USIP 高性能、32位MIPS安全微控制器,支持Linux OS
The USIP™ Professional IC (USIP PRO) is a secure microcontroller designed to provide an interoperable, secure, and cost-effective environment for new generations of trusted devices. This secure platform is fully compliant with EMV® and PCI PED standards. The USIP PRO is based upon the most secure, 32-bit, RISC core (MIPS32® 4KSd™) from MIPS Technologies. While providing superior performance (1.35MIPS/MHz), this low-power core adds special instructions to accelerate cryptographic operations and security functions to enforce system integrity. Complemented by a secure memory management unit (MMU), the USIP PRO can run feature-rich operating systems such as Linux® in a secure way.
System security is enhanced by a number of physical and logical protection mechanisms including environmental sensors (temperature, voltage, and frequency), active metal shield, real-time clock (RTC), and 512 bits of secure NVM storage (BPK) with instant erase capability upon tampering. For greater privacy, external memory content is fully protected through a patented universal cryptographic interface (UCI) that performs on the fly AES-128 encryption/decryption. The USIP PRO is one of the most integrated solutions for financial and other trusted terminals. It includes 128KB of SRAM, 128KB of ROM, 256KB of flash, and 256 bytes of OTP. Additionally, the USIP PRO accommodates external memories such as NOR flash, SRAM, and SDRAM.
The device provides extensive communication support with USB On-The-Go (OTG), UART, SPI™, I²C, PS/2, IrDA, and parallel SPP. In addition, the USIP PRO offers a unique set of peripherals such as smart card controllers, LCD interface, thermal printer interface, GPIO, PWM, watchdog, general-purpose timers, and a built-in ADC.
MIPS32 4KSd RISC Processor
- 130 MIPS at 96MHz
- 2 x 8KB Cache
- Memory Management Unit
- Enhanced Power Management
- Dedicated Instructions to Boost Cryptographic Operations
Memories
- 128KB of SRAM
- 256KB of Lockable Flash Memory
- 256 Bytes of User OTP
- 128KB of ROM (HAL, EMV Level 1, and Secure Bootloader)
- Memory Controller Supporting One SDRAM and Up to Four Static Memories (Flash or SRAM)
Security Features
- On the Fly AES Encryption/Decryption of External Memories
- Hardware AES-128 Engine
- Unique Serial Number (USN)
- 512-Bit Battery-Powered Key Area (BPK) with Instant Erase Upon Tampering
- Integrated Tamper Sensors (Frequency, Voltage, Temperature, Die Shield)
- 12 External Sensor Inputs
- True Random-Number Generator (TRNG)
- Secure RTC with Interrupt Alarm
- Secure Keyboard Controller (12 x 12)
Interrupt Controller
1D/2D DMA
LCD Interface: 8-Bit Bus, 6800 Compatible
Three ISO 7816 Controllers
Thermal Printer Interface
USB 2.0 OTG Full Speed with 16 Endpoints and Integrated Transceiver
Four UARTs (IrDA and Full Modem Support)
I²C Master/Slave
SPI Master/Slave with Up to Seven Slaves
PS2 Master/Slave
SPP Interface
6-Channel, 10-Bit ADC
32 GPIOs
Four 16-Bit Timers/Counters
Two PWMs with One 15mA Output
Watchdog Timer
JTAG Boundary Scan
256-Ball BGA, 0.8mm Pitch
ATM键盘
EFTPOS
Electric Metering
Healthcare Reader
密码键盘
