MAX9875 有低RF干扰敏感度的单声道音频子系统,带有D
新品快讯
29人已加入
MAX9875 具有低RF干扰敏感度的单声道音频子系统,带有DirectDrive耳机放大器
数据资料
The MAX9875 combines a high-efficiency Class D audio power amplifier with a stereo Class AB capacitorless DirectDrive® headphone amplifier. Maxim’s 3rd generation, filterless Class D amplifier with active emissions limiting technology provides Class AB performance with Class D efficiency.
The MAX9875 delivers up to 725mW from a 3.7V supply into an 8&937; load with 87% efficiency to extend battery life. The filterless modulation scheme combined with active emissions limiting circuitry and spread-spectrum modulation greatly reduces EMI while eliminating the need for output filtering used in traditional Class D devices.
The stereo Class AB headphone amplifier in the MAX9875 uses Maxim’s patented DirectDrive architecture, that produces a ground-referenced output from a single supply, eliminating the need for large DC-blocking capacitors, saving cost, space, and component height.
The device utilizes a user-defined input architecture, three preamplifier gain settings, an input mixer, volume control, comprehensive click-and-pop suppression, and I2C control.
The MAX9875 is available in a thermally efficient, space-saving 20-bump WLP package.
关键特性
Low Emissions, Filterless Class D Amplifier
  • Achieves Better than 10dB Margin Under EN55022 Class B Limits
  • Low RF Susceptibility Design Rejects TDMA Noise from GSM Radios
  • Input Mixer with User-Defined Input Mode
  • 725mW Speaker Output (RSPK = 8Ω, PVDD = 3.7V)
  • 53mW Headphone Output (RHP = 16Ω, VDD = 3.7V)
  • Low 0.05% THD+N at 1kHz (Class D Power Amplifier)
  • Low 0.016% THD+N at 1kHz (Headphone Amplifier)
  • 87% Efficiency (RSPK = 8Ω, POUT = 750mW)
  • High Speaker Amplifier PSRR (72dB at 217Hz)
  • High Headphone Amplifier PSRR (84dB at 217Hz)
  • I2C Control
  • Hardware and Software Shutdown Mode
  • Click-and-Pop Suppression
  • Current-Limit and Thermal Protection
  • Available in a Space-Saving, 2.5mm x 2.0mm WLP Package
    应用/使用
    蜂窝电话
    便携式多媒体播放器
    MAX9875 pdf datasheet (Low RF Susceptibility Mono Audio Subsystem)
    • 相关推荐
    • 热点推荐
