KUKA机器人对于涂胶设备的清胶控制
清胶控制时序:
清胶程序的调用:SPSMAKRO183 = E1534 + E163
A1534 = EIN  ------------ A1534清胶许可
A1535 = E1534 + E163  ------ A1535清胶=E1534清胶请求+E163PLC清胶
WARTE BIS A1535 & E1536 + !A1535
E1536  清胶已经结束
A1535 = AUS 关闭清胶
A1534 = AUS清胶许可
后台USER控制
IFMIT_KL1_SPUELEN AND ((NOT $OUT[O_R_PFO] AND NOT KL1_stat) OR (KL1_stat AND NOT$IN[I_Sp_Ruh_KL1]) OR ($EXT==FALSE)) AND KL1_SPUELEN_AKTIV THEN
F346激活原位清胶,!A15机器人在原位和F356固定涂胶,或者F356固定涂胶和E2115摆臂在接胶位,或者不是外部自动,KL1_SPUELEN_AKTIV清胶已激活
用于固定涂胶设备使用
$OUT[O_KL1_SP_EIN]=FALSE  A1535 清胶
$OUT[O_KL1_FRG_SP]=FALSEA1534清胶请求
$OUT[O_KL1_Sp_akt]=FALSE   A163清胶激活
KL1_SPUELEN_AKTIV=FALSE   关闭清胶激活
ENDIF
IF NOT $OUT[O_KL1_P_akt] THEN 如果没有激活进程涂胶
IF($OUT[O_R_PFO] AND NOT KL1_stat AND $FLAG[F_KL1_FRG_PF0]) OR (KL1_stat AND$IN[I_Sp_Ruh_KL1] AND NOT $IN[I_Sp_Arb_KL1]) THEN
A15在原位,没有固定涂胶,F721允许在原位自动清胶,者固定涂胶和E2115摆臂在接胶位,没有E2116摆臂伸出
$OUT[O_KL1_FRG_SP]=TRUE   A1534 发出涂胶请求
ELSE
$OUT[O_KL1_FRG_SP]=FALSE  关闭涂胶请求
ENDIF
IFMIT_KL1_SPUELEN OR $IN[I_KL1_anw_Sp] THEN  使用原位清胶,E163选择清胶
IF($EXT==TRUE) AND $COULD_START_MOTION AND $OUT[O_KL1_FRG_SP] THEN
外部自动 ,程序执行,  A1534清胶请求
IF$IN[I_KL1_ANF_SP] OR $IN[I_KL1_anw_Sp] THEN
E1534 有清胶请求,E163PLC选择清胶
$OUT[O_KL1_SP_EIN]=TRUE  A1535 清胶
$OUT[O_KL1_Sp_akt]=TRUE   A163 清胶激活
KL1_SPUELEN_AKTIV=TRUE清胶激活
ENDIF
IF$IN[I_KL1_SP_FER] THEN  E1536清胶结束
$OUT[O_KL1_SP_EIN]=FALSEA1535 清胶 关闭
$OUT[O_KL1_Sp_akt]=FALSEA163 清胶激活关闭
KL1_SPUELEN_AKTIV=FALSE清胶激活关闭
ENDIF
ENDIF
ENDIF
ENDIF
