PC 并行接口定义
接口定义
119人已加入
PC 并行接口定义
PC 并行接口外观是 25 针母插座:
Pin
Name
Description
Pin
Name
Description
1
/STROBE
Strobe
14
/AUTOFD
Autofeed
2
D0
Data Bit 0
15
/ERROR
Error
3
D1
Data Bit 1
16
/INIT
Initialize
4
D2
Data Bit 2
17
/SELIN
Select In
5
D3
Data Bit 3
18
GND
Signal Ground
6
D4
Data Bit 4
19
GND
Signal Ground
7
D5
Data Bit 5
GND
Signal Ground
D6
Data Bit 6
21
GND
Signal Ground
9
D7
Data Bit 7
22
GND
Signal Ground
10
/ACK
Acknowledge
23
GND
Signal Ground
11
BUSY
Busy
24
GND
Signal Ground
12
PE
Paper End
25
GND
Signal Ground
13
SEL
Select
