y2电容的规格型号
今日头条
1194人已加入
Y2电容是安规电容中的Y电容系列之一,它主要是由两块导体夹着一块绝缘体构成的电子元件。外观多为蓝色,产品都有安全认证标志和耐压AC300V字样。它的规格型号分别有:
安规Y2电容器全系列产品规格:
型号              宽度 厚度脚距引线            电压              容量         材料  容差
Y2-103M-Y5Vφ13mmT3.8mmF10mmL3-22mm   300VAC10000pFY5V  ±20%
Y2-472M-Y5Vφ9.5mmT3.8mmF7.5mmL3-22mm   300VAC4700pFY5V  ±20%
Y2-332M-Y5Vφ8.5mmT3.8mmF7.5mmL3-22mm   300VAC3300pFY5V  ±20%
Y2-222M-Y5Vφ7.5mmT3.8mmF7.5mmL3-22mm   300VAC2200pFY5V  ±20%
Y2-152M-Y5Vφ6.5mmT3.8mmF7.5mmL3-22mm   300VAC1500pFY5V  ±20%
Y2-102M-Y5Vφ6.5mmT3.8mmF7.5mmL3-22mm   300VAC1000pFY5V  ±20%
Y2-472M-Y5Uφ13mmT3.8mmF10mmL3-22mm   300VAC4700pFY5U  ±20%
Y2-332M-Y5Uφ11mmT3.8mmF10mmL3-22mm   300VAC3300pFY5U ±20%
Y2-222M-Y5Uφ8.5mmT3.8mmF7.5mmL3-22mm   300VAC2200pFY5U ±20%
Y2-152M-Y5Uφ8.5mmT3.8mmF7.5mmL3-22mm    300VAC1500pFY5U ±20%
Y2-102M-Y5Uφ7.5mmT3.8mmF7.5mmL3-22mm   300VAC1000pFY5U ±20%
Y2-821K-Y5Uφ7.5mmT3.8mmF7.5mmL3-22mm   300VAC820pFY5U ±10%
Y2-681K-Y5Uφ6.5mmT3.8mmF7.5mmL3-22mm    300VAC680pFY5U ±10%
Y2-561K-Y5Uφ6.5mmT3.8mmF7.5mmL3-22mm    300VAC560pFY5U ±10%
Y2-471K-Y5Uφ6.5mmT3.8mmF7.5mmL3-22mm    300VAC470pFY5U ±10%
Y2-102K-Y5Pφ10mmT3.8mmF7.5mmL3-22mm   300VAC1000pFY5P ±10%
Y2-821K-Y5Pφ10mmT3.8mmF7.5mmL3-22mm    300VAC820pFY5P ±10%
Y2-681K-Y5Pφ8.5mmT3.8mmF7.5mmL3-22mm   300VAC680pFY5P ±10%
Y2-561K-Y5Pφ8mmT3.8mmF7.5mmL3-22mm   300VAC560pFY5P ±10%
Y2-471K-Y5Pφ7.5mmT3.8mmF7.5mmL3-22mm   300VAC470pFY5P ±10%
Y2-331K-Y5Pφ6.5mmT3.8mmF7.5mmL3-22mm    300VAC330pFY5P ±10%
Y2-221K-Y5Pφ6.5mmT3.8mmF7.5mmL3-22mm   300VAC220pFY5P ±10%
Y2-151K-Y5Pφ6.5mmT3.8mmF7.5mmL3-22mm   300VAC150pFY5P ±10%
Y2-101K-Y5Pφ6.5mmT3.8mmF7.5mmL3-22mm   300VAC        100pFY5P ±10%
lw
