74hc574功能真值表及引脚管脚图
接口定义
119人已加入
74hc574功能真值表及引脚管脚图
74hc
74hc74HC574 pdf datasheet
Notes
1. H = HIGH voltage level
h = HIGH voltage level one set-up time prior to the LOW-to-HIGH
CP transition
L = LOW voltage level
l = LOW voltage level on set-up time prior to the LOW-to-HIGH
CP transition
Z = HIGH impedance OFF-state
­ = LOW-to-HIGH clock transition
评论(0)
发评论
zxb19861224 2013-07-10
0 回复 举报
不错 收起回复
  • 相关推荐
  • 热点推荐
  • 74hc
