KUKA机器人电伺服移动到力的控制MOVE_TO_FORCE程序分析
移动焊钳到使用力
GLOBALDEF SGM_MOVE_TO_FORCE (FORCE :IN, MovementType:IN, GunClosingReason:IN, SGEQ_ParamSet:IN, SGRS_ParamSet:IN )
力值的给入图:
机器人
声明变量:
DECL SG_MoveType_TMovementType
DECL ForceMovementType_T GunClosingReason
DECL SGEQg_POINT_T SGEQ_ParamSet
DECLREAL FORCE, SPEED, factor, SavedExValue
DECLINT HANDLE
DECL SGRSg_POINT_T SGRS_ParamSet
声明结束
进入程序
SG_LogbookCurrent.TargetForce = FORCE
factor = 1.0
IF(SGEQ_ActivePointCond)THEN SGEQ_ActivePointCond=false
说明一下的IF语句里暂时没有使用
SGEQ_ExpectedTime =SGEQ_TimeExpectedHelper(SGEQ_ParamSet)
SGEQ_SpeedProz = SGEQ_CalcSpeedAndTimes(SGEQ_ExpectedTime)
SPEED = SGEQ_SpeedProz
SGEQ_CurrentParamSet = SGEQ_ParamSet
IF NOT SGEQ_ContactMode THEN
SGEQ_INIT(SGEQ_ParamSet,SGEQ_ExpectedTime)
ENDIF
IF(ServoGun[SG_ActiveGunNumber].GunControl == #Position)THEN
TRIGGERWHENDISTANCE= 1 DELAY= 0 DO SGEQ_Start(SGEQ_CurrentParamSet,SGEQ_ExpectedTime)Prio=-1
ELSE
SavedExValue = SGL_GET_AXIS_VALUE(P_APPROX)
P_APPROX = SGEQ_StartPoint
SGL_SET_AXIS_VALUE(P_APPROX, SavedExValue)
ENDIF
SGL_MoveToPos(SGEQ_StartPoint,SGEQ_StartPoint,#CLS_OPEN,MovementType)
ENDIF
-----------------endif--------------
IF MovementType == #SG_PTP THEN  移动方式是PTP
BAS (#ACC_PTP,100 )  使用 ACC加速度100%
BAS (#VEL_PTP,100 )  使用 VEL速度100%
$APO.CPTP=1    使用接近距离
说明一下的IF语句里暂时没有使用
$VEL_EXTAX[SG_ExtaxActive]= SPEED * factor
IF(ServoGun[SG_ActiveGunNumber].GunControl == #Force)THEN
ENDIF
ELSE
IF(GunClosingReason == #SingleWear)THEN
factor = SG_SingleWearSpeedF
$VEL_EXTAX[SG_ExtaxActive]= SG_ConstSpeed * factor
ELSE
$VEL_EXTAX[SG_ExtaxActive]= 100
ENDIF
ENDIF
-------------end-------------------------
---------------if-----------------
IF(GunClosingReason == #Init)THEN
焊接时GunClosingReason =#WELD 测量时GunClosingReason == #Init
PTP P_APPROX C_PTP
ELSE
PTP P_APPROX C_PTP
ENDIF
$VEL_EXTAX[SG_ExtaxActive]=SG_ConstSpeed * factor
-----提前运行中外部轴的轴速度-----
-----SG_ConstSpeed 之前在更换电极时算得速度------------
ServoGun[1]=#Position
ACTIVATE_FORCE_MODE((6+SG_ExtaxActive), FORCE, SGL_CalcPartPos(SG_CurrentCmd),0)
----使用力功能进行移动--------给入焊接控制器给的力值进行力的移动-------
ENDIF
由于ServoGun[1]= #Position所以不执行力模式
ACTIVATE_FORCE_MODE((6+SG_ExtaxActive), FORCE, SGL_CalcPartPos(SG_CurrentCmd),SGEQ_AFM_ConstSpeedUser)
ENDIF
PTP P_PART C_PTP   在有力的情况下执行点到点的位置P_PART
P_PART补偿之后的力的值
C_PTP带轨迹逼近-提前执行
TRIGGERWHENDISTANCE=0 DELAY=0 DO SGM_VELEXAXFULL()PRIO=-1
提前触发激活  外部轴速度$VEL_EXTAX[1]=100
$APO.CDIS激活逼近范围
PTP P_WELD与ACTIVATE_FORCE_MODE()函数和$VEL_EXTAX[1]一起使用实现力的控制
PTP P_WELD 执行焊接轨迹点
ENDIF
