通信设计应用
//------------------------------------------------------------------------ // ds1631.c -- Functions for the Dallas Semiconductor DS1631 // Two-Wire Temperature Sensor // Designed for 8051 microcontrollers // This code was developed using the DS5000/DS2250 // //--------------------------------------------------------------------- // command line directives #include// absolute addressing modes #include // character types #include // standard math #include // standard I/O #include // string functions #include // DS5000 series 8051 registers // Configuration parameters #define XtalFreq (11059490) // main crystal frequency #define CntrFreq (XtalFreq/12) // main counter frequency #define BaudRate (9600) // baud rate #define CntrTime (8) // number of cycles for counter #define Ft (32768.0) // target crystal frequency //---------------------------------------------------------------------- //-------------------------------------------------------------------- #ifndef READ #define READ 1 #endif #ifndef WRITE #define WRITE 0 #endif #ifndef I2CCLK #define I2CCLK 0xA0 #endif //global variables unsigned char Config; // Config. Reg. Data float temp_c; // temperature in deg. C float temp_f; // temperature in deg. F float TH; // TH byte float TL; // TL byte unsigned char MSB; // temp byte MSB unsigned char LSB; // temp byte LSB unsigned char Select_Type; // Function variable //Function Prototypes void I2CBitDly(void); void I2CSCLHigh(void); void I2CSendAddr(unsigned char addr, unsigned char rd); void I2CSendByte(unsigned char bt); unsigned char I2CGetByte(unsigned char lastone); void I2CSendStart(void); void I2CSendStop(void); void GetTemp(unsigned char Address); void GetConfig(unsigned char Address); void WriteConfig(unsigned char Address, unsigned char Data); void ReadTHandTL(unsigned char Address); void WriteTHandTL(unsigned char Address, float TH, float TL); //---------------------------------------------------------------------- // MAIN //---------------------------------------------------------------------- //---------------------------------------------------------------------- void main (void) { Select_Type = 0; // initialize command selection //---------------------------------------------------------------------- // Inhibit the watchdog timer and set up memory //---------------------------------------------------------------------- TA = 0xAA; // timed access TA = 0x55; PCON = 0x00; // inhibit watchdog timer //---------------------------------------------------------------------- // Set up the serial port //---------------------------------------------------------------------- SCON = 0x50; // SCON: mode 1, 8-bit UART, enable rcvr TMOD = 0x21; // TMOD: timer 1, mode 2, 8-bit reload // TMOD: timer 0, mode 1, 16-bit PCON |= 0x80; // SMOD = 1 Double Baud Rate for TH1 load TH0=TL0 = 0; TH1=TL0 = (unsigned int)(256 - ( (XtalFreq / BaudRate) / 192)); TR0 = 1; // TR0: timer 0 run TR1 = 1; // TR1: timer 1 run TI = 1; // TI: set TI to send first char of UART //---------------------------------------------------------------------- // Display DS1631 Two-Wire Device banner //---------------------------------------------------------------------- printf ("\n"); printf (" Dallas Semiconductor - Battery Management / Thermal \n"); printf (" This program selects between two DS1631 devices on the same bus\n"); printf (" with the addresses of 0x90h and 0x92h.\n"); printf (" Updated Code October 2002 \n"); printf (" [C Program for DS500x or 8051 Compatible Microcontroller]"); printf("\n\n"); printf("\n********************************************************************\n"); printf (" Select Menu Option\n"); printf (" 0. Read Temperature, Device Address 0x90\n"); printf (" 1. Read Configuration Register, Device Address 0x90\n"); printf (" 2. Write Configuration Register = 00h, Clear Flags, Device Address 0x90\n"); printf (" 3. Read TH and TL Registers, Device Address 0x90\n"); printf (" 4. Write TH=30.5 degrees and Write TL=10, Device Address 0x90\n"); printf (" 5. Read Temperature, Device Address 0x92\n"); printf (" 6. Read Configuration Register, Device Address 0x92\n"); printf (" 7. Write Configuration Register = 00h, Clear Flags, Device Address 0x92\n"); printf (" 8. Read TH and TL Registers, Device Address 0x92\n"); printf (" 9. Write TH=40.5 degrees, Write TL=0.5, Device Address 0x92\n"); printf ("\n\n"); do { Select_Type = getchar(); // wait for selection switch(Select_Type) { case '0': printf ("\n 1. Read Temperature, Device Address 0x90\n"); GetTemp(0x90); break; case '1': printf ("\n 1. Read Config Register, Device Address 0x90\n"); GetConfig(0x90); break; case '2': printf ("\n 2. Write Config Register = 00h, Clear Flags, Device Address 0x90\n"); WriteConfig(0x90, 0x00); break; case '3': printf ("\n 3. Read TH and TL Registers, Device Address 0x90\n"); ReadTHandTL(0x90); break; case '4': printf (" 4. Write TH=30.5 degrees, Device 0: Write TL=10 Device Address 0x90\n"); WriteTHandTL(0x90, 30.5, 10); break; case '5': printf ("\n 5. Read Temperature, Device Address 0x92\n"); GetTemp(0x92); break; case '6': printf ("\n 6. Read Configuration Register, Device Address 0x92\n"); GetConfig(0x92); break; case '7': printf ("\n 7. Write Configuration Register = 00h, Clear Flags, Device Address 0x92\n"); WriteConfig(0x92,0x00); break; case '8': printf ("\n 8. Read TH and TL Registers: Device Address 0x92\n"); ReadTHandTL(0x92); break; case '9': printf ("\n 9. Write TH=40.5 degrees, Device 1: Write TL=0.5 Device Address 0x92\n"); WriteTHandTL(0x92, 40.5, .5); break; default: printf ("\n Select Another Menu Option\n"); break; }; // end switch }while(1); //keep looping }// End Main Program void GetTemp(unsigned char Address) //Pass Address 0x90h or 0x92h { I2CSendAddr(Address,WRITE); // control byte I2CSendByte(0x51); // command byte start conversion I2CSendStop(); // send stop I2CBitDly(); // wait I2CSendAddr(Address,WRITE); // control byte I2CSendByte(0xAA); // command byte read temp I2CSendAddr(Address,READ); // restart control byte and device address MSB = I2CGetByte(0); // Temp MSB LSB = I2CGetByte(1); // Temp LSB I2CSendStop(); // send stop // Calculate Temp if(MSB>=0x80) //if sign bit is set, then temp is negative temp_c = (float)((MSB<<8 + LSB) - 65536) * 0.0625; else temp_c = (float)(MSB<<8 + LSB) * 0.0625; temp_f =( temp_c * 9/5) + 32; //---------------------------------------------------------------------- // Display temp to CRT //---------------------------------------------------------------------- printf( "\nTempC=%5.1f \n", temp_c ); // print temp. C printf( "\nTempF=%5.1f \n", temp_f ); // print temp. F } void GetConfig(unsigned char Address) //Pass Address 0x90h or 0x92h { I2CSendAddr(Address,WRITE); // control byte I2CSendByte(0xAC); // command byte to access config I2CSendAddr(Address,READ); // restart Config = I2CGetByte(1); // Configuration Register I2CSendStop(); // send stop //---------------------------------------------------------------------- // Display Config to CRT //---------------------------------------------------------------------- printf( "\nConfig=%02X \n", Config ); // print Config Register Value } void WriteConfig(unsigned char Address, unsigned char Data) //Pass Address 0x90h or 0x92h { // Write Data to Config Register I2CSendAddr(Address,WRITE); // control byte I2CSendByte (0xAC); // command byte access Config reg. I2CSendByte (Data); // data to send I2CSendStop(); // send stop I2CBitDly(); // wait GetConfig(Address); // Read Config to verify write } void ReadTHandTL(unsigned char Address) //Pass Address 0x90h or 0x92h { //Read TH I2CSendAddr(Address,WRITE); // control byte I2CSendByte(0xA1); // command byte Access TH I2CSendAddr(Address,READ); // control byte read temp MSB = I2CGetByte(0); // read TH MSB LSB = I2CGetByte(1); // read TH LSB I2CSendStop(); // Calculate TH if(MSB>=0x80) //if sign bit is set, then temp is negative TH = (float)((MSB<<8 + LSB) - 65536) * 0.0625; else TH = (float)(MSB<<8 + LSB) * 0.0625; //Read TL I2CSendAddr(Address,WRITE); // control byte I2CSendByte(0xA2); // command byte Access TL I2CSendAddr(Address,READ); // control byte read temp MSB = I2CGetByte(0); // read TL MSB LSB = I2CGetByte(1); // read TL LSB I2CSendStop(); // Calculate TL if(MSB>=0x80) //if sign bit is set, then temp is negative TL = (float)((MSB<<8 + LSB) - 65536) * 0.0625; else TL = (float)(MSB<<8 + LSB) * 0.0625; //---------------------------------------------------------------------- // Display temp to CRT //---------------------------------------------------------------------- printf( "\nTH=%5.1f \n", TH ); // print TH printf( "\nTL=%5.1f \n", TL ); // print TL } void WriteTHandTL(unsigned char Address, float TH, float TL) { //Write TH MSB = ((unsigned char)TH<<8) & 0xFF00; //Get MSB of TH (This assumes TH is >0) LSB = ((unsigned char)TH<<8) & 0xFF; //Get LSB of TH I2CSendAddr(Address,WRITE); // control byte I2CSendByte (0xA1); // Access TH I2CSendByte (MSB); // send MSB I2CSendByte (LSB); // send LSB I2CSendStop(); //end transmission //Write TL MSB = ((unsigned char)TL<<8) & 0xFF00; //Get MSB of TL(This assumes TH is >0) LSB = ((unsigned char)TL<<8) & 0xFF; //Get LSB of TL I2CSendAddr(Address,WRITE); // control byte I2CSendByte (0xA2); // Access TL I2CSendByte (MSB); // send MSB I2CSendByte (LSB); // send LSB I2CSendStop(); //end transmission ReadTHandTL(Address); } void I2CBitDly(void) // wait approximately 4.7uS { // tune to xtal. This works at 11.0592MHz unsigned int time_end = 10; unsigned int index; for (index = 0; index < time_end; index++); return; } void I2CSCLHigh(void) // Set SCL high, and wait for it to go high { register int err; SCL = 1; while (! SCL) { err++; if (!err) { return; } } } void I2CSendAddr(unsigned char addr, unsigned char rd) { I2CSendStart(); I2CSendByte(addr+rd); // send address byte } void I2CSendByte(unsigned char bt) { register unsigned char i; for (i=0; i<8; i++) { if (bt & 0x80) SDA = 1; // Send each bit, MSB first changed 0x80 to 0x01 else SDA = 0; I2CSCLHigh(); I2CBitDly(); SCL = 0; I2CBitDly(); bt = bt << 1; } SDA = 1; // Check for ACK I2CBitDly(); I2CSCLHigh(); I2CBitDly(); if (SDA) SCL = 0; I2CBitDly(); SDA = 1; // end transmission SCL = 1; } unsigned char I2CGetByte(unsigned char lastone) // last one == 1 for last byte; 0 for any other byte { register unsigned char i, res; res = 0; for (i=0;i<8;i++) // Each bit at a time, MSB first { I2CSCLHigh(); I2CBitDly(); res *= 2; if (SDA) res++; SCL = 0; I2CBitDly(); } SDA = lastone; // Send ACK according to 'lastone' I2CSCLHigh(); I2CBitDly(); SCL = 0; SDA = 1; // end transmission SCL=1; I2CBitDly(); return(res); } void I2CSendStart(void) { SCL = 1; I2CBitDly(); SDA = 0; I2CBitDly(); SCL = 0; I2CBitDly(); } void I2CSendStop(void) { SDA = 0; I2CBitDly(); SCL = 1; I2CBitDly(); SDA = 1; I2CBitDly(); }
//----------------------------------------------------------------------- DS50002w.H Header file for Dallas Semiconductor DS5000/8051. ------------------------------------------------------------------------- #ifndef DS5000_HEADER_FILE #define DS5000_HEADER_FILE 1 //------------------------------------------------ DS5000 Byte Registers ------------------------------------------------ sfr P0 = 0x80; sfr SP = 0x81; sfr DPL = 0x82; sfr DPH = 0x83; sfr PCON = 0x87; sfr TCON = 0x88; sfr TMOD = 0x89; sfr TL0 = 0x8A; sfr TL1 = 0x8B; sfr TH0 = 0x8C; sfr TH1 = 0x8D; sfr P1 = 0x90; sfr SCON = 0x98; sfr SBUF = 0x99; sfr P2 = 0xA0; sfr IE = 0xA8; sfr P3 = 0xB0; sfr IP = 0xB8; sfr MCON = 0xC6; sfr TA = 0xC7; sfr PSW = 0xD0; sfr ACC = 0xE0; sfr B = 0xF0; //------------------------------------------------ DS5000 P0 Bit Registers ------------------------------------------------ sbit SDA = 0x80; sbit SCL = 0x81; sbit P0_2 = 0x82; sbit P0_3 = 0x83; sbit P0_4 = 0x84; sbit P0_5 = 0x85; sbit P0_6 = 0x86; sbit P0_7 = 0x87; //------------------------------------------------ DS5000 PCON Bit Values ------------------------------------------------ #define IDL_ 0x01 #define STOP_ 0x02 #define EWT_ 0x04 #define EPFW_ 0x08 #define WTR_ 0x10 #define PFW_ 0x20 #define POR_ 0x40 #define SMOD_ 0x80 //------------------------------------------------ DS5000 TCON Bit Registers ------------------------------------------------ sbit IT0 = 0x88; sbit IE0 = 0x89; sbit IT1 = 0x8A; sbit IE1 = 0x8B; sbit TR0 = 0x8C; sbit TF0 = 0x8D; sbit TR1 = 0x8E; sbit TF1 = 0x8F; //------------------------------------------------ DS5000 TMOD Bit Values ------------------------------------------------ #define T0_M0_ 0x01 #define T0_M1_ 0x02 #define T0_CT_ 0x04 #define T0_GATE_ 0x08 #define T1_M0_ 0x10 #define T1_M1_ 0x20 #define T1_CT_ 0x40 #define T1_GATE_ 0x80 #define T1_MASK_ 0xF0 #define T0_MASK_ 0x0F //------------------------------------------------ DS5000 P1 Bit Registers ------------------------------------------------ sbit P1_0 = 0x90; sbit P1_1 = 0x91; sbit P1_2 = 0x92; sbit P1_3 = 0x93; sbit P1_4 = 0x94; sbit P1_5 = 0x95; sbit P1_6 = 0x96; sbit P1_7 = 0x97; //------------------------------------------------ DS5000 SCON Bit Registers ------------------------------------------------ sbit RI = 0x98; sbit TI = 0x99; sbit RB8 = 0x9A; sbit TB8 = 0x9B; sbit REN = 0x9C; sbit SM2 = 0x9D; sbit SM1 = 0x9E; sbit SM0 = 0x9F; //------------------------------------------------ DS5000 P2 Bit Registers ------------------------------------------------ sbit P2_0 = 0xA0; sbit P2_1 = 0xA1; sbit P2_2 = 0xA2; sbit P2_3 = 0xA3; sbit P2_4 = 0xA4; sbit P2_5 = 0xA5; sbit P2_6 = 0xA6; sbit P2_7 = 0xA7; //------------------------------------------------ DS5000 IE Bit Registers ------------------------------------------------ sbit EX0 = 0xA8; sbit ET0 = 0xA9; sbit EX1 = 0xAA; sbit ET1 = 0xAB; sbit ES = 0xAC; sbit EA = 0xAF; //------------------------------------------------ DS5000 P3 Bit Registers (Mnemonics & Ports) ------------------------------------------------ sbit RD = 0xB7; sbit WR = 0xB6; sbit T1 = 0xB5; sbit T0 = 0xB4; sbit INT1 = 0xB3; sbit INT0 = 0xB2; sbit TXD = 0xB1; sbit RXD = 0xB0; sbit P3_0 = 0xB0; sbit P3_1 = 0xB1; sbit P3_2 = 0xB2; sbit P3_3 = 0xB3; sbit P3_4 = 0xB4; sbit P3_5 = 0xB5; sbit P3_6 = 0xB6; sbit P3_7 = 0xB7; //------------------------------------------------ DS5000 IP Bit Registers ------------------------------------------------ sbit PX0 = 0xB8; sbit PT0 = 0xB9; sbit PX1 = 0xBA; sbit PT1 = 0xBB; sbit PS = 0xBC; sbit RWT = 0xBF; //------------------------------------------------ DS5000 MCON Bit Values ------------------------------------------------ #define SL_ 0x01 #define PAA_ 0x02 #define ECE2_ 0x04 #define RA32_8_0x08 #define PA0_ 0x10 #define PA1_ 0x20 #define PA2_ 0x40 #define PA3_ 0x80 //------------------------------------------------ DS5000 PSW Bit Registers ------------------------------------------------ sbit P = 0xD0; sbit OV = 0xD2; sbit RS0 = 0xD3; sbit RS1 = 0xD4; sbit F0 = 0xD5; sbit AC = 0xD6; sbit CY = 0xD7; //------------------------------------------------ Interrupt Vectors: Interrupt Address = (Number * 8) + 3 ------------------------------------------------ #define IE0_VECTOR 0 // 0x03 #define TF0_VECTOR 1 // 0x0B #define IE1_VECTOR 2 // 0x13 #define TF1_VECTOR 3 // 0x1B #define SIO_VECTOR 4 // 0x23 #define PFW_VECTOR 5 // 0x2B //------------------------------------------------ ------------------------------------------------ #endif
