解读实时时钟寄存器-Interpreting Real-Ti
通信设计应用
65人已加入
Abstract: This application note describes the format used for Maxim Real-Time Clock (RTC) time and date registers.
Maxim RTCs (real-time clocks) provide both current clock and calendar information to the end user. Many of these RTCs have a time/date alarm function that can be programmed for periodic timed alarms or for a specific one-time calendar alarm. This application note is intended to ease the implementation of Maxim RTCs through detailed discussions and examples of how to properly configure and use the clock, calendar, and alarm functions. Discussions of Timekeeping or Alarm Register contents will reference decimal equivalents of time/date data contained within, unless otherwise specified.
RTC Clock and Calendar Functions
Maxim RTCs provide both clock and calendar functions. Illogical settings will not produce predictable results. The RTC algorithms for clock and calendar counter functions are based on valid data being entered into the respective registers. The old engineering saying of "garbage in, garbage out" holds true here. From both cost and size perspectives, there are no extensive checks and balances for the data entered into any of the Timekeeping Registers used to generate clock and calendar data. It is left to the user's discretion to enter only valid clock and calendar information into the RTC Timekeeping Registers.
Table 1. Typical RTC Timekeeping Registers
Register Address/Command Register Definition
FUNCTION
A7 A6 A5 A4 A3 A2 A1 A0 VALUE D7 D6 D5 D4 D3 D2 D1 D0
CLOCK
SEC 1 0 0 0 0 0 0 RD 00-59 0 10SEC 1SEC
              /W *POR STATE 0 0 0 0 0 0 0 0
MIN 1 0 0 0 0 0 1 RD 00-59 0 10MIN 1MIN
HR 1 0 0 0 0 1 0 RD 01-12 12/24 0 10R 10HR 1HR
              /W 00-23 1/0 A/P 0/1
DATE 1 0 0 0 0 1 1 RD 01-28/29
01-30
01-31
0 0 10 DATE 1 DATE
              /W *POR STATE 0 0 0 0 0 0 0 1
MONTH 1 0 0 0 1 0 0 RD 01-12 0 0 0 10 M 1 MONTH
DAY 1 0 0 0 1 0 1 RD 01-07 0 0 0 0 0 WEEKDAY
YEAR 1 0 0 0 1 1 0 RD 00-99 10 YEAR 1 YEAR
              /W *POR STATE 0 1 1 1 0 0 0 0
CONTROL 1 0 0 0 1 1 1 RD   WP 0 0 0 0 0 0 0
TRICKLE
CHARGER
1 0 0 1 0 0 0 RD   TCS TCS TCS TCS DS DS RS RS
CENTURY 1 0 0 1 0 0 1 RD 0-99 1000 YEAR 100 YEAR
              /W *POR STATE 0 0 0 1 1 0 0 1
ALARM
CONFIG
1 0 0 1 0 1 0 RD   0 YEAR DAY MONTH DATE HR MIN SEC
TEST
CONFIG
1 0 0 1 0 1 1 RD   0 0 0 0 0 1 1 1
              /W *POR STATE 0 0 0 0 0 1 1 1
Note: *POR STATE defines the Power-On Reset state of register content.
Seconds Register
The Timekeeping Seconds Register contains the current time count from the seconds counter. The seconds-counter output ranges from 00 to 59 seconds and carries over to 00 on the next 1-second count following a previous count of 59. Seconds data is contained in D6 through D0, and BCD format applies to those data bits. D7 is used in some RTCs for a status or control bit. In those RTCs, reads to and writes from the Seconds Register must mask D7 and interpret only D6 through D0 as seconds data, as shown below.
Table 2. Timekeeping Seconds Register
Seconds Register D7 D6 D5 D4 D3 D2 D1 D0
  0 10SEC (BCD 0-5) (Decimal 0-5) 1SEC (BCD 0-9) (Decimal 0-9)
Min Binary Count 0 0 0 0 0 0 0 0
Max Binary Count 0 1 0 1 1 0 0 1
Note: Valid seconds data = 00 to 59
Minutes Register
The Timekeeping Minutes Register contains the current time count from the minutes counter. The minutes-counter output ranges from 00 to 59 minutes and carries over to 00 on the next 1-minute count following a previous count of 59. Minutes data is contained in D6 through D0, and BCD format applies to those data bits. D7 is used in some RTCs for a status or control bit. In those RTCs, reads to and writes from the Minutes Register must mask D7 and interpret only D6 through D0 as minutes data, as shown below.
Table 3. Timekeeping Minutes Register
Minutes Register D7 D6 D5 D4 D3 D2 D1 D0
  0 10MIN (BCD 0-5) (Decimal 0-5) 1MIN (BCD 0-9) (Decimal 0-9)
Note: Valid minutes data = 00 to 59
Hours Register
The Timekeeping Hours Register contains the current time count from the hours counter. There are two operating modes for the Hours Register: 12-hour format and 24-hour format. The interpretation of D5 depends on the hour format selected in D7.
Table 4. Timekeeping Hours Register
Hours Register D7 D6 D5 D4 D3 D2 D1 D0
  12/24 0 10HR 10HR 1HR
  1/0   A/P 0/1
D7, the 12/24 format bit set to a 0, configures the hours counter for 24-hour format. D5 is used as the upper bit in the 10-hour BCD format. Hours data in the 24-hour format is contained in D5 through D0, and BCD format applies to those data bits. In this mode, the hours-counter output ranges from 00 to 23 hours and carries over to 00 on the next 1-hour count following a previous count of 23.
Table 5. Timekeeping Hours Resister: 24-Hour Format
Hours Register (24HR Format) D7 D6 D5 D4 D3 D2 D1 D0
  0(24HR) 0 10HR (BCD 0-2) (Decimal 0-2) 1HR (BCD 0-3) (Decimal 0-3)
Max Binary Count 0 0 1 0 0 0 1 1
Note: Valid hour data (24-hour format) = 00 to 23
D7, the 12/24 format bit set to a 1, configures the hours counter for 12-hour format. D5 is used as the AM/PM indicator with 1 = PM and 0 = AM. Hours data in the 12-hour AM format or in the 12-hour PM format is contained in D4 through D0, and BCD format applies to those data bits. In this mode, the hours-counter output ranges from 01 to 12 hours and carries over to 01 on the next 1-hour count following a previous count of 12. In addition, the AM/PM bit changes on the hour increment from 11 PM (D5 = 0) to 12 AM (D5 = 1) and from 11 AM (D5 = 1) to 12 PM (D5 = 0).
Table 6. Timekeeping Hours Register: 12-Hour AM Format
Hours Register (12HR AM Format) D7 D6 D5 D4 D3 D2 D1 D0
  1 (12HR) 0 0 (AM) 10HR (BCD 0-1) (Decimal 0-1) 1HR (BCD 1-2) (Decimal 1-2)
Min Binary Count 1 0 0 0 0 0 0 1
Max Binary Count 1 0 0 1 0 0 1 0
Note: Valid hour data (12-hour format) =01 to 12
Table 7. Timekeeping Hours Register: 12-Hour PM Format
Hours Register (12HR PM Format) D7 D6 D5 D4 D3 D2 D1 D0
  1 (12HR) 0 1 (PM) 10HR (BCD 0-1) (Decimal 0-1) 1HR (BCD 1-2) (Decimal 1-2)
Date Register
The Timekeeping Date Register contains the current calendar day of the month from the date counter. The counter-output range is dependent on the current value of the Month Register, Year Register, and Century Register. The date-counter range is 01 to 28, 01 to 29, 01 to 30, or 01 to 31. At maximum count, the date counter carries back to 01 on the next day increment computed from the Hours Register. Date data is contained in D5 through D0, and BCD format applies to those data bits. If D6 and D7 are always 0, which is the case for most Maxim RTCs, then BCD format applies for the entire Date Register.
Table 8. Timekeeping Date Register
Date Register D7 D6 D5 D4 D3 D2 D1 D0
  0 0 10 DATE (BCD 0-3) (Decimal 0-3) 1 DATE (BCD 1-9) (Decimal 1-9)
Min Binary Count 0 0 0 0 0 0 0 1
Max Binary Count 0 0 1 1 0 0 0 1
Note: Valid date data = 01 to 31, 01 to 30, 01 to 29, 01 to 28
Table 9. Counting Range of Date Counter
Range Carry Month Register
(BCD)
Year and Century
Register
01 to 31   01 (January)
03 (March)
05 (May)
07 (July)
08 (August)
10 (October)
12 (December)
N/A
01 to 30   04 (April)
06 (June)
09 (September)
11 (November)
N/A
01 to 29   02 (February) Divide by 4 with no remainder
01 to 28   02 (February) Divide by 4 with remainder
Month Register
The Timekeeping Month Register contains the current time count from the month counter. The month-counter output ranges from 01 to 12 months and carries over to 01 on the next 1-month count following a previous count of 12. Month data is contained in D4 through D0, and BCD format applies to those data bits. If D7, D6, and D5 are always 0, which is the case for most Maxim RTCs, then BCD format applies for the entire Date Register.
Table 10. Timekeeping Month Register
Month Register D7 D6 D5 D4 D3 D2 D1 D0
  0 0 0 10 M (BCD 0-1)
(Decimal 0-1)
1 MONTH (BCD 0-9) (Decimal 0-9)
Max Binary Count 0 0 0 1 0 0 1 0
Note: Valid month data = 01 to 12
Table 11. Month Register (BCD)
Month Register
(BCD)
Month
01 January
02 February
03 March
04 April
05 May
06 June
07 July
08 August
09 September
10 October
11 November
12 December
Day Register
The Timekeeping Day Register (day of the week) contains the current weekday count from the day counter. The day-counter output ranges from 01 to 07 days and carries over to 01 on the next 1-day count following a previous count of 07. Weekday data is contained in D4 through D0, and BCD format applies to those data bits. If D7 through D3 are always 0, which is the case for most Maxim RTCs, then BCD format applies for the entire Day Register.
Table 12. Timekeeping Day Register
Day Register D7 D6 D5 D4 D3 D2 D1 D0
  0 0 0 0 0 WEEKDAY (BCD 1-7) (Decimal 1-7)
Max Binary Count 0 0 0 0 0 1 1 1
Note: Valid day data = 01 to 07
Year Register
The Timekeeping Year Register contains the current units and 10's count for the year counter. The year-counter output ranges from 00 to 99 and carries over to 00 on the next 1-year count following a previous count of 99. The current year units' count is contained in D3 through D0 in BCD format. The current year 10's count is contained in D7 through D4 in BCD format.
Table 13. Timekeeping Year Register
Year Register D7 D6 D5 D4 D3 D2 D1 D0
  10 YEAR (BCD 0-9) (Decimal) 1 YEAR (BCD 0-9) (Decimal 0-9)
Max Binary Count 1 0 0 1 1 0 0 1
Note: Valid year data = 00 to 99
Century Register
The Timekeeping Century Register contains the current thousand's and hundred's count for the century counter. The century-counter output ranges from 00 to 99 and carries over to 00 on the next 1-century count following a previous count of 99. The current year thousand's count is contained in D7 through D4 in BCD format. The current year hundred's count is contained in D3 through D0 in BCD format.
Table 14. Timekeeping Century Register
Century Register D7 D6 D5 D4 D3 D2 D1 D0
  1000 YEAR 100 YEAR
Note: Valid century data = 00 to 99
Time/Date Example
Table 15. Register Contents for March 26, 2001; Monday; 11:24:36 PM (23:24:36 hours)
Hex Data BCD
Data
Decimal Timekeeping
Contents
Register/
Binary Data
Seconds Seconds Seconds Seconds 0 10SEC 1SEC
36h 36 36 Binary 0 0 1 1 0 1 1 0
Minutes Minutes Minutes Minutes 0 10MIN 1MIN
24h 24 24 Binary 0 0 1 0 0 1 0 0
Hour (24HR Format) Hour (24HR Format) Hour (24HR Format) Hour (24HR Format) 12/24 (0/1) 0 10
HR
10
HR
1HR
A3h A3 23 Binary 1 0 1 0 0 0 1 1
Hour (12HR Format) Hour (12HR Format) Hour (12HR Format) Hour (12HR Format) 12/24 (0/1) 0 A/P (0/1) 10
HR
1HR
31h 31 11 PM Binary 0 0 1 1 0 0 0 1
Date Date Date Date 0 0 10 DATE 1 DATE
26h 26 26 Binary 0 0 1 0 0 1 1 0
Month Month Month Month 0 0 0 10 M 1 MONTH
03h 03 3 (March) Binary 0 0 0 0 0 0 1 1
Day Day Day Day 0 0 0 0 0 WEEKDAY
02h 02 2 (Monday) Binary 0 0 0 0 0 0 1 0
Year Year Year Year 10 YEAR   1 YEAR
01h 01 01 Binary 0 0 0 0 0 0 0 1
Century Century Century Century 1000 YEAR 100 YEAR
20h 20 20 Binary 0 0 1 0 0 0 0 0
RTC Alarm Function
For Maxim RTCs that provide an alarm function, there are a variety of possible configurations for the alarm settings. Illogical settings will not produce predictable results. From both cost and size perspectives, there are no extensive checks and balances for the data entered into the Alarm Configuration or Alarm Threshold Registers. It is left to the user's discretion to enter only valid clock and calendar information into the RTC Alarm Registers.
RTC Alarm Configuration Register
The RTC Alarm Configuration Register contains bits for programming when a date/time alarm occurs.
Table 16. Alarm Configuration Register
FUNCTION A7 A6 A5 A4 A3 A2 A1 A0 VALUE D7 D6 D5 D4 D3 D2 D1 D0
CLOCK
ALARM CONFIG 1 0 0 1 0 1 0 RD   0 YEAR DAY MONTH DATE HR MIN SEC
A logic 0 in any bit does not enable a comparison of the respective Alarm Threshold Register with the associated timekeeping-counter output for that respective time unit. A logic 1 enables the comparison. Each bit set to a logic 1 in the Alarm Configuration Register must have conditions satisfied for the alarm to occur. For example, if D0, seconds bit, is set to 1 and D1, minutes bit, is set to 1, then the alarm will occur every time the timekeeping counter matches both the count stored in the Seconds Threshold Register and the count stored in the Minutes Threshold Register.
When the Alarm Threshold Registers, which have been selected by the Alarm Configuration Register, match their respective timekeeping-counter outputs, the alarm will trigger with a typical 3mS delay. Once the alarm is triggered, it can be cleared by writing or reading to any Alarm Threshold Register or by reading or writing to the Alarm Configuration Register.
Because the alarm-trigger function is an edge-triggered logic, the alarm only occurs once each time the respective counter reaches the count that matches the respective Alarm Threshold Register setting. For example, set the Alarm Configuration Register to only minutes by setting D1 to logic 1 and all other data bits to zero. Now, in the Alarm Threshold Minutes Register, set its LSB to 1 and all other bits to zero. This configures the RTC alarm logic to trigger every time the minutes counter transitions from 00 to 01. The first transition of the minutes counter from 00 to 01 sets the alarm. If the alarm is now cleared by reading or writing to the Alarm Configuration Register or any of the Alarm Threshold Registers, it will not be reset again until the next edge transition of the minutes counter from 00 to 01, regardless of whether or not the output of the minutes counter is still at 01.
Typical RTC Alarm Threshold Registers are shown below. The Alarm Threshold Registers (Year, Day, Month, Date, Hours, Minutes, Seconds) have the same data configuration as their respective Timekeeping Register counterparts, described in detail earlier.
Table 17. Typical RTC Alarm Registers
Register/Address Command Register Definition
ALARM THRESHOLDS
SEC 1 0 0 1 1 0 0 RD 00-59 0 10SEC 1SEC
              /W *POR STATE 0 1 1 1 1 1 1 1
MIN   1 0 0 1 1 0 1 RD 00-59 0 10MIN 1MIN
HR   1 0 0 1 1 1 0 RD 01-12 12/24 0 10
HR
10
HR
  1HR
                *POR STATE 1 0 1 1 1 1 1 1
DATE 1 0 0 1 1 1 1 RD 01-28/29
01-30
01-31
0 0 10 DATE   1 DATE
              /W *POR STATE 0 0 1 1 1 1 1 1
MONTH 1 0 1 0 0 0 0 RD 01-12 0 0 0 10 M 1 MONTH
              /W *POR STATE 0 0 0 1 1 1 1 1
DAY 1 0 1 0 0 0 1 RD 01-07 0 0 0 0 0 WEEKDAY
YEAR   1 0 1 0 0 1 0 RD 00-99 10 YEAR   1 YEAR
              /W *POR STATE 1 1 1 1 1 1 1 1
CLOCK BU/RST 1 0 1 1 1 1 1 RD
              /W
RAM (VBATT Backed Up)
RAM 0
1 1 0 0 0 0 0 RD RAM DATA 0 x x x x x x x x
              /W
RAM 30   1 1 1 1 1 1 0 RD RAM DATA 30 x x x x x x x x
              /W
RAM BU/RST 1 1 1 1 1 1 1 RD
              /W
Note: *POR STATE defines the Power-On Reset state of register contents.
There are 128 possible alarm settings using the Alarm Configuration Register. Not all of these possible combinations are logical or cause the desired effect for triggering the alarm (for example, setting an alarm to trigger every April 31). A few common examples are presented in detail below as guidance in correctly configuring the Alarm Configuration Register and the Alarm Threshold Registers.
Table 18. Summary of Common Examples
Example D7 D6 Year D5 Day D4 Month D3 Date D2 Hours D1 Minutes D0 Seconds Alarm Occurrence (when threshold-register contents match respective timekeeping-counter output)
1 0 0 0 0 0 0 0 1 Once every Seconds match (e.g., once a minute @ 30 seconds count)
2 0 0 0 0 0 0 1 0 Once every Minutes match (e.g., once an hour @ 45 minutes count)
3 0 0 0 0 0 1 0 0 Once every Hours* match (e.g., once a day - every 24 hours @11 PM)
4 0 0 0 0 0 1 1 1 Once every Hours*, Minutes, and Seconds match (e.g., once a day - every 24 hours @ specific time of day)
5 0 0 0 0 1 0 0 0 Once every Date match (e.g., once a month)
6 0 0 1 0 0 0 0 0 Once every Day match (e.g., once a week - every Monday)
7 0 0 0 1 0 0 0 0 Once every Month match (e.g., once/year - every March 1 @ 12 AM)
8 0 0 0 1 1 1 1 1 Once every Time, Date, and Month (Month, Date, Hours*, Minutes, Seconds) match (e.g., once a year - specific month, date, time of day*)
9 0 1 0 1 1 1 1 1 Once every Time, Date, Month, and Year match (e.g., one-time alarm set - specific month, date, year, time of day*)
Note: *The Alarm Threshold Register must use the same hour format (12-hour or 24-hour) as the Timekeeping Register, otherwise the alarm function will not operate properly.
Alarm Example 1: Triggering the Alarm Once Every Minute @ 30-Seconds Count
Once every Seconds match. Only the Alarm Threshold Seconds Register is set, and all other Alarm Threshold Registers (Year, Day, Month, Date, Hours, Minutes) have their internal bits set to logic 0.
Set the alarm to trigger once every minute at the 30-seconds count.
Table 19. Register Contents for the Alarm Trigger Every Minute @ 30-Seconds Count
Hex Data BCD Data Decimal Timekeeping Contents Register/Binary Data D7 D6 D5 D4 D3 D2 D1 D0
30h 30 30 Binary 0 0 1 1 0 0 0 0
Alarm Example 2: Triggering the Alarm Once Every Hour @ 45-Minutes Count
Once every Minutes match. Only the Alarm Threshold Minutes Register is set, and all other Alarm Threshold Registers (Year, Day, Month, Date, Hours, Seconds) have their internal bits set to logic 0.
Set the alarm to trigger once every hour at the 45-minutes count.
Table 20. Register Contents for the Alarm Trigger Every Hour @ 45-Minutes Count
45h 45 45 Binary 0 1 0 0 0 1 0 1
Alarm Example 3: (24-Hour Format): Triggering the Alarm Once a Day @; 23:00:00 Hours
Once every Hours match. Only the Alarm Threshold Hours Register is set, and all other Alarm Threshold Registers (Year, Day, Month, Date, Minutes, Seconds) have their internal bits set to logic 0. The Alarm Threshold Hour Register must use the same hour format (12-hour or 24-hour) as the Timekeeping Hour Register, otherwise the alarm function will not operate properly.
Set the alarm to trigger every 24 hours (once a day) at 23:00:00 hours.
Table 21. Register Contents for the Alarm Trigger Every 24 Hours @ 23:00:00 Hours
Hour (24HR Format) Hour (24HR Format) Hour (24HR Format) Hour (24HR Format) 12/24 (0/1)   0 10HR 10HR 1HR
Alarm Example 3: (12-Hour Format): Triggering the Alarm Once a Day @ 11 PM
Set the alarm to trigger every 24 hours (once a day) at 11 PM.
Table 22. Register Contents for the Alarm Trigger Every 24 Hours @ 11 PM
Hour (12HR Format) Hour (12HR Format) Hour (12HR Format) Hour (12HR Format) 12/24 (0/1)  0 A/P (0/1) 10HR 1HR
Alarm Example 4: (24-Hour Format): Triggering the Alarm Once a Day @ 23:24:36 Hours
Once every Hours, Minutes, and Seconds match. Only the Alarm Threshold Hours Register, Minutes Register, and Seconds Register are set, and all other Alarm Threshold Registers (Year, Day, Month, Date) have their internal bits set to logic 0. The Alarm Threshold Hour Register must use the same hour format (12-hour or 24-hour) as the Timekeeping Hour Register, otherwise the alarm function will not operate properly.
Set the alarm to trigger every 24 hours (once a day) at 23:24:36 hours.
Table 23. Register Contents for the Alarm Trigger Every 24 Hours @ 23:24:36 Hours
Alarm Example 4: (12-Hour Format): Triggering the Alarm Once a Day @ 11:24:36 PM
Table 24. Register Contents for the Alarm Trigger Every 24 Hours @ 11:24:36 PM
A3h A3 23 Binary 0 0 1 1 0 0 0 1
Alarm Example 5: Triggering the Alarm Once a Month on the 26th Day
Once every Date match. Only the Alarm Threshold Date Register is set, and all other Alarm Threshold Registers (Year, Day, Month, Hours,Minutes, Seconds) have their internal bits set to logic 0. Because it is desired for the alarm to trigger each month on the same date, a valid date that exists in each month should be chosen, otherwise the alarm will not trigger during a month that does not contain the particular date (for example, 31 does not exist in June).
Set the alarm to trigger on the 26th day of every month at 12:00:00 AM.
Table 25. Register Contents for the Alarm Trigger Every Month on the 26th Day of the Month @ 12:00:00 AM
Alarm Example 6: Triggering the Alarm Once a Week Every Monday @ 12:00:00AM
Once every Day match. Only the Alarm Threshold Day Registeris set, and all other Alarm Threshold Registers (Year, Month, Date, Hours, Minutes, Seconds) have their internal bits set to logic 0.
Set the alarm to trigger once per week on Monday at 12:00:00 AM.
Table 26. Register Contents for the Alarm Trigger Every Week on Monday @ 12:00:00 AM
Alarm Example 7: Triggering the Alarm Once a Year Every March 1 @ 12:00:00 AM
Once every Month match. Only the Alarm Threshold Month Register is set, and all other Alarm Threshold Registers (Year, Day, Date, Hours, Minutes, Seconds) have their internal bits set to logic 0.
Set the alarm to trigger once per year on March 1 at 12:00:00 AM.
Table 27. Register Contents for the Alarm Trigger Every Year on March 1 @ 12:00:00 AM
Alarm Example 8: (24-Hour Format): Triggering the Alarm Once a Year Every March 26 @ 23:24:36 Hours
Once every Time, Date, and Month match. Only the Alarm Threshold Month, Date, Hours, Minutes, and Seconds Registers are set, and the other Alarm Threshold Registers (Year, Day) have their internal bits set to logic 0. Because it is desired for the alarm to trigger each year on the same date, a valid date that exists in each month should be chosen, otherwise the alarm will not trigger during a month that does not contain the particular date (for example, 31 does not exist in June).
Set the alarm to trigger once per year on March 26 @ 23:24:36 hours.
Table 28. Register Contents for the Alarm Trigger Every Year on March 26 @ 23:24:36 Hours
Alarm Example 8: (12-Hour Format): Triggering the Alarm Once a Year Every March 26 @ 11:24:36 PM
Set the alarm to trigger once per year on March 26 @ 11:24:36 hours.
Table 29. Register Contents for the Alarm Trigger Every Year on March 26 @ 11:24:36 PM
Alarm Example 9: (24-Hour Format): Triggering the Alarm Once on March 26, 2099 @ 23:24:36 Hours
Once on Time, Date, Month, and Year match. The Alarm Threshold Year, Month, Date, Hours, Minutes, and Seconds Registers are set, and the Alarm Threshold Day Register has its internal bits set to logic 0.
Set the alarm to trigger on March 26, 2099, @ 23:24:36 hours. This assumes, of course, that the Century Register was programmed for 20 (BCD format).
Table 30. Register Contents for the Alarm Trigger on March 26, 2099, @ 23:24:36 Hours
99h 99h 99h Binary 1 0 0 1 1 0 0 1
Alarm Example 9: (12-Hour Format): Triggering the Alarm Once on March 26, 2099 @; 11:24:36 PM
Set the alarm to trigger on March 26, 2099 @ 11:24:36 PM. This assumes, of course, that the Century Register was programmed for 20 (BCD format).
Table 31. Register Contents for the Alarm Trigger on March 26, 2099, @ 11:24:36 PM
