TL16C552A--具有16字节FIFO并行端口的双路UA
新品快讯
30人已加入
TL16C552A--具有16字节FIFO并行端口的双路UART芯片
The TL16C552A is an enhanced dual-channel version of the popular TL16C550B asynchronous communications element (ACE). The device serves two serial input/output interfaces simultaneously in microcomputer or microprocessor-based systems. Each channel performs serial-to-parallel conversion on data characters received from peripheral devices or modems and parallel-to-serial conversion on data characters transmitted by the CPU. The complete status of each channel of the dual ACE can be read at any time during functional operation by the CPU. The information obtained includes the type and condition of the transfer operations being performed and the error conditions encountered.
In addition to its dual communications interface capabilities, the TL16C552A provides the user with a bidirectional parallel data port that fully supports the parallel Centronics-type printer interface. The parallel port and the two serial ports provide IBM PC/AT-compatible computers with a single device to serve the three system ports. A programmable baud rate generator that can divide the timing reference clock input by a divisor between 1 and (216 - 1) is included.
The TL16C552A is available in a 68-pin plastic-leaded chip-carrier (FN) package and a 80-pin TQFP (PN) package. The TL16C552AM is available in a 68-pin ceramic quad flat (HV) package.
特性
IBM PC/ATTM Compatible
Two TL16C550 ACEs
Enhanced Bidirectional Printer Port
16-Byte FIFOs Reduce CPU Interrupts
Up to 16-MHz Clock Rate for up to 1-Mbaud Operation
Transmit, Receive, Line Status, and Data Set Interrupts on Each Channel Independently Controlled
Individual Modem Control Signals for Each Channel
Programmable Serial Interface Characteristics for Each Channel:
5-, 6-, 7-, or 8-Bit Characters
Even, Odd, or No Parity Bit Generation and Detection
1-, 1-1/2-, or 2-Stop Bit Generation
3-State Outputs Provide TTL Drive for the Data and Control Bus on Each Channel
Hardware and Software Compatible With TL16C452
IBM PC/AT is a trademark of International Business Machines Corporation.
Number of Channels 2
FIFOs(bytes) 16
Operating Voltage(V) 5.0
Pin/Package 68PLCC, 80LQFP
Rating Catalog
Tx / Rx FIFO INT Trig No / 4 Levels
Auto RTS/CTS Yes
CPU Interface X86
Baud Rate (max) at Vcc = 1.8V and with 16X Sampling(Mbps) N/A
Baud Rate (max) at Vcc = 2.5V and with 16X Sampling(Mbps) N/A
Baud Rate (max) at Vcc = 3.3V and with 16X Sampling(Mbps) N/A
Baud Rate (max) at Vcc = 5.0V and with 16X Sampling(Mbps) 1.0
