MAX3798 Industry's First S
新品快讯
29人已加入
MAX3798 Industry's First Single-Chip, VCSEL Driver and Limiting-Amplifier Solution for 8G Fibre Channel and 10G Ethernet
The MAX3798 combines a VCSEL driver and limiting amplifier in a single chip for 1G to 10G SFP+ applications.
Fabricated using Maxim's MBIC3 IC technology, the MAX3798 delivers > 10Gbps performance, a wide range of receiver- and transmitter-programmable features, and only 320mW of power consumption.
A mode-select feature ensures optimum performance for 1x/2x/4x/8x Fibre Channel and 10GBASE-SR from a single chip.
The MAX3798 is ideal for use in SFP+ optical modules.
 MAX3798 pdf datasheet
ingle Chip Combines 10G VCSEL Driver and Limiting Amplifier
SUNNYVALE, CA—March 12, 2009—Maxim Integrated Products (NASDAQ: MXIM) introduces the MAX3798, a single-chip, VCSEL driver and limiting-amplifier solution targeted for SFP+ Fibre Channel and Ethernet applications. Fabricated using Maxim's MBIC3 integrated-circuit technology, this device delivers > 10Gbps performance, a wide range of receiver- and transmitter-programmable features, and only 320mW of power consumption. Packing the functions of two chips into one, the MAX3798 provides a low-cost, low-power solution for both Fibre Channel (1x/2x/4x/8x) and Ethernet 10GBASE-SR transmission systems, thus simplifying transceiver BOM for module manufacturers.
A 3-wire digital interface provides a wide range of programmable features to optimize performance. Programmable receive functions include data rate, LOS threshold, LOS squelch, LOS polarity, CML output level, signal path polarity, slew-rate control, deemphasis, and mode-select change time. Programmable transmit functions include modulation current, bias current, polarity, deemphasis, eye-crossing adjustment, and eye safety control.
The MAX3798 is fully specified for operation over the -40°C to +85°C temperature range, and is available in a 5mm x 5mm, 32-pin TQFN package. Prices start at $6.18 (10,000-up, FOB USA).
