X-NUCLEO-IDB04A1 X-NUCLEO-IDB04A1基于BlueNRG为STM32核蛋白蓝牙低耗能扩展板
KANA 发表于 2020-05-20 19:05:18
数据: 基于BlueNRG为STM32核蛋白蓝牙低耗能扩展板
  • BlueNRG low power, low energy Bluetooth network coprocessor
  • BALF-NRG-01D3 balun & harmonic filter
  • Free comprehensive development firmware library and example for BlueNRG, compatible with STM32Cube firmware
  • Bluetooth low energy 4.0 master and slave compliant
  • Compatible with STM32 Nucleo boards
  • Equipped with Arduino UNO R3 connector
The X-NUCLEO-IDB04A1 is a Bluetooth low energy evaluation board to allow expansion of the STM32 Nucleo boards. It is compatible with the Arduino UNO R3 connector layout, and is designed around BlueNRG, a Bluetooth low energy, low power network coprocessor compliant with BTLE 4.0 and the BALF-NRG-01D3, an ultra miniature balun optimized for ST BlueNRG RF IC, which integrates matching network and harmonics filter. The X-NUCLEO-IDB04A1 interfaces with the STM32 MCU via SPI pin, and the user can change the default SPI clock, the SPI chip select and SPI IRQ by changing one resistor on the evaluation board. The excellent performance of BlueNRG and the best matching between BlueNRG and BALF-NRG-01D3, X-NUCLEO-IDB04A1 passed the RF TEST for Japan Radio Law certification with higher margin above the specification values as well as it is FCC certified (FCC ID: S9NIDB04A1).
技术文档
数据手册(1)
收藏
相关话题
文章来源栏目
+加入圈子
评论(0)
加载更多评论
参与评论
分享到
QQ空间 QQ好友 微博
取消
