Highly Integrated UMTS Femto B
新品快讯
30人已加入
Highly Integrated UMTS Femto Base-Station Chipset Drives Adoption in Access Points and Residential Gateways
  • The MAX2557/MAX2597 comprise a WCDMA Band II and Band V femto base-station transceiver chipset with a unique digital interface for the North American UMTS market.
  • Maxim's proprietary high dynamic range MAX-PHY™ interface eliminates the cost associated with a mixed-signal analog front-end.
  • The MAX2597 transmitter also integrates power amplifiers to further reduce BOM expense.
  • This chipset is ideal for residential gateways and access points.
Chipset with MAX-PHY Interface Reduces BOM Cost in Femto Base Stations
SUNNYVALE, CA—February 25, 2009—Maxim Integrated Products (NASDAQ: MXIM) introduces the MAX2557/MAX2597, a WCDMA Band II and Band V femto base-station transceiver chipset with a unique digital interface for the North American UMTS market. The receiver (MAX2557) and transmitter (MAX2597) utilize Maxim's proprietary high dynamic range MAX-PHY™ interface to eliminate the need for a mixed-signal analog front-end. The MAX2557 has four low-noise amplifier (LNA) inputs to allow monitoring of WCDMA and GSM macro-network signals. The MAX2599 integrates power amplifiers (PAs) to further reduce BOM expense. This industry-leading chipset is the most integrated and highest performance solution for the burgeoning femto base-station market.
The MAX2557/MAX2597 are the North American versions of Maxim's previously released UMTS Band I solution: the MAX2547/MAX2599 transceiver chipset. The MAX2557 is available in a 48-pin fcLGA package, while the MAX2597 is packaged in a 64-pin fcLGA. Both devices operate over the -40°C to +85°C extended industrial temperature range. Contact the factory for pricing.
For rapid application development, a reference design kit is available, providing a complete evaluation platform and all necessary software. Due to unusually high demand for this product, samples, data sheets, and applications support are available by request only.
Maxim Integrated Products is a publicly traded company that designs, manufactures, and sells high-performance semiconductor products. The Company reported revenue in excess of $2 billion for fiscal 2008. Maxim was founded over 25 years ago with the mission to deliver innovative analog and mixed-signal engineering solutions that add value to its customers' products.
  • 相关推荐
  • 热点推荐
  • Access
