应用案例
Renesas公司的8V97003是高性能mmWave宽带合成器/锁相环(PLL),能从集成的压控振荡器(VCO)产生高达18GHz的输出频率,提供倍频程的频率调谐范围.器件还提供高性能32位分数反馈分频器,输出分频器允许用户能从VCO的宽带特性获得全部的好处.器件的品质因素(FOM)为-236dBc/Hz,极好的VCO性能有非常低的相位噪音和RMS相位抖动. 在所有工作条件下和频率下,8V97003提供非常低的相位偏移< 10°,从而在波束成形应用中如5G无线网卡大容量MIMO系统降低无线通路再校准所发生的事情.输出驱动器具有可编输出功率设定,8GHz时的单端输出功率高达+12dBm,18GHz时为+4dBm.
当输出是电阻负载时,输出驱动器提供单端输出功率,8GHz时为+9.5dBm,12GHz时高达为-2.5dBm.工作电压3.3V, 7 x7 mm 48-VFQFPN封装.主要用在5G毫米波无线基础设备,大容量MIMO,相位阵列天线和波束成形.无线骨干网,点对点和点对多点微波链接,卫星/VSAT,测试设备/仪表,时钟发生器,高速RF转换器取样时钟和雷达.中电网为您整理如下详细资料,本文介绍了8V97003主要特性,框图,以及评估板8V97003 EVB主要特性,电路图,材料清单和PCB设计图.
The 8V97003 is a high-performance mmWave widebandSynthesizer / Phase Lock Loop (PLL) that generates outputfrequencies up to 18GHz from an integrated Voltage ControlledOscillator (VCO) offering an octave of frequency tuning range.
The device also offers a high-performance 32-bit fractionalfeedback divider and an output divider to allow users to fullybenefit from the wideband characteristics of the VCO.
The device’s figure of merit (FOM) of -236dBc/Hz and theexcellent VCO performance allow for very low phase noise andRMS phase jitter.
The 8V97003 offers a very low output-to-output phase skew driftof < 10° across all operating conditions and frequencies, reducingradio path recalibration occurrences in beamforming applications,such as 5G radio card massive MIMO systems.
The output drivers have programmable output power settings andcan deliver high single-ended output power up of +12dBm at8GHz, and +4dBm at 18GHz, when using inductively loadedoutput terminations (double termination). When the outputs areresistively loaded, the output drivers can deliver a single-endedoutput power of +9.5dBm at 8GHz, and up to -2.5dBm at 12GHz.
The output power can be further increased when using differentialoutputs and measuring the output power differentially.The 8V97003 relies on a single 3.3V power supply and offers lownoise integrated LDOs for excellent power supply noise immunity.
8V97003主要特性:
▪ Output frequency range: 171.875MHz to 18GHz
▪ Ultra-low phase noise VCO
• -60.6dBc integrated phase jitter (35fs rms jitter) from 20kHzto 100MHz at 6GHz
▪ Figure of Merit: -236dBc/Hz
▪ Input reference frequency:
• 10MHz to 1.6GHz (LVPECL, LVDS)
• 10MHz to 250MHz (LVCMOS)
▪ Fractional-N synthesizer and integer-N synthesizer
▪ 32-bit of fractional and modulus resolution
▪ Phase frequency detector (PFD) operation up to 500MHz(Integer mode) or 250MHz (Fractional mode)
▪ Programmable RF output power levels
▪ RF output power < -80dBm when in MUTE
▪ Programmable input multiplier (MULT) to increase PFDfrequency when using a low input frequency
▪ -40°C to +95°C ambient temperature range; and up to +105°Ccase temperature
▪ 3.3V single power supply operation
▪ 7 x7 mm 48-VFQFPN package
▪ SPI interface is compatible with 1.8V logic and tolerant to 3.3V
▪ Supported in the Timing CommanderTM design tool
8V97003典型应用:
▪ 5G millimeter wave wireless infrastructure
▪ Massive MIMO
▪ Phase Array Antennas and beam forming
▪ Wireless backhaul
▪ Point-to-point and point-to-multipoint microwave links
▪ Satellites / VSATs
▪ Test equipment/instrumentation
▪ Clock generation
▪ High-speed RF converters sampling clocks
▪ Radar
图1.8V97003框图
评估板8V97003 EVB
The 8V97003 evaluation board is designed to enable customers to evaluate the functionality and performance of the 8V97003 RF/Microwave Wideband Synthesizer. The 8V97003 device on the evaluation board can be programmed and configured via a PC-based GUI, called Timing Commander, to generate output frequency from 187.5MHz to 18GHz with very low phase noise and RMS phase jitter.
This document discusses the setup of the EVB, and the programming of the 8V97003 using Timing Commander.
评估板8V97003 EVB包括:
8V97003 Evaluation Board
Micro USB Cable
图2.评估板8V97003 EVB外形图
图3.评估板8V97003 EVB主要功能位置图
图4.评估板8V97003 EVB电路图(1)
图5.评估板8V97003 EVB电路图(2)
图6.评估板8V97003 EVB电路图(3)
评估板8V97003 EVB材料清单:
图7.评估板8V97003 EVB PCB设计图:左:顶层;右:第二层
图8.评估板8V97003 EVB PCB设计图:左:第三层;右:底层
编辑:jq
