图形界面介绍:GUI上的按键是Summary Report
这次我们要介绍的GUI上的按键是Summary Report界面。这个按键其实很简单,就是调用summaryReport这个命令,点一下会出现如下界面
界面
打开生成的report文件,会包含以下信息
General design information
General library information
Netlist information
Timing information
Floorplan/Placement information
例子:
============================== General Design Information ============================== Design Status: Routed Design Name: DTMF_CHIP # Instances: 5813 # Hard Macros: 4     ------------------------------     Macro Cells in Netlist     ------------------------------               Macro Name   Instance Count  Area (um^2)  Area Percentage in Core              rom_512x16A                1        47055.125            6.642%                   pllclk                1        84000.000           11.857% # Std Cells: 5738     ------------------------------     Standard Cells in Netlist     ------------------------------                Cell Type   Instance Count  Area (um^2)                   XOR2X1               18         479.0016                  XNOR2X1               26         691.8912   ============================== General Library Information ============================== # Routing Layers: 6 # Masterslice Layers: 0 # Pin Layers:     General Caution:         1) Library have Metal1, Metal2, Metal4 and Metal6 pins, you should setPreRouteAsObs {1 2 3}                                 to ensure these pins are accessible after placement       ------------------------------     Pin Layers     ------------------------------     Metal6     Metal1  4 # Layers:     ------------------------------     Layer OVERLAP Information     ------------------------------     Type  Overlap     ------------------------------     Layer OVERLAP InformationLayer Metal6 Information     ------------------------------     Type  Routing     Wire Pitch X  1.320 um 。。。
