嵌入式新闻
| Name | Function |
| DP[0] | Data pointer 0 |
| DP[1] | Data pointer 1 |
| BP[OFFS] | Frame pointer base |
| OFFS | Offset of frame pointer base |
| DPC | Data pointer control |
| SDPS0 SDPS1 |
00b selects DP[0] as active pointer 01b selects DP[1] as active pointer 10b selects BP as active pointer |
| WBS0 | DP[0] word mode WBS0=1, byte mode WBSO=0 |
| WBS1 | DP[1] word mode WBS1=1, byte mode WBSO=0 |
| WBS2 | BP word mode WBS2=1, byte mode WBSO=0 |
| Register | Bit Position | |||||||
| DP[0] | DP[0] (16 bits) | |||||||
| DP[1] | DP[1] (16 bits) | |||||||
| BP | BP = BP[Offs] (16 bits) | |||||||
| OFFS | - | - | - | - | OFFS (8 Bits) | |||
| DPC | DPC (16 bits) | |||||||
| - | - | - | WBS2 | WBS1 | WBS0 | SDPS1 | SDPS0 | |
move DPC, #2 ;(explicit) selection of BP as the active pointer move DP[1], DP[1] ;(implicit) selection of DP[1]; set SDPS1: 0=01b move OFFS, src ;(implicit) selection of BP; set SDPS1=1 move @DP[0],src ;(implicit) selection of DP[0]; set SDPS1:0=00b
move NUL, @DP[0]++ ;increment DP[0] move NUL, @DP[1]-- ;decrement DP[1] move NUL, @BP[OFFS++] ;increment Frame Pointer Base + Offset + 1 move @++DP[0], A[1] ;increment address and store A[1] at new address ;Note: Only the pre-increment/decrement can be ;used ;when writing to memory move A[1], @DP[1]-- ;Reads value from DP[1] and store in A[1] then ;decrement ;Note: Only the post-increment/decrement can be ;used ;when reading from memory
int_Var1 EQU 0h ;address of int_Var1 to the first byte of SRAM int_Var2 EQU 1h ;address of int_Var2 to the second byte of SRAM main: move DPC, #4h ;Set DP[0] to word mode ;Must be set active before using move DP[0], #int_Var1 ;Load address of int_Var1 into DP[0] ;also activated DP[0] move @DP[0], #5555h ;write 5555h to SRAM at address of int_Var1 move DP[0], #int_Var2 ;Load address into of int_Var1 into DP[0] move @DP[0], #0AAAAh ;Writes AAAAh to SRAM at address of int_Var2 move DP[0], #int_Var1 ;Load address of int_Var1 into DP[0] move A[0], @DP[0] ;Reads from address of int_Var1 move DP[0], #int_Var2 ;Load address of int_Var2 into DP[0] move A[1], @DP[0] ;Reads from address of int_Var2 move AP, #0 ;select accumulator 0 and A[1] ;AND the A[1] and A[0] and store in A[0] end
int_Var1 EQU 0h ;address of int_Var1 to the first word of SRAM int_Var2 EQU 1h ;address of int_Var2 to the second word of SRAM main: move DPC, #0h ;Set DP[1] to byte mode ;Must be set active before using move DP[1], #int_Var1 ;Load address of int_Var1 into DP[1] ;also activated DP[1] move @DP[1], #55h ;write 55h to SRAM at address of int_Var1 move DP[1], #int_Var2 ;Load address into of int_Var1 into DP[1] move @DP[1], #0AAh ;Writes AAh to SRAM at address of int_Var2 move DP[1], #int_Var1 ;Load address of int_Var1 into DP[1] move A[0], @DP[1] ;Reads from address of int_Var1 move DP[1], #int_Var2 ;Load address of int_Var2 into DP[1] move A[1], @DP[1] ;Reads from address of int_Var2 move AP, #0 ;select accumulator 0 and A[1] ;AND the A[1] and A[0] and store in A[0] end
int_Var1 EQU 0h ;address of int_Var1 to the first word of SRAM int_Var2 EQU 1h ;address of int_Var2 to the second word of SRAM main: move DPC, #10h ;Set BP[OFFS] to word mode move BP, #0h ;Sets BP to 0 and activates BP[OFFS] move OFFS, #int_Var1 ;Load address of int_Var1 into OFFS move @BP[OFFS], #5555h ;write to 5555h to SRAM at address of int_Var1 move OFFS, #int_Var2 ;Load address into of int_Var1 into OFFS move @BP[OFFS], #0AAAAh ;Writes AAAAh to SRAM at address of int_Var2 move OFFS, #int_Var1 ;Load address of int_Var1 into OFFS move A[0], @BP[OFFS] ;Reads from address of int_Var1 move OFFS, #int_Var2 ;Load address of int_Var2 into OFFS move A[1], @BP[OFFS] ;Reads from address of int_Var2 move AP, #0 ;select accumulator 0 and A[1] ;AND the A[1] and A[0] and store in A[0] end
| Assembly Instruction | Problem | Solution |
move DP[0], DP[0] move A[1], @DP[0] move A[2], @DP[1] |
Data pointer initialized to DP[0]. Needs to be reinitialized to DP[1]. | move DP[0], DP[0] move A[1], @DP[0] move DP[1], DP[1] move A[2], @DP[1] |
move BP[OFFS], #0h |
BP and OFFS must be initialized separately. | move BP, #0h move OFFS, #0h |
move @DP[0]++, A[0] |
Only the pre-increment/decrement can be used. | move @++DP[0], A[0] |
move A[0], @++DP[0] |
Only the post-increment/decrement can be used. | move A[0], @DP[0]-- |
move @++DP[0], @DP[0]++ |
Unable to increment data pointer and store it using the same data pointer. | move A[1], @DP[0]++ move @++DP[0], A[1] |
move @DP[0]++, A[1] |
You cannot use post-increment/decrement for a destination. | move @DP[0], A[1] move NUL, @DP[0]++ |
move A[0], @--DP[0] |
You cannot use pre-increment/decrement for a source. | move NUL, @DP[0]-- move A[0], @DP[0] |
