通信设计应用
| Part | RAM Density | VCC (V) |
| DS1642 | 2k × 8 | 5 |
| DS1643 | 8k × 8 | 5 |
| DS1644 | 32k × 8 | 5 |
| DS1646 | 128k × 8 | 5 |
| DS1647 | 512k × 8 | 5 |
| DS1742 | 2k × 8 | 3.3 or 5 |
| DS1743 | 8k × 8 | 3.3 or 5 |
| DS1744 | 32k × 8 | 3.3 or 5 |
| DS1746 | 128k × 8 | 3.3 or 5 |
| DS1747 | 512k × 8 | 3.3 or 5 |
/**********************************************************************/ /* DS1644.c - Access DS1644/6, DS1744/6 using Reference RTC circuit */ /* This program if for example only and is not supported by Dallas */ /* Semiconductor Maxim. */ /**********************************************************************/ #include/* Prototypes for I/O functions */ #include /* Register declarations for DS5000 */ #include /* needed to define xdata addresses */ #include /************************* bit definitions ****************************/ /***************************** Defines ********************************/ /************************* Global Variables ***************************/ uchar yr, mn, dt, dy, hr, min, sec, day; unsigned int MAXADD; sbit RSTb = P2^7; sbit IRQb = P2^6; sbit AD16 = P1^5; sbit AD17 = P1^6; sbit AD18 = P1^7; /*********************** Function Prototypes **************************/ void writereg(); void init_rtc(); void Disp_Clk_Regs(); void ramread(); void ramwrite(); void toggle_ft(); void init_rtc() /* ------------ set the time and date ----------------- */ /* Note: NO error checking is done on the user entries! */ { uchar tmp; printf("\nEnter the year (0-99): "); scanf("%bx", &yr); printf("Enter the month (1-12): "); scanf("%bx", &mn); printf("Enter the date (1-31): "); scanf("%bx", &dt); printf("Enter the day (1-7): "); scanf("%bx", &dy); printf("Enter the hour (1-23): "); scanf("%bx", &hr); printf("Enter the minute (0-59): "); scanf("%bx", &min); printf("Enter the second (0-59): "); scanf("%bx", &sec); AD16 = AD17 = AD18 = 1; XBYTE[0xfff8] = 0x80; /* set write bit for write */ XBYTE[0xfff9] = sec; XBYTE[0xfffa] = min; XBYTE[0xfffb] = hr; XBYTE[0xfffc] = dy; XBYTE[0xfffd] = dt; XBYTE[0xfffe] = mn; XBYTE[0xffff] = yr; XBYTE[0xfff8] = 0; /* clear write bit to allow update */ } void Disp_Clk_Regs() /* ----------------------------------------- */ { uchar msec, Sec, prv_sec = 99, Min, Hrs, Dte, Mon, Day, Yr; AD16 = AD17 = AD18 = 1; printf("\nYr Mn Dt Dy Hr:Mn:Sec"); while(!RI) /* Read & Display Clock Registers */ { XBYTE[0xfff8] = 0x40; /* set read bit to stop updates */ Sec = XBYTE[0xfff9]; Min = XBYTE[0xfffa]; Hrs = XBYTE[0xfffb]; Day = XBYTE[0xfffc]; Dte = XBYTE[0xfffd]; Mon = XBYTE[0xfffe]; Yr = XBYTE[0xffff]; XBYTE[0xfff8] = 0; /* clear read bit to resume updates */ delay(3); /* must allow time for transfer to occur */ if(Sec != prv_sec) /* display every time seconds change */ { printf("\n%02.bX %02.bX %02.bX %02.bX", Yr, Mon, Dte, Day); printf(" %02.bX:%02.bX:%02.bX", Hrs, Min, Sec); } prv_sec = Sec; } RI = 0; /* Swallow keypress to exit loop */ } void ramread() /* ------------ Read RAM ------------- */ { unsigned int j; AD16 = AD17 = AD18 = 0; for (j = 0; j <= MAXADD; j++) { if(j != 0 && !(j % 256) ) { printf("\nPress a key or Esc to exit "); if( _getkey() == 0x1b) return; } if(!(j % 16)) printf("\n%bx%04x ", (uchar) AD16, j); printf("%02.bx ", (uchar) XBYTE[j]); if (j == 0xffff) break; } if(MAXADD == 0xffff) { printf("\nPress a key or Esc to exit "); if( _getkey() == 0x1b) return; AD16 = 1; for (j = 0; j <= MAXADD; j++) if(j != 0 && !(j % 256) ) { printf("\nPress a key or Esc to exit "); if( _getkey() == 0x1b) break; } if(!(j % 16)) printf("\n%bx%04x ", (uchar) AD16, j); printf("%02.bx ", (uchar) XBYTE[j]); if (j == 0xffff) break; } } } void ramwrite() /* ------------- write with incrementing data ------------- */ { unsigned int j; uchar offset = 0; if(MAXADD == 0xFFFF) { AD16 = AD17 = AD18 = 0; for (j = 0; j <= MAXADD; j++) { XBYTE[j] = (uchar) ( (j & 0xff) + offset); if( (j & 0xff) == 0xff) offset++; if(j == 0xffff) break; } } AD16 = 1; offset = 0; for (j = 0; j < (MAXADD - 7); j++) { XBYTE[j] = (uchar) ( (j & 0xff) + offset); if( (j & 0xff) == 0xff) offset++; } } void ramfill(uchar dat) /* ------------- fill with fixed data ------------- */ { unsigned int j; if(MAXADD == 0xFFFF) { AD16 = AD17 = AD18 = 0; for (j = 0; j <= MAXADD; j++) { if(j & 0x100) XBYTE[j] = dat ^ 0xFF; else XBYTE[j] = dat; if(j == 0xffff) break; } } AD16 = 1; for (j = 0; j < (MAXADD - 7); j++) /* don't disturb time & date */ { if(j & 0x100) XBYTE[j] = dat ^ 0xFF; else XBYTE[j] = dat; } } void toggle_ft() /* -------- toggle the Frequency Test bit --------- */ { uchar creg; AD16=1; creg = XBYTE[0xfffc]; if( (creg & 0x40) ) /* check FT bit */ { XBYTE[0xfff8] = 0x80; /* set write bit for write */ XBYTE[0xfffc] = (creg & 0xbf); /* clear FT bit */ XBYTE[0xfff8] = 0; /* clear write bit */ } else { XBYTE[0xfff8] = 0x80; /* set write bit for write */ XBYTE[0xfffc] = (creg | 0x40); /* set FT bit */ XBYTE[0xfff8] = 0; /* clear write bit */ } } main (void) /* ----------------------------------------------------- */ { uchar i, M, M1; RSTb = 1; printf("\n1) DS1644 or 2) DS1646 ? "); i = _getkey(); if (i == '1') MAXADD = 0x7FFF; if (i == '2') MAXADD = 0xFFFF; while (1) { printf("\nDS1644/6 build 100\n"); printf("CI Init clock CR Read Time\n"); printf("R RAM Fill RR RAM Read\n"); printf("T Toggle FT"); printf("\nEnter Menu Selection:"); M = _getkey(); switch(M) { case 'C': case 'c': printf("\rEnter Clock Routine to run: C"); M1 = _getkey(); switch(M1) { case 'I': case 'i': init_rtc(); break; case 'R': case 'r': Disp_Clk_Regs(); break; } break; case 'R': case 'r': printf("\rFill RAM A)a, 5)5, I)nc data or R)ead: "); M1 = _getkey(); switch(M1) { case '5': ramfill(0x55); break; case 'A': case 'a': ramfill(0xaa); break; case 'R': case 'r': ramread(); break; case 'I': case 'i': ramwrite(); break; } break; case 'T': case 't': toggle_ft(); break; } } }
