FPC物料中英文对照表
电子常识
2686人已加入
FPC物料中英文对照表
1、基材:base material 2、层压板:laminate
3、覆金属箔基材:metal-clad bade material 4 laminate (CCL)
5、单面覆铜箔层压板:single-sided copper-clad laminate 6 copper-clad laminate
7、复合层压板:composite laminate 8、薄层压板:thin laminate
9、金属芯覆铜箔层压板:metal core copper-clad laminate 10、金属基覆铜层压板:metal base copper-clad laminate
11、挠性覆铜箔绝缘薄膜:flexible copper-clad dielectric film 12、基体材料:basis material
13、预浸材料:prepreg 14、粘结片:bonding sheet
15、预浸粘结片:preimpregnated bonding sheer 16 glass substrate
17、加成法用层压板:laminate for additive process 18 lamination panel
19、内层芯板:core material 20、催化板材:catalyzed board coated catalyzed laminate
21、涂胶催化层压板:adhesive-coated catalyzed laminate 22、涂胶无催层压板:adhesive-coated uncatalyzed laminate
23、粘结层:bonding layer 24、粘结膜:film adhesive
25、涂胶粘剂绝缘薄膜:adhesive coated dielectric film 26、无支撑胶粘剂膜:unsupported adhesive film
27、覆盖层:cover layer (cover lay) 28 material
29、铜箔面:copper-clad surface 30、去铜箔面:foil removal surface
31、层压板面:unclad laminate surface 32、基膜面:base film surface
33、胶粘剂面:adhesive face 34 finish
35、粗面:matt finish 36 wise direction
37、模向:cross wise direction 38、剪切板:cut to size panel
39、酚醛纸质覆铜箔板:phenolic cellulose paper copper-clad laminates(phenolic/paper CCL)
40、环氧纸质覆铜箔板:epoxide cellulose paper copper-clad laminates (epoxy/paper CCL)
41、环氧玻璃布基覆铜箔板:epoxide woven glass fabric copper-clad laminates
42、环氧玻璃布纸复合覆铜箔板:epoxide cellulose paper core glass cloth surfaces copper-clad laminates
43、环氧玻璃布玻璃纤维复合覆铜箔板:epoxide non woven/woven glass reinforced copper-clad laminates
44、聚酯玻璃布覆铜箔板:ployester woven glass fabric copper-clad laminates
45、聚酰亚胺玻璃布覆铜箔板:polyimide woven glass fabric copper-clad laminates
46、双马来酰亚胺三嗪环氧玻璃布覆铜箔板:bismaleimide/triazine/epoxide woven glass fabric copper-clad lamimates
47、环氧合成纤维布覆铜箔板:epoxide synthetic fiber fabric copper-clad laminates
48、聚四乙烯玻璃纤维覆铜箔板:teflon/fiber glass copper-clad laminates
49、超薄型层压板:ultra thin laminate
50、陶瓷基覆铜箔板:ceramics base copper-clad laminates
51、紫外线阻挡型覆铜箔板:UV blocking copper-clad laminates
基材材料
1、A阶树脂:A-stage resin 2、B阶树脂:B-stage resin
3、C阶树脂:C-stage resin 4、环氧树脂:epoxy resin
5、酚醛树脂:phenolic resin 6 resin
7、聚酰亚胺树脂:polyimide resin 8、双马来酰亚胺三嗪树脂:bismaleimide-triazine resin
9、丙烯酸树脂:acrylic resin 10、 三聚氰胺甲醛树脂:melamine formaldehyde resin
11、多官能环氧树脂:polyfunctional epoxy resin 12、溴化环氧树脂:brominated epoxy resin
13、环氧酚醛:epoxy novolac 14、氟树脂:fluroresin
15、硅树脂:silicone resin 16、硅烷:silane
17、聚合物:polymer 18、无定形聚合物:amorphous polymer
19、结晶现象:crystalline polamer 20、双晶现象:dimorphism
21、共聚物:copolymer 22、合成树脂:synthetic
23、热固性树脂:thermosetting resin 24 resin
25、感光性树脂:photosensitive resin 26、环氧当量:weight per epoxy equivalent (WPE)
27、环氧值:epoxy value 28
29、粘结剂:binder 30
31、固化剂:curing agent 32 retardant
33、遮光剂:opaquer 34
35、不饱和聚酯:unsatuiated polyester 36、聚酯薄膜:polyester
37、聚酰亚胺薄膜:polyimide film (PI) 38 (PTFE)
39、聚全氟乙烯丙烯薄膜:perfluorinated ethylene-propylene copolymer film (FEP)
40、增强材料:reinforcing material 41、玻璃纤维:glass fiber
42、E玻璃纤维:E-glass fibre 43、D玻璃纤维:D-glass fibre
44、S玻璃纤维:S-glass fibre 45、玻璃布:glass fabric
46、非织布:non-woven fabric 47、玻璃纤维垫:glass mats
48、纱线:yarn 49
50、绞股:strand 51、纬纱:weft yarn
52、经纱:warp yarn 53、但尼尔:denier
54、经向:warp-wise 55、纬向:weft-wise filling-wise
56、织物经纬密度:thread count 57、织物组织:weave structure
58、平纹组织:plain structure 59、坏布:grey fabric
60、稀松织物:woven scrim 61、弓纬:bow of weave
62、断经:end missing 63、缺纬:mis-picks
64、纬斜:bias 65、折痕:crease
66、云织:waviness 67 eye
68、毛圈长:feather length 69
70、裂缝:split 71、捻度:twist of yarn
72、浸润剂含量:size content 73、浸润剂残留量:size residue
74、处理剂含量:finish level 75、浸润剂:size
76、偶联剂:couplint agent 77、处理织物:finished fabric
78、聚酰胺纤维:polyarmide fiber 79、聚酯纤维非织布:non-woven polyester fabric
80、浸渍绝缘纵纸:impregnating insulation paper 81、聚芳酰胺纤维纸:aromatic polyamide paper
82、断裂长:breaking length 83、吸水高度:height of capillary rise
84、湿强度保留率:wet strength retention 85、白度:whitenness
86、陶瓷:ceramics 87 foil
88、铜箔:copper foil 89 copper foil (ED copper foil)
90、压延铜箔:rolled copper foil 91 copper foil
92、压延退火铜箔:rolled annealed copper foil (RA copper foil) 93、薄铜箔:thin copper foil
94、涂胶铜箔:adhesive coated foil 95 coated copper foil (RCC)
96、复合金属箔:composite metallic material 97 foil
98、殷瓦:invar 99 profile
100、光面:shiny side 101 side
102、处理面:treated side 103 proofing 104、双面处理铜箔:double treated foil
