通信设计应用
| SCT PORT |
BGA PIN | BSDL SCAN POSITION |
BSDL SCAN NAME |
I/O | DATA SHEET SYMBOL |
DATA SHEET DESCRIPTION |
| 1 | -- | 0 | RCL | Output | -- | Internal to Package |
| 1 | M1 | 1 | A8MCLK | Output | 8MCLK1 | 8192 MHz Clock Based on RCLK1 |
| 1 | M2 | 2 | RCHBLK | Output | RCHBLK1 | Receive Channel Block SCT1 |
| 1 | H1 | 3 | RSYSCLK | Input | RSYSCLK1 | Receive System Clock SCT1 |
| 1 | H2 | 4 | RLOSLOTC | Output | RLOS/LOTC1 | Receive LOS/LOTC SCT1 |
| 1 | G1 | 5 | RSYNC | BiDir | RSYNC1 | Receive Sync SCT1 |
| 1 | -- | 6 | -- | Control | -- | Internal to Package |
| 1 | K4 | 7 | RFSYNC | Output | RFSYNC1 | Receive Frame Sync SCT1 |
| 1 | L1 | 8 | RMSYNC | Output | RMSYNC1 | Receive Multiframe Sync SCT1 |
| 1 | J2 | 9 | RSER | Output | RSER1 | Receive Serial Data SCT1 |
| 1 | L2 | 10 | RSIG | Output | RSIG1 | Receive Signaling Output SCT1 |
| 1 | K1 | 11 | RSIGF | Output | RSIGF1 | Receive Signaling Freeze SCT1 |
| 1 | J1 | 12 | RCHCLK | Output | RCHCLK1 | Receive Channel Clock SCT1 |
| 1 | L4 | 13 | RPOSO | Output | RPOSO1 | Receive Positive Data Output SCT1 |
| 1 | L3 | 14 | RNEGO | Output | RNEGO1 | Receive Negative Data Output SCT1 |
| 1 | M3 | 15 | RCLKO | Output | RCLKO1 | Receive Clock Output SCT1 |
| 1 | M4 | 16 | RCLKI | Input | RCLKI1 | Receive Clock Input SCT1 |
| 1 | R3 | 17 | RNEGI | Input | RNEGI1 | Receive Negative Data Input SCT1 |
| 1 | R4 | 18 | RPOSI | Input | RPOSI1 | Receive Positive Data Input SCT1 |
| 1 | -- | 19 | RDATA | Output | -- | Internal to Package |
| 1 | N3 | 20 | RCLK | Output | RCLK1 | Receive Clock SCT1 |
| 1 | F1 | 21 | RLCLK | Output | RLCLK1 | Receive Link Clock SCT1 |
| 1 | G2 | 22 | RLINK | Output | RLINK1 | Receive Link Data SCT1 |
| 1 | K3 | 23 | WRRW | Input | Active-Low WR (R/Active-Low W) | Write Input (Read/Write) |
| 1 | -- | 24 | FMS | Input | -- | Internal to Package |
| 1 | P3 | 25 | CS | Input | Active-Low CS1 | Chip Select SCT1 |
| 1 | N2 | 26 | RDDS | Input | Active-Low RD (Active-Low DS) | Read Input (Data Strobe) |
| 1 | P4 | 27 | ALEASA7 | Input | A7/ALE | Address Bus Bit 7/ALE |
| 1 | U8 | 28 | A6 | Input | A6 | Address Bus Bit 6 |
| 1 | H4 | 29 | A5 | Input | A5 | Address Bus Bit 5 |
| 1 | V8 | 30 | A4 | Input | A4 | Address Bus Bit 4 |
| 1 | T4 | 31 | A3 | Input | A3 | Address Bus Bit 3 |
| 1 | V2 | 32 | A2 | Input | A2 | Address Bus Bit 2 |
| 1 | L17 | 33 | A1 | Input | A1 | Address Bus Bit 1 |
| 1 | U3 | 34 | A0 | Input | A0 | Address Bus Bit 0 |
| 1 | U4 | 35 | D7AD7 | BiDir | D7/AD7 | Data or Address/Data Bus Bit 7 |
| 1 | V4 | 36 | D6AD6 | BiDir | D6/AD6 | Data or Address/Data Bus Bit 6 |
| 1 | U5 | 37 | D5AD5 | BiDir | D5/AD5 | Data or Address/Data Bus Bit 5 |
| 1 | U9 | 38 | D4AD4 | BiDir | D4/AD4 | Data or Address/Data Bus Bit 4 |
| 1 | U7 | 39 | D3AD3 | BiDir | D3/AD3 | Data or Address/Data Bus Bit 3 |
| 1 | W15 | 40 | D2AD2 | BiDir | D2/AD2 | Data or Address/Data Bus Bit 2 |
| 1 | J19 | 41 | D1AD1 | BiDir | D1/AD1 | Data or Address/Data Bus Bit 1 |
| 1 | U11 | 42 | D0AD0 | BiDir | D0/AD0 | Data or Address/Data Bus Bit 0 |
| 1 | -- | 43 | -- | Control | -- | Internal to Package |
| 1 | U10 | 44 | MUX | Input | MUX | Mux Bus Select |
| 1 | V9 | 45 | CO | Output | CO1 | Carry Output for IBO SCT1 |
| 1 | V10 | 46 | TCHCLK | Output | TCHCLK1 | Transmit Channel Clock SCT1 |
| 1 | W12 | 47 | TSSYNC | Input | TSSYNC1 | Transmit System Sync SCT1 |
| 1 | W11 | 48 | TSYSCLK | Input | TSYSCLK1 | Transmit System Clock SCT1 |
| 1 | -- | 49 | TDATA | Input | -- | Internal to Package |
| 1 | -- | 50 | TESO | Output | -- | Internal to Package |
| 1 | W10 | 51 | TSIG | Input | TSIG1 | Transmit Signaling Input SCT1 |
| 1 | W9 | 52 | TSER | Input | TSER1 | Transmit Serial Data SCT1 |
| 1 | Y9 | 53 | TCLK | Input | TCLK1 | Transmit Clock SCT1 |
| 1 | V7 | 54 | TPOSO | Output | TPOSO1 | Transmit Positive Data Output SCT1 |
| 1 | T3 | 55 | TNEGO | Output | TNEGO1 | Transmit Negative Data Output SCT1 |
| 1 | W7 | 56 | TCLKO | Output | TCLKO1 | Transmit Clock Output SCT1 |
| 1 | V6 | 57 | TCLKI | Input | TCLKI1 | Transmit Clock Input SCT1 |
| 1 | R1 | 58 | TNEGI | Input | TNEGI1 | Transmit Negative Data Input SCT1 |
| 1 | W3 | 59 | TPOSI | Input | TPOSI1 | Transmit Positive Data Input SCT1 |
| 1 | V1 | 60 | TSYNC | BiDir | TSYNC1 | Transmit Sync SCT1 |
| 1 | -- | 61 | -- | Control | -- | Internal to Package |
| 1 | W6 | 62 | CI | Input | CI1 | Carry Input for IBO SCT1 |
| 1 | W5 | 63 | TLINK | Input | TLINK1 | Transmit Link Data for SCT1 |
| 1 | V3 | 64 | TLCLK | Output | TLCLK1 | Transmit Link Clock for SCT1 |
| 1 | W1 | 65 | TCHBLK | Output | TCHBLK1 | Transmit Channel Block SCT1 |
| 1 | U1 | 66 | INT | Output | Active-Low INT | Interrupt |
| 1 | -- | 67 | -- | Internal | -- | Internal to Package |
| 1 | -- | 68 | -- | Internal | -- | Internal to Package |
| 1 | U16 | 69 | TEST | Input | TEST | Test |
| 1 | -- | 70 | A8XCLK | Output | -- | Internal to Package |
| 1 | K2 | 71 | LIUC | Input | LIUC | Line Interface Connect |
| 1 | P2 | 72 | BTS | Input | BTS | Bus Type Select |
| 2 | -- | 0 | RCL | Output | -- | Internal to Package |
| 2 | H17 | 1 | A8MCLK | Output | 8MCLK2 | 8192MHz Clock Based on RCLK2 |
| 2 | G17 | 2 | RCHBLK | Output | RCHBLK2 | Receive Channel Block SCT2 |
| 2 | F17 | 3 | RSYSCLK | Input | RSYSCLK2 | Receive System Clock SCT2 |
| 2 | E17 | 4 | RLOSLOTC | Output | RLOS/LOTC2 | Receive LOS/LOTC SCT2 |
| 2 | D12 | 5 | RSYNC | BiDir | RSYNC2 | Receive Sync SCT2 |
| 2 | -- | 6 | -- | Control | -- | Internal to Package |
| 2 | D17 | 7 | RFSYNC | Output | RFSYNC2 | Receive Frame Sync SCT2 |
| 2 | D16 | 8 | RMSYNC | Output | RMSYNC2 | Receive Multiframe Sync SCT2 |
| 2 | D15 | 9 | RSER | Output | RSER2 | Receive Serial Data SCT2 |
| 2 | B16 | 10 | RSIG | Output | RSIG2 | Receive Signaling Output SCT2 |
| 2 | C15 | 11 | RSIGF | Output | RSIGF2 | Receive Signaling Freeze SCT2 |
| 2 | D14 | 12 | RCHCLK | Output | RCHCLK2 | Receive Channel Clock SCT2 |
| 2 | A16 | 13 | RPOSO | Output | RPOSO2 | Receive Positive Data Output SCT2 |
| 2 | B15 | 14 | RNEGO | Output | RNEGO2 | Receive Negative Data Output SCT2 |
| 2 | C14 | 15 | RCLKO | Output | RCLKO2 | Receive Clock Output SCT2 |
| 2 | A15 | 16 | RCLKI | Input | RCLKI2 | Receive Clock Input SCT2 |
| 2 | D13 | 17 | RNEGI | Input | RNEGI2 | Receive Negative Data Input SCT2 |
| 2 | B14 | 18 | RPOSI | Input | RPOSI2 | Receive Positive Data Input SCT2 |
| 2 | -- | 19 | RDATA | Output | -- | Internal to Package |
| 2 | B13 | 20 | RCLK | Output | RCLK2 | Receive Clock SCT2 |
| 2 | A12 | 21 | RLCLK | Output | RLCLK2 | Receive Link Clock SCT2 |
| 2 | A13 | 22 | RLINK | Output | RLINK2 | Receive Link Data SCT2 |
| 2 | K3 | 23 | WRRW | Input | Active-Low WR (R/Active-Low W) | Write Input (Read/Write) |
| 2 | -- | 24 | FMS | Input | -- | Internal to Package |
| 2 | A14 | 25 | CS | Input | Active-Low CS2 | Chip Select for SCT2 |
| 2 | N2 | 26 | RDDS | Input | Active-Low RD (Active-Low DS) | Read Input (Data Strobe) |
| 2 | P4 | 27 | ALEASA7 | Input | A7/ALE | Address Bus Bit 7/ALE |
| 2 | U8 | 28 | A6 | Input | A6 | Address Bus Bit 6 |
| 2 | H4 | 29 | A5 | Input | A5 | Address Bus Bit 5 |
| 2 | V8 | 30 | A4 | Input | A4 | Address Bus Bit 4 |
| 2 | T4 | 31 | A3 | Input | A3 | Address Bus Bit 3 |
| 2 | V2 | 32 | A2 | Input | A2 | Address Bus Bit 2 |
| 2 | L17 | 33 | A1 | Input | A1 | Address Bus Bit 1 |
| 2 | U3 | 34 | A0 | Input | A0 | Address Bus Bit 0 |
| 2 | U4 | 35 | D7AD7 | BiDir | D7/AD7 | Data or Address/Data Bus Bit 7 |
| 2 | V4 | 36 | D6AD6 | BiDir | D6/AD6 | Data or Address/Data Bus Bit 6 |
| 2 | U5 | 37 | D5AD5 | BiDir | D5/AD5 | Data or Address/Data Bus Bit 5 |
| 2 | U9 | 38 | D4AD4 | BiDir | D4/AD4 | Data or Address/Data Bus Bit 4 |
| 2 | U7 | 39 | D3AD3 | BiDir | D3/AD3 | Data or Address/Data Bus Bit 3 |
| 2 | W15 | 40 | D2AD2 | BiDir | D2/AD2 | Data or Address/Data Bus Bit 2 |
| 2 | J19 | 41 | D1AD1 | BiDir | D1/AD1 | Data or Address/Data Bus Bit 1 |
| 2 | U11 | 42 | D0AD0 | BiDir | D0/AD0 | Data or Address/Data Bus Bit 0 |
| 2 | -- | 43 | -- | Control | -- | Internal to Package |
| 2 | U10 | 44 | MUX | Input | MUX | Mux Bus Select |
| 2 | B17 | 45 | CO | Output | CO2 | Carry Output for IBO SCT2 |
| 2 | A18 | 46 | TCHCLK | Output | TCHCLK2 | Transmit Channel Clock SCT2 |
| 2 | B18 | 47 | TSSYNC | Input | TSSYNC2 | Transmit System Sync SCT2 |
| 2 | A19 | 48 | TSYSCLK | Input | TSYSCLK2 | Transmit System Clock SCT2 |
| 2 | -- | 49 | TDATA | Input | -- | Internal to Package |
| 2 | -- | 50 | TESO | Output | -- | Internal to Package |
| 2 | C18 | 51 | TSIG | Input | TSIG2 | Transmit Signaling Input SCT2 |
| 2 | C17 | 52 | TSER | Input | TSER2 | Transmit Serial Data SCT2 |
| 2 | B19 | 53 | TCLK | Input | TCLK2 | Transmit Clock SCT2 |
| 2 | C19 | 54 | TPOSO | Output | TPOSO2 | Transmit Positive Data Output SCT2 |
| 2 | B20 | 55 | TNEGO | Output | TNEGO2 | Transmit Negative Data Output SCT2 |
| 2 | E18 | 56 | TCLKO | Output | TCLKO2 | Transmit Clock Output SCT2 |
| 2 | D19 | 57 | TCLKI | Input | TCLKI2 | Transmit Clock Input SCT2 |
| 2 | F19 | 58 | TNEGI | Input | TNEGI2 | Transmit Negative Data Input SCT2 |
| 2 | C20 | 59 | TPOSI | Input | TPOSI2 | Transmit Positive Data Intput SCT2 |
| 2 | D20 | 60 | TSYNC | BiDir | TSYNC2 | Transmit Sync SCT2 |
| 2 | -- | 61 | -- | Control | -- | Internal to Package |
| 2 | F18 | 62 | CI | Input | CI2 | Carry Input for IBO SCT2 |
| 2 | E19 | 63 | TLINK | Input | TLINK2 | Transmit Link Data for SCT2 |
| 2 | E20 | 64 | TLCLK | Output | TLCLK2 | Transmit Link Clock for SCT2 |
| 2 | F20 | 65 | TCHBLK | Output | TCHBLK2 | Transmit Channel Block SCT2 |
| 2 | U1 | 66 | INT | Output | Active-Low INT | Interrupt |
| 2 | -- | 67 | -- | Internal | -- | Internal to Package |
| 2 | -- | 68 | -- | Internal | -- | Internal to Package |
| 2 | U16 | 69 | TEST | Input | TEST | Test |
| 2 | -- | 70 | A8XCLK | Output | -- | Internal to Package |
| 2 | K2 | 71 | LIUC | Input | LIUC | Line Interface Connect |
| 2 | P2 | 72 | BTS | Input | BTS | Bus Type Select |
| 3 | -- | 0 | RCL | Output | -- | Internal to Package |
| 3 | F4 | 1 | A8MCLK | Output | 8MCLK3 | 8192 MHz Clock Based on RCLK3 |
| 3 | G4 | 2 | RCHBLK | Output | RCHBLK3 | Receive Channel Block SCT3 |
| 3 | G3 | 3 | RSYSCLK | Input | RSYSCLK3 | Receive System Clock SCT3 |
| 3 | E1 | 4 | RLOSLOTC | Output | RLOS/LOTC3 | Receive LOS/LOTC SCT3 |
| 3 | D1 | 5 | RSYNC | BiDir | RSYNC3 | Receive Sync SCT3 |
| 3 | -- | 6 | -- | Control | -- | Internal to Package |
| 3 | A2 | 7 | RFSYNC | Output | RFSYNC3 | Receive Frame Sync SCT3 |
| 3 | F2 | 8 | RMSYNC | Output | RMSYNC3 | Receive Multiframe Sync SCT3 |
| 3 | E2 | 9 | RSER | Output | RSER3 | Receive Serial Data SCT3 |
| 3 | C1 | 10 | RSIG | Output | RSIG3 | Receive Signaling Output SCT3 |
| 3 | D2 | 11 | RSIGF | Output | RSIGF3 | Receive Signaling Freeze SCT3 |
| 3 | F3 | 12 | RCHCLK | Output | RCHCLK3 | Receive Channel Clock SCT3 |
| 3 | B1 | 13 | RPOSO | Output | RPOSO3 | Receive Positive Data Output SCT3 |
| 3 | C2 | 14 | RNEGO | Output | RNEGO3 | Receive Negative Data Output SCT3 |
| 3 | B4 | 15 | RCLKO | Output | RCLKO3 | Receive Clock Output SCT3 |
| 3 | A4 | 16 | RCLKI | Input | RCLKI3 | Receive Clock Input SCT3 |
| 3 | A1 | 17 | RNEGI | Input | RNEGI3 | Receive Negative Data Input SCT3 |
| 3 | B2 | 18 | RPOSI | Input | RPOSI3 | Receive Positive Data Input SCT3 |
| 3 | -- | 19 | RDATA | Output | -- | Internal to Package |
| 3 | E3 | 20 | RCLK | Output | RCLK3 | Receive Clock SCT3 |
| 3 | D3 | 21 | RLCLK | Output | RLCLK3 | Receive Link Clock SCT3 |
| 3 | A3 | 22 | RLINK | Output | RLINK3 | Receive Link Data SCT3 |
| 3 | K3 | 23 | WRRW | Input | Active-Low WR (R/Active-Low W) | Write Input (Read/Write) |
| 3 | -- | 24 | FMS | Input | -- | Internal to Package |
| 3 | B5 | 25 | CS | Input | Active-Low CS3 | Chip Select for SCT3 |
| 3 | N2 | 26 | RDDS | Input | Active-Low RD (Active-Low DS) | Read Input (Data Strobe) |
| 3 | P4 | 27 | ALEASA7 | Input | A7/ALE | Address Bus Bit 7/ALE |
| 3 | U8 | 28 | A6 | Input | A6 | Address Bus Bit 6 |
| 3 | H4 | 29 | A5 | Input | A5 | Address Bus Bit 5 |
| 3 | V8 | 30 | A4 | Input | A4 | Address Bus Bit 4 |
| 3 | T4 | 31 | A3 | Input | A3 | Address Bus Bit 3 |
| 3 | V2 | 32 | A2 | Input | A2 | Address Bus Bit 2 |
| 3 | L17 | 33 | A1 | Input | A1 | Address Bus Bit 1 |
| 3 | U3 | 34 | A0 | Input | A0 | Address Bus Bit 0 |
| 3 | U4 | 35 | D7AD7 | BiDir | D7/AD7 | Data or Address/Data Bus Bit 7 |
| 3 | V4 | 36 | D6AD6 | BiDir | D6/AD6 | Data or Address/Data Bus Bit 6 |
| 3 | U5 | 37 | D5AD5 | BiDir | D5/AD5 | Data or Address/Data Bus Bit 5 |
| 3 | U9 | 38 | D4AD4 | BiDir | D4/AD4 | Data or Address/Data Bus Bit 4 |
| 3 | U7 | 39 | D3AD3 | BiDir | D3/AD3 | Data or Address/Data Bus Bit 3 |
| 3 | W15 | 40 | D2AD2 | BiDir | D2/AD2 | Data or Address/Data Bus Bit 2 |
| 3 | J19 | 41 | D1AD1 | BiDir | D1/AD1 | Data or Address/Data Bus Bit 1 |
| 3 | U11 | 42 | D0AD0 | BiDir | D0/AD0 | Data or Address/Data Bus Bit 0 |
| 3 | -- | 43 | -- | Control | -- | Internal to Package |
| 3 | U10 | 44 | MUX | Input | MUX | Mux Bus Select |
| 3 | A6 | 45 | CO | Output | CO3 | Carry Output for IBO SCT3 |
| 3 | B8 | 46 | TCHCLK | Output | TCHCLK3 | Transmit Channel Clock SCT3 |
| 3 | D10 | 47 | TSSYNC | Input | TSSYNC3 | Transmit System Sync SCT3 |
| 3 | A11 | 48 | TSYSCLK | Input | TSYSCLK3 | Transmit System Clock SCT3 |
| 3 | -- | 49 | TDATA | Input | -- | Internal to Package |
| 3 | -- | 50 | TESO | Output | -- | Internal to Package |
| 3 | A10 | 51 | TSIG | Input | TSIG3 | Transmit Signaling Input SCT3 |
| 3 | C10 | 52 | TSER | Input | TSER3 | Transmit Serial Data SCT3 |
| 3 | B10 | 53 | TCLK | Input | TCLK3 | Transmit Clock SCT3 |
| 3 | C9 | 54 | TPOSO | Output | TPOSO3 | Transmit Positive Data Output SCT3 |
| 3 | D9 | 55 | TNEGO | Output | TNEGO3 | Transmit Negative Data Output SCT3 |
| 3 | A7 | 56 | TCLKO | Output | TCLKO3 | Transmit Clock Output SCT3 |
| 3 | C8 | 57 | TCLKI | Input | TCLKI3 | Transmit Clock Input SCT3 |
| 3 | D8 | 58 | TNEGI | Input | TNEGI3 | Transmit Negative Data Input SCT3 |
| 3 | A8 | 59 | TPOSI | Input | TPOSI3 | Transmit Positive Data Input SCT3 |
| 3 | C7 | 60 | TSYNC | BiDir | TSYNC3 | Transmit Sync SCT3 |
| 3 | -- | 61 | -- | Control | -- | Internal to Package |
| 3 | D7 | 62 | CI | Intput | CI3 | Carry Input for IBO SCT3 |
| 3 | C6 | 63 | TLINK | Input | TLINK3 | Transmit Link Data for SCT3 |
| 3 | D6 | 64 | TLCLK | Output | TLCLK3 | Transmit Link Clock for SCT3 |
| 3 | C11 | 65 | TCHBLK | Output | TCHBLK3 | Transmit Channel Block SCT3 |
| 3 | U1 | 66 | INT | Output | Active-Low INT | Interrupt for All Four SCTs |
| 3 | -- | 67 | -- | Internal | -- | Internal to Package |
| 3 | -- | 68 | -- | Internal | -- | Internal to Package |
| 3 | U16 | 69 | TEST | Input | TEST | Test |
| 3 | -- | 70 | A8XCLK | Output | -- | Internal to Package |
| 3 | K2 | 71 | LIUC | Input | LIUC | Line Interface Connect |
| 3 | P2 | 72 | BTS | Input | BTS | Bus Type Select |
| 4 | -- | 0 | RCL | Output | -- | Internal to Package |
| 4 | V13 | 1 | A8MCLK | Output | 8MCLK4 | 8192MHz Clock Based on RCLK4 |
| 4 | Y12 | 2 | RCHBLK | Output | RCHBLK4 | Receive Channel Block SCT4 |
| 4 | W14 | 3 | RSYSCLK | Input | RSYSCLK4 | Receive System Clock SCT4 |
| 4 | V11 | 4 | RLOSLOTC | Output | RLOS/LOTC4 | Receive LOS/LOTC SCT4 |
| 4 | V12 | 5 | RSYNC | BiDir | RSYNC4 | Receive Sync SCT4 |
| 4 | -- | 6 | -- | Control | -- | Internal to Package |
| 4 | V14 | 7 | RFSYNC | Output | RFSYNC4 | Receive Frame Sync SCT4 |
| 4 | W16 | 8 | RMSYNC | Output | RMSYNC4 | Receive Multiframe Sync SCT4 |
| 4 | W17 | 9 | RSER | Output | RSER4 | Receive Serial Data SCT4 |
| 4 | Y18 | 10 | RSIG | Output | RSIG4 | Receive Signaling Output SCT4 |
| 4 | V16 | 11 | RSIGF | Output | RSIGF4 | Receive Signaling Freeze SCT4 |
| 4 | U14 | 12 | RCHCLK | Output | RCHCLK4 | Receive Channel Clock SCT4 |
| 4 | U15 | 13 | RPOSO | Output | RPOSO4 | Receive Positive Data Output SCT4 |
| 4 | U17 | 14 | RNEGO | Output | RNEGO4 | Receive Negative Data Output SCT4 |
| 4 | T17 | 15 | RCLKO | Output | RCLKO4 | Receive Clock Output SCT4 |
| 4 | R17 | 16 | RCLKI | Input | RCLKI4 | Receive Clock Input SCT4 |
| 4 | P17 | 17 | RNEGI | Input | RNEGI4 | Receive Negative Data Input SCT4 |
| 4 | V15 | 18 | RPOSI | Input | RPOSI4 | Receive Positive Data Input SCT4 |
| 4 | -- | 19 | RDATA | Output | -- | Internal to Package |
| 4 | M18 | 20 | RCLK | Output | RCLK4 | Receive Clock SCT4 |
| 4 | K18 | 21 | RLCLK | Output | RLCLK4 | Receive Link Clock SCT4 |
| 4 | U12 | 22 | RLINK | Output | RLINK4 | Receive Link Data SCT4 |
| 4 | K3 | 23 | WRRW | Input | Active-Low WR (R/Active-Low W) | Write Input (Read/Write) |
| 4 | -- | 24 | FMS | Input | -- | Internal to Package |
| 4 | K17 | 25 | CS | Input | Active-Low CS4 | Chip Select for SCT4 |
| 4 | N2 | 26 | RDDS | Input | Active-Low RD (Active-Low DS) | Read Input (Data Strobe) |
| 4 | P4 | 27 | ALEASA7 | Input | A7/ALE | Address Bus Bit 7/ALE |
| 4 | U8 | 28 | A6 | Input | A6 | Address Bus Bit 6 |
| 4 | H4 | 29 | A5 | Input | A5 | Address Bus Bit 5 |
| 4 | V8 | 30 | A4 | Input | A4 | Address Bus Bit 4 |
| 4 | T4 | 31 | A3 | Input | A3 | Address Bus Bit 3 |
| 4 | V2 | 32 | A2 | Input | A2 | Address Bus Bit 2 |
| 4 | L17 | 33 | A1 | Input | A1 | Address Bus Bit 1 |
| 4 | U3 | 34 | A0 | Input | A0 | Address Bus Bit 0 |
| 4 | U4 | 35 | D7AD7 | BiDir | D7/AD7 | Data or Address/Data Bus Bit 7 |
| 4 | V4 | 36 | D6AD6 | BiDir | D6/AD6 | Data or Address/Data Bus Bit 6 |
| 4 | U5 | 37 | D5AD5 | BiDir | D5/AD5 | Data or Address/Data Bus Bit 5 |
| 4 | U9 | 38 | D4AD4 | BiDir | D4/AD4 | Data or Address/Data Bus Bit 4 |
| 4 | U7 | 39 | D3AD3 | BiDir | D3/AD3 | Data or Address/Data Bus Bit 3 |
| 4 | W15 | 40 | D2AD2 | BiDir | D2/AD2 | Data or Address/Data Bus Bit 2 |
| 4 | J19 | 41 | D1AD1 | BiDir | D1/AD1 | Data or Address/Data Bus Bit 1 |
| 4 | U11 | 42 | D0AD0 | BiDir | D0/AD0 | Data or Address/Data Bus Bit 0 |
| 4 | -- | 43 | -- | Control | -- | Internal to Package |
| 4 | U10 | 44 | MUX | Input | MUX | Mux Bus Select |
| 4 | J20 | 45 | CO | Output | CO4 | Carry Output for IBO SCT4 |
| 4 | L18 | 46 | TCHCLK | Output | TCHCLK4 | Transmit Channel Clock SCT4 |
| 4 | K19 | 47 | TSSYNC | Input | TSSYNC4 | Transmit System Sync SCT4 |
| 4 | N18 | 48 | TSYSCLK | Input | TSYSCLK4 | Transmit System Clock SCT4 |
| 4 | -- | 49 | TDATA | Input | -- | Internal to Package |
| 4 | -- | 50 | TESO | Output | -- | Internal to Package |
| 4 | L19 | 51 | TSIG | Input | TSIG4 | Transmit Signaling Input SCT4 |
| 4 | K20 | 52 | TSER | Input | TSER4 | Transmit Serial Data SCT4 |
| 4 | M19 | 53 | TCLK | Input | TCLK4 | Transmit Clock SCT4 |
| 4 | N19 | 54 | TPOSO | Output | TPOSO4 | Transmit Positive Data Output SCT4 |
| 4 | N20 | 55 | TNEGO | Output | TNEGO4 | Transmit Negative Data Output SCT4 |
| 4 | P19 | 56 | TCLKO | Output | TCLKO4 | Transmit Clock Output SCT4 |
| 4 | P20 | 57 | TCLKI | Input | TCLKI4 | Transmit Clock Input SCT4 |
| 4 | R20 | 58 | TNEGI | Input | TNEGI4 | Transmit Negative Data Input SCT4 |
| 4 | R19 | 59 | TPOSI | Input | TPOSI4 | Transmit Positive Data Intput SCT4 |
| 4 | R18 | 60 | TSYNC | BiDir | TSYNC4 | Transmit Sync SCT4 |
| 4 | -- | 61 | -- | Control | -- | Internal to Package |
| 4 | T20 | 62 | CI | Input | CI4 | Carry Input for IBO SCT4 |
| 4 | T19 | 63 | TLINK | Input | TLINK4 | Transmit Link Data for SCT4 |
| 4 | T18 | 64 | TLCLK | Output | TLCLK4 | Transmit Link Clock for SCT4 |
| 4 | U20 | 65 | TCHBLK | Output | TCHBLK4 | Transmit Channel Block SCT4 |
| 4 | U1 | 66 | INT | Output | Active-Low INT | Interrupt |
| 4 | -- | 67 | -- | Internal | -- | Internal to Package |
| 4 | -- | 68 | -- | Internal | -- | Internal to Package |
| 4 | U16 | 69 | TEST | Input | TEST | Test |
| 4 | -- | 70 | A8XCLK | Output | -- | Internal to Package |
| 4 | K2 | 71 | LIUC | Input | LIUC | Line Interface Connect |
| 4 | P2 | 72 | BTS | Input | BTS | Bus Type Select |
