface connector such as the XMC DriveCard 4400, it features and demonstrates Infineon’s CoolSiC™ MOSFETs in motor drives.
  The evaluation board Eval-M5-E1B1245N-SiC was developed to support customers during their first steps designing applications with the sixpack power module FS45MR12W1M1_B11. The module has a rated blocking voltage of 1200 V at a typical on-state resistance of 45 mOhm. It is optimized for motor drive applications with a very high-frequency switching operation.
       The Eval-M5-E1B1245N-SiC evaluation board is part of the iMOTION™ Modular Application Design Kit for motor drives (iMOTION™ MADK).
       The MADK platform is intended for use at various power stages with different control boards. These boards can easily be interfaced via the iMOTION™ MADK-M5 32-pin interface connector to control boards such as the XMC DriveCard 4400 or XMC DriveCard 1300.
       This evaluation board is designed as an easy-to-use power stage based on Infineon’s 3-phase power modules. The board is equipped with shunts in the phase output enabling the implementation of sensorless control. It provides a three-phase AC connector, EMI filter, rectifier and a 3-phase output for connecting the motor. The power stage also contains isolated current, voltage and temperature sensing circuits.
       The Eval-M5-E1B1245N-SiC evaluation board is available via regular Infineon distribution partners as well as on Infineon’s website. The features of this board are described in the design feature chapter of this document. The remaining paragraphs provide information enabling customers to copy, modify and qualify the design for production according to their own specific requirements.
 Environmental conditions were considered in the design of the Eval-M5-E1B1245N-SiC. The design was tested as described in this document, but not qualified in terms of safety requirements, manufacturing and operation over the entire operating temperature range or lifetime. The boards provided by Infineon are subject to functional testing only.
Evaluation boards are not subject to the same procedures as regular products regarding Returned Material Analysis (RMA), Process Change Notification (PCN) and Product Discontinuation (PD). Evaluation boards are intended to be used under laboratory conditions and by trained specialists only.
       潜在应用:
       Motor control and drives
       Solutions for solar energy systems
       Uninterruptible power supply
图2.评估板Eval-M5-E1B1245N-SiC外形图
图3.评估板Eval-M5-E1B1245N-SiC正面概述图
图4.评估板Eval-M5-E1B1245N-SiC侧面图
图3和图4中数字功能表:
驱动
驱动
图5.驱动器板连接器电路图
驱动
图6.主输入和预充电电路
驱动
图7.EMI滤波器电路
驱动
图8.辅助电源电路
驱动
图9.功率级
驱动
图10.单相腿驱动器电路
驱动
图11.驱动器电源电路
驱动
图12.驱动器电路整流器电路
驱动
图13.评估板NTC测量电路
驱动
图14.相位电流测量电路
驱动
图15.DC总线电压测量电路
驱动
图16.数模转换测量电路
驱动
图17.保护电路和温度测量电路
驱动
图18.短路保护电路
驱动
图19.评估板Eval-M5-E1B1245N-SiC顶层装配图
驱动
图20.评估板Eval-M5-E1B1245N-SiC底层装配图
评估板Eval-M5-E1B1245N-SiC材料清单:
驱动
驱动
驱动
驱动
驱动
编辑:jq
