Analog Switches Operate With 3
电源设计应用
455人已加入
Abstract: By adding a voltage doubler and voltage inverter, a single 3V or 5V power supply can produce the voltages necessary to improve the performance on a dual voltage analog switch. With the higher power supplies and wider range, the on resistance and timing performance are enhanced.
By adding a single component to a 3V-only or 5V-only board, you can operate conventional CMOS analog switches with performance approaching that specified with ±15V supplies. This means fast switching, low on-resistance, CMOS/TTL compatibility, low power consumption, and a signal range (±VCC) that exceeds the input supply range (VCC to ground).
Simply add a charge-pump voltage converter (IC1), which produces ±2VCC outputs from a VCC input. These unregulated voltages ensure reliable switch operation for VCC levels as low as 3V. Logic thresholds for the switch remain unaffected.
Operate
Figure 1. The charge pump (IC1) provides a local bipolar power supply for the CMOS analog switch (IC2).
A VCC of 3V (for instance) produces ±6V rails for the switch (IC2), resulting in on-resistance <30Ω W, switching times <200ns, leakage <0.1nA, and ICC current <0.5mA. Raising VCC to 5V produces ±10V rails, resulting in on-resistance <20Ω W, switching times <150ns, leakage <0.4nA, and ICC current <1.3mA.
IC1 can easily power additional switches and/or low-power op amps, but more than a few milliamps of load current degrades performance by lowering the unregulated supply rails.
  • 相关推荐
  • 热点推荐
  • Operate
