干货:Centos 6.5部署nginx和php环境部署
  1.IP地址:192.168.1.241
  下载这次部署需要的更新包,并上传到/usr/local/src目录:[root@binds src]# ll
  total 17576
  -rw-r--r-- 1 root root 730589 Jul 14 13:29 nginx-1.2.8.tar.gz
  -rw-r--r-- 1 root root 1790055 Jul 29 10:39 pcre-8.32.tar.gz
  -rw-r--r-- 1 root root 14902187 Jul 28 18:00 php-5.3.22.tar.gz
  -rw-r--r-- 1 root root 560351 Jul 29 10:41 zlib-1.2.7.tar.gz
  安装nginx必须安装pcre-8.32.tar.gz
  [root@binds pcre-8.32]# tar zxvf pcre-8.32.tar.gz
  [root@binds pcre-8.32]# cd pcre-8.32
  [root@binds pcre-8.32]# 。/configure
  [root@binds pcre-8.32]# make && make install
  make[3]: Leaving directory `/usr/local/src/pcre-8.32‘
  make[2]: Leaving directory `/usr/local/src/pcre-8.32’
  make[1]: Leaving directory `/usr/local/src/pcre-8.32‘
  安装结束
  接下来安装
  [root@binds src]# tar zxvf zlib-1.2.7.tar.gz
  [root@binds src]# cd zlib-1.2.7
  [root@binds zlib-1.2.7]# 。/configure
  出现错误Looking for a four-byte integer type.。。 Found. 无关紧要
  [root@localhost zlib-1.2.7]# make && make install
  chmod 644 /usr/local/lib/libz.a
  cp libz.so.1.2.7 /usr/local/lib
  chmod 755 /usr/local/lib/libz.so.1.2.7
  cp zlib.3 /usr/local/share/man/man3
  chmod 644 /usr/local/share/man/man3/zlib.3
  cp zlib.pc /usr/local/lib/pkgconfig
  chmod 644 /usr/local/lib/pkgconfig/zlib.pc
  cp zlib.h zconf.h /usr/local/include
  chmod 644 /usr/local/include/zlib.h /usr/local/include/zconf.h
  安装完成后,安装nginx
  [root@binds src]# tar zxvf nginx-1.2.8.tar.gz
  [root@binds src]# cd nginx-1.2.8
  。/configure --prefix=/usr/local/nginx-1.2.8 --with-http_sub_module --with-http_stub_status_module --with-http_ssl_module --with-http_gzip_static_module
  Configuration summary
  + using system PCRE library
  + using system OpenSSL library
  + md5: using OpenSSL library
  + sha1: using OpenSSL library
  + using system zlib library
  nginx path prefix: “/usr/local/nginx-1.2.8”
  nginx binary file: “/usr/local/nginx-1.2.8/sbin/nginx”
  nginx configuration prefix: “/usr/local/nginx-1.2.8/conf”
  nginx configuration file: “/usr/local/nginx-1.2.8/conf/nginx.conf”
  nginx pid file: “/usr/local/nginx-1.2.8/logs/nginx.pid”
  nginx error log file: “/usr/local/nginx-1.2.8/logs/error.log”
  nginx http access log file: “/usr/local/nginx-1.2.8/logs/access.log”
  nginx http client request body temporary files: “client_body_temp”
  nginx http proxy temporary files: “proxy_temp”
  nginx http fastcgi temporary files: “fastcgi_temp”
  nginx http uwsgi temporary files: “uwsgi_temp”
  nginx http scgi temporary files: “scgi_temp”
  [root@binds nginx-1.2.8]# make && make install
  cp conf/nginx.conf ’/usr/local/nginx-1.2.8/conf/nginx.conf.default‘
  test -d ’/usr/local/nginx-1.2.8/logs‘ || mkdir -p ’/usr/local/nginx-1.2.8/logs‘
  test -d ’/usr/local/nginx-1.2.8/html‘ || cp -R html ’/usr/local/nginx-1.2.8‘
  make[1]: Leaving directory `/usr/local/src/nginx-1.2.8’
  安装完成
  打补丁:后面会补全
  root@binds nginx-1.2.8]# service iptables stop
  iptables: Setting chains to policy ACCEPT: filter [ OK ]
  iptables: Flushing firewall rules: [ OK ]
  iptables: Unloading modules: [ OK ]
  [root@localhost nginx-1.2.8]# /usr/local/nginx-1.2.8/sbin/nginx
  /usr/local/nginx-1.2.8/sbin/nginx: error while loading shared libraries: libpcre.so.1: cannot open shared object file: No such file or directory
  报错解决方法:
  创建软连接:[root@binds share]#测试下:ln -s /usr/local/lib/libpcre.so.1 /lib64/
  接下来继续安装php
  mkdir -p /usr/local/php/lib/php/extensions/no-debug-non-zts-20090626
  [root@binds share]# cd /usr/local/src/
  total 17592
  drwxr-xr-x 9 1001 1001 4096 Aug 10 10:58 nginx-1.2.8
  drwxr-xr-x 9 1169 1169 12288 Aug 10 10:34 pcre-8.32
  drwxr-xr-x 14 501 games 4096 Aug 10 10:52 zlib-1.2.7
  [root@binds src]# tar zxvf php-5.3.22.tar.gz
  [root@binds php-5.3.22]# yum -y install libjpeg libjpeg-devel libpng libpng-devel freetype freetype-devel libxml2 libxml2-devel zlib zlib-devel glibc glibc-devel glib2 glib2-devel bzip2 bzip2-devel ncurses ncurses-devel curl curl-devel e2fsprogs e2fsprogs-devel krb5 krb5-devel libidn libidn-devel openssl openssl-devel openldap openldap-devel nss_ldap openldap-clients openldap-servers gd curl curl-devel mysql mysql-devel mhash libiconv mcrypt
  。/configure “--prefix=/usr/local/php” “--enable-fpm” “--with-config-file-path=/home/server_config/php” “--with-mysql=/usr/local/mysql” “--with-mysqli=/usr/local/mysql/bin/mysql_config” “--with-pdo-mysql=/usr/local/mysql” “--with-iconv-dir” “--with-freetype-dir” “--with-jpeg-dir” “--with-png-dir” “--with-gd” “--with-zlib” “--with-libxml-dir” “--with-curl” “--with-curlwrappers” “--with-openssl” “--with-mhash” “--with-xmlrpc” “--with-mcrypt” “--with-ldap” “--with-ldap-sasl” “--enable-xml” “--enable-safe-mode” “--enable-bcmath” “--enable-shmop” “--enable-sysvsem” “--enable-inline-optimization” “--enable-mbregex” “--enable-mbstring” “--enable-gd-native-ttf” “--enable-ftp” “--enable-pcntl” “--enable-sockets” “--enable-fastcgi”
  低版本:。/configure --prefix=/usr/local/php \
  --with-config-file-path=/home/server_config/php\
  --with-mysql=/usr/local/mysql/ \
  --with-mysqli=/usr/local/mysql/bin/mysql_config --with-iconv-dir=/usr/local/ \
  --with-freetype-dir --with-jpeg-dir --with-png-dir --with-zlib --with-libxml-dir=/usr/ \
  --enable-xml --disable-rpath --enable-discard-path --enable-bcmath \
  --enable-shmop --enable-sysvsem --enable-inline-optimization --with-curl --with-curlwrappers \
  --enable-mbregex --enable-fastcgi --enable-fpm --enable-force-cgi-redirect --enable-mbstring \
  --with-mcrypt --with-gd --enable-gd-native-ttf --with-openssl --with-mhash --enable-pcntl \
  --enable-sockets --with-ldap --with-ldap-sasl --with-xmlrpc --enable-zip --enable-soap
  --enable-safe-mode
  可能报错:
  checking for LDAP Cyrus SASL support.。。 yes
  configure: error: Cannot find ldap libraries in /usr/lib.
  执行:cp -frp /usr/lib64/libldap* /usr/lib
  checking for mcrypt support.。。 yes
  configure: error: mcrypt.h not found. Please reinstall libmcrypt.
  上传libmcrypt-2.5.8.tar.gz
  # tar zxvf libmcrypt-2.5.8.tar.gz
  # cd libmcrypt-2.5.8
  # 。/configure
  # make
  # make install
  checking for specified location of the MySQL UNIX socket.。。 no configure: error: Cannot find libmysq
  执行:
  cp -rp /usr/lib64/mysql/libmysqlclient.so.16.0.0 /usr/lib/libmysqlclient.so
  [root@localhost php-5.3.22]# make && make install
  /usr/bin/ld: cannot find -lltdl
  collect2: ld returned 1 exit status
  make: *** [libphp5.la] Error 1
  如果需要mcrypt,那么需要安装libltdl
  libltdl在libmcrypt软件包中就有,具体过程:
  #cd /software/libmcrypt-2.5.8/libltdl
  #./configure –enable-ltdl-install
  [root@localhost php-5.3.22]# cp php.
  php.gif php.ini-development php.ini-production
  [root@localhost php-5.3.22]# cp php.ini-development /usr/local/php-5.3.22/lib/
  [root@localhost php-5.3.22]# cp php.ini-production /usr/local/php-5.3.22/lib/
  [root@localhost php-5.3.22]# cd /usr/local/php-5.3.22/
  [root@localhost php-5.3.22]# ll
  total 32
  drwxr-xr-x 2 root root 4096 Aug 11 18:16 bin
  drwxr-xr-x 2 root root 4096 Aug 11 18:16 etc
  drwxr-xr-x 3 root root 4096 Aug 11 18:16 include
  drwxr-xr-x 3 root root 4096 Aug 11 18:18 lib
  drwxr-xr-x 4 root root 4096 Aug 11 18:15 man
  drwxr-xr-x 2 root root 4096 Aug 11 18:15 sbin
  drwxr-xr-x 3 root root 4096 Aug 11 18:15 share
  drwxr-xr-x 4 root root 4096 Aug 11 18:15 var
  [root@localhost php-5.3.22]# cd etc/
  [root@localhost etc]# ll
  total 28
  -rw-r--r-- 1 root root 1222 Aug 11 18:16 pear.conf
  -rw-r--r-- 1 root root 21680 Aug 11 18:15 php-fpm.conf.default
  [root@localhost etc]# mv php-fpm.conf.default php-fpm.conf
  [root@localhost etc]# /usr/local/php-5.3.22/sbin/php-fpm
  第三方php apc apcu的安装
  上传APC-3.1.9.tgz apcu-4.0.6.tgz到服务器
  tar zxvf APC-3.1.9.tgz
  [root@localhost APC-3.1.9]# /usr/local/php/bin/phpize
  [root@localhost src]# tar zxvf apcu-4.0.6.tgz
  [root@localhost apcu-4.0.6]# /usr/local/php/bin/phpize
  。/configure --enable-apcu --with-php-config=/usr/local/php/bin/php-config
  。/configure --prefix=/usr/local/unixODBC-2.3.0 --includedir=/usr/local/include --libdir=/usr/lib -bindir=/usr/bin --sysconfdir=/etc
  安装imagick-3.1.0RC2 先yum -y install ImageMagick-devel
