嵌入式设计应用
// Generate a long delay for card reset and read intervals.
void longDelay()
int i, j;
for (i = 1; i < 5; i++) {
for (j = 1; j < 5000; j++) {
// Generate a shorter delay (used between STROBE/DATA transitions).
void delay()
int i;
for (i = 1; i < 1000; i++) {
// Release the DATA line (P0.0) and allow it to float high.
void dataHigh()
P0 |= 0x01;
delay();
// Drive the DATA line (P0.0) low.
void dataLow()
P0 &= 0xFE;
delay();
// Release the STROBE line (P0.1) and allow it to float high.
void strobeHigh()
P0 |= 0x02;
delay();
// Drive the STROBE line (P0.1) low.
void strobeLow()
P0 &= 0xFD;
delay();
void resetCardReader()
dataHigh();
strobeHigh();
longDelay();
dataLow(); // Force DATA low.
longDelay();
strobeLow(); // Drive STROBE low, then high again.
strobeHigh();
strobeLow(); // Drive STROBE low, then release DATA.
dataHigh();
longDelay();
strobeHigh(); // Drive STROBE low and high again two more times
strobeLow(); // to complete the reset and leave the card reader
strobeHigh(); // in the ready state, prepared to scan a card.
strobeLow();
// Wait for the DATA line to be driven low by the card reader.
void waitForDataLow()
int i = 0xFF;
dataHigh(); // Make sure that DATA is floating high.
while ((i & 1) == 1) {
i = P0;
resetCardReader();
printf("\r\n");
printf("Waiting for card swipe...\r\n");
printf("\r\n");
waitForDataLow(); // DATA low indicates that card swipe has begun.
strobeHigh();
longDelay();
strobeLow();
longDelay();
waitForDataLow(); // DATA low indicates that card swipe is complete.
// Clock a single bit value out of the card reader by driving STROBE high,
// then low, and reading the DATA line.
int readBit()
int i;
strobeHigh(); // Drive STROBE high.
strobeLow(); // Drive STROBE low (DATA line now contains bit).
i = P0;
if ((i & 1) == 0) {
return 1; // Low on DATA line indicates a 1 bit.
} else {
return 0; // High on DATA line indicates a 0 bit.
读卡器同步输出的前16位是“前导”位,指出读卡器ASIC的版本。这些为并非卡的数据,应用程序可以忽略它们。// 0123456789012345678901234567890123456789012345678901234567890 123
char char7bit[64] =
" !'#$%&'()*+,-./0123456789:;<=>?@ABCDEFGHIJKLMNOPQRSTUVWXYZ[\\]^_";
// Clock out and decode a 7-bit character from the track memory, returning the
// character value. 7-bit (alphanumeric) characters are found on Track A only.
char read7BitChar()
int i, c;
// Each character is composed of 7 bits, which we clock out of the track memory
// beginning with the least significant bit. Bit 7 is parity, which is ignored.
c = 0;
for (i = 1; i < 128; i *= 2) {
c |= (readBit() * i);
c &= 0x3F;
return char7bit[c]; // Decode/return the character using the 7-bit table.
// Track A - 76 characters, 7 bits per alphanumberic character including parity.
printf("Track A > ");
for (i = 0; i < 76; i++) {
putchar(read7BitChar());
printf("\r\n\r\n");
// At this point, we have read 532 bits of the 704-bit Track A memory on the
// card reader IC. Flush the remaining 172 bits.
for (i = 0; i < 172; i++) {
readBit();
不同类型的卡在磁道A上有不同的数据。磁道A还可以含有字母字符。因此,磁道A常用于存储持卡人的姓名、地址和账号等数字信息。正如上面代码所示,在同步输出磁道B的数据之前,必须读出磁道A的所有704位数据(即使并非所有位都含有编码数据)。// 0123456789012345
char char5bit[16] = "0123456789:;<=>?";
// Clock out and decode a 5-bit character from the track memory, returning the
// character value. 5-bit (numeric+symbol) characters are found on Tracks B and C.
char read5BitChar()
int i, c;
// Each character is composed of 5 bits, which we clock out of the track memory
// beginning with the least significant bit. Bit 5 is parity, which is ignored.
c = 0;
for (i = 1; i < 32; i *= 2) {
c &= 0x0F;
return char5bit[c]; // Decode/return the character using the 5-bit table.
// Track B - 40 characters, 5 bits per numeric/symbol character including parity.
printf("Track B > ");
for (i = 0; i < 40; i++) {
putchar(read5BitChar());
printf("\r\n\r\n");
在磁道A的最后,读取磁道C之前,必须读取磁道B的所有剩余位(如果需要用到磁道C)。由于已经从磁道B (40个字符 x 5位)读取了200位,在访问磁道C之前,必须同步输出其余504位。全部0条评论
