MAX1789 高级智能电池组控制器
新品快讯
29人已加入
MAX1789 高级智能电池组控制器
The MAX1789 smart battery-pack controller integrates a user-programmable microcontroller core, a coulomb-counting fuel gauge, a multichannel data-acquisition unit, and a system management bus (SMBus) v1.1-compliant master/slave SMBus interface. The 8-bit, RISC microcontroller core has an integrated 8KB of user-programmable flash and a 12KB program ROM library, which provides battery-pack designers with complete flexibility in developing fuel-gauging and control algorithms. The MAX1789 is equipped with in-system debug (ISD) capability for efficient development and debugging.
The MAX1789 includes a 12-bit data-acquisition unit to measure individual cell voltages, thermistors, current, and pack voltage. Internally adjustable overcurrent thresholds and delay timers provide a flexible solution.
The integrating fuel-gauge module provides a typical input offset of less than 1µV and gain accuracy of better than 1% with no trimming required during pack manufacture. The MAX1789 has a wide +4V to +25V operating voltage range. The MAX1789 is available as a 28-TSSOP. The MAX1789 evaluation kit is available to assist with development.
  • Accurate Fuel Gauge Uses V to F Method
    • < 1µV Input Offset Voltage
    • < 1% Gain Error
    • 139nAh Resolution (5m)
    • No Calibration Required
  • 8-bit RISC Microcontroller Core
  • 8KB of Program Flash
  • 12KB of Program ROM
  • 512 Bytes of Data Flash
  • 648 Bytes of RAM
  • 12-Bit ADC
  • Watchdog Timer
  • In-System Debug
  • Eliminates Separate Primary-Protection IC
    • Individual Cell-Voltage Measurements with 0.5% Accuracy
    • N-Channel MOSFET Gate Drivers
    • Low-Current Charge Pump
    • 8% Accurate Overcurrent Protection
    • Programmable Overcurrent Delay Timers
  • 3-pin, 6-LED PWM Driver
  • Random-Number Generator For Encryption
  • SMBus v1.1 Compliant with Master Capability
  • Typical Operating Current < 250µA
  • Typical Shutdown Current < 10nA
  • Integrated 32kHz Oscillator: No Crystal
  • Fully Integrated LDO (VIN = +4V to +25V)
  • 数据采集系统
  • 笔记本电脑电池组
  • 专用电池组
  • 远端数据记录
    • 相关推荐
    • 热点推荐
