抗干扰油色谱分析仪的特点与参数
测量仪表
1527人已加入
抗干扰油色谱分析仪供应产品特性
1、气相色谱柱箱容积大,可安装双填充柱或毛细管柱,且升降温速度快。
2、采用了降低噪声电机,运行平稳机震小,且安装了自动后开门装置。
3、采用320*240显示屏 ,显示清晰明了。
4、自动化控制,操作简单易用。
抗干扰油色谱分析仪供应产品参数
1、体积:690×480×480mm
2、重量:65kg
3、电源:220V±10%(50Hz±0.5 Hz)
4、功率:≤2000W
5、环境温度:+5℃~+35℃
6、相对湿度:≤85%
7、控温范围及控温精度:
8、温度控制范围:室温加8℃~399℃(增量1℃)
9、温度控制精度:在200℃以内精度为±0.1℃, 在200℃以上精度为±0.2℃
10、程升升温阶数: 8阶(柱箱)
11、程升升温速率: 0.1℃~39.9℃/min(柱箱)
12、各阶恒温时间:0~999.9min(增量0.1min)(柱箱)
13、氢火焰离子化检测器(FID):
14、检测限:Mt ≤8×10-12g/s(正十六烷)
15、噪音:≤5×10-14A
16、漂移:≤1×10-13A/30min
17、热导池检测器(TCD):
18、电流:0~220mA(增量1mA)
19、灵敏度:S≥3000mV•ml/mg(正十六烷)
20、噪声:≤20μV
21、漂移:≤30μV/30 mi
        责任编辑:wv
评论(0)
发评论
hole1007 2022-08-22
0 回复 举报
http://house.china.com.cn/sousou/%25B4%25FA%25C0%25ED%25C6%25BD%25CC%25A8%252C%2B%25C3%25E5%25B5%25E9%25CD%25FE%25C4%25E1%25CB%25B9%25C8%25CB%25D3%25E9%25C0%25D6B2024.cN%252C%25BB%25C6%25CA%25AF%25B8%25DF%25D0%25A3_1s.htm http://house.china.com.cn/sousou/%25CA%25D6%25BB%25FAAPP%252C%2B%25BB%25B7%25C7%25F2%25D3%25E9%25C0%25D6%25D5%25E6%25C8%25CB%25D3%25E9%25C0%25D6B2024.cN_1s.htm http://house.china.com.cn/sousou/VIP%252C%2B%25C3%25E5%25B5%25E9%25D3%25C0%25B2%25FD%25B9%25FA%25BC%25CAB2024.cN%252C%25D0%25CF%25CC%25A8%25B5%25E7%25D0%25C5_2s.htm http://house.china.com.cn/sousou/%25DB%25C2%25C0%25B0%252C%2B%25B9%25FB%25B8%25D2%25C5%25B7%25D1%25C7%25B9%25FA%25BC%25CA%25D3%25E9%25C0%25D6B2024.cN%252C%25D2%25E6%25D1%25F4%25B7%25D6%25B9%25AB%25CB%25BE_1s.htm http://house.china.com.cn/sousou/%25C3%25E5%25B5%25E9%252C%2B%25C3%25E5%25B5%25E9%25C5%25B7%25D1%25C7%25B9%25FA%25BC%25CA%25B9%25AB%25CB%25BEB2024.cN%252C%25C9%25CF%25C8%25C4%25CC%25E5%25D3%25FD_1s.htm 收起回复
