TL16C552--具有16字节FIFO和并行端口的双路UA
新品快讯
30人已加入
TL16C552--具有16字节FIFO和并行端口的双路UART芯片
The TL16C552 is an enhanced dual channel version of the popular TL16C550 asynchronous communications element (ACE). The device serves two serial input/output interfaces simultaneously in microcomputer or microprocessor-based systems. Each channel performs serial-to-parallel conversion on data characters received from peripheral devices or modems and parallel-to-serial conversion on data characters transmitted by the CPU. The complete status of each channel of the dual ACE can be read at any time during functional operation by the CPU. The information obtained includes the type and condition of the transfer operations being performed and the error conditions.
In addition to its dual communications interface capabilities, the TL16C552 provides the user with a fully bidirectional parallel data port that fully supports the parallel Centronics-type printer. The parallel port and the two serial ports provide IBM PC/AT-compatible computers with a single device to serve the three system ports.
A programmable baud rate generator is included that can divide the timing reference clock input by a divisor between 1 and (216 - 1).
The TL16C552 is housed in a 68-pin plastic leaded chip carrier.
特性
IBM PC/ATTM Compatible
Two TL16C550 ACEs
Enhanced Bidirectional Printer Port
16-Byte FIFOs Reduce CPU Interrupts
Independent Control of Transmit, Receive, Line Status, and Data Set Interrupts on Each Channel
Individual Modem Control Signals for Each Channel
Programmable Serial Interface Characteristics for Each Channel:
5-, 6-, 7-, or 8-bit Characters
Even-, Odd-, or No-Parity Bit Generation
and Detection
1-, 1 1/2-, or 2-Stop Bit Generation
3-State TTL Drive for the Data and Control Bus on Each Channel
Hardware and Software Compatible With TL16C452
IBM PC/AT is a trademark of International Business Machines Corporation.
Number of Channels 2
FIFOs(bytes) 16
Operating Voltage(V) 5.0
Operating Temp Range(Celsius) 0 to 70
Pin/Package 68PLCC
Rating Catalog
Tx / Rx FIFO INT Trig No / 4 Levels
Auto RTS/CTS Yes
CPU Interface X86
Baud Rate (max) at Vcc = 1.8V and with 16X Sampling(Mbps) N/A
Baud Rate (max) at Vcc = 2.5V and with 16X Sampling(Mbps) N/A
Baud Rate (max) at Vcc = 3.3V and with 16X Sampling(Mbps) N/A
Baud Rate (max) at Vcc = 5.0V and with 16X Sampling(Mbps) 1.0
