MAX5304 10位、电压输出DAC,8引脚µ
新品快讯
29人已加入
MAX5304 10位、电压输出DAC,8引脚µMAX封装
MAX5304 概述
The MAX5304 combines a low-power, voltage-output, 10-bit digital-to-analog converter (DAC) and a precision output amplifier in an 8-pin µMAX package. It operates from a single +5V supply, drawing less than 280µA of supply current.
The output amplifier's inverting input is available to the user, allowing specific gain configurations, remote sensing, and high output-current capability. This makes the MAX5304 ideal for a wide range of applications, including industrial process control. Other features include a software shutdown and power-on reset.
The serial interface is SPI™/QSPI™/MICROWIRE™ compatible. The DAC has a double-buffered input, organized as an input register followed by a DAC register. A 16-bit serial word loads data into the input register. The DAC register can be updated independently or simultaneously with the input register. All logic inputs are TTL/CMOS-logic compatible and buffered with Schmitt triggers to allow direct interfacing to optocouplers.
MAX5304 pdf datasheet
MAX5304 关键特性
  • 10-Bit DAC with Configurable Output Amplifier
  • +5V Single-Supply Operation
  • Low Supply Current
    • 0.28mA Normal Operation
    • 2µA Shutdown Mode
  • Available in 8-Pin µMAX
  • Power-On Reset Clears DAC Output to Zero
  • SPI/QSPI/MICROWIRE Compatible
  • Schmitt-Trigger Digital Inputs for Direct Optocoupler Interface
    MAX5304 应用/使用
     数字增益与失调控制
     工业过程控制
     微处理器控制系统
     便携式测试仪表
     远端工业控制
    dac
    功能原理框图
  • 打开APP阅读更多精彩内容
    • 相关推荐
    • 热点推荐
    • dac
